Question about Frigidaire FAFW3801LW Washer
Trying to drain washer for move
I can't seem to find instructions anywhere on how to drain my washer. Please help!
  • Official Brand Answer
  • 4,342 Answers
Good Afternoon Jennifer, thank you for allowing me to assist you. I have located generic instructions on how to drain your washer, please follow the steps below:
1 Turn off water supply faucets.
2 Disconnect hoses from water supply and drain water from hoses.
3 Plug electrical cord into a properly grounded electrical outlet.
4 Add 1 gallon (3.8 L) nontoxic recreational vehicle (RV) antifreeze to empty wash drum. Close door.
5 Select the Spin Only cycle. Press Start and let the washer drain for 1 minute to drain out all the water.
(Not all of the RV antifreeze will be expelled.)
6 Press Cancel, unplug electrical power cord, dry off drum interior and close door.
7 Remove dispenser drawer. Drain any water in compartments and dry compartments. Replace drawer.
8 Store washer in an upright position.
9 To remove antifreeze from washer after storage, perform Clean System Cycle as described earlier.
I hope this information helps to some degree. If you have further questions, please do not hesitate to reconnect.
Posted on Jul 29, 2013
2 Suggested Answers
adadoug
  • 682 Answers
SOURCE: Washer hums but will not fill or start/ spin has water pressure and tub seems to move freely the model #on tag LTF2140ES0
If it doesn't fill it won't start any other cycle unless you move it ahead yourself. If it hums I am thinking it is trying to fill. Sounds like the valve is turning on to let water in but it is not getting through. My washer has a screen where the hoses go on and sometimes the screen becomes plugging with scale. If that is ok then the solenoid must be coming on but the valve is stuck. Does neither hot or cold settings work? Please rate my answer so I am rewarded points for it.
Posted on Jan 27, 2012
Washer not draining properly
check drain pump filter for blockage see instruction filter removal
Feb 08, 2013 | Smeg WDI12 Front Load Washer / Dryer
Whirlpool Front Loading Washer Only Spins in Diagnostic Mode
replace the brushes in the motor _around 20 quid and usually the first thing to start messing up when the brushes get short is the fast spin _UNPLUG IT FIRST. you might also like to clean up the com with a bit of wet and dry
Oct 02, 2012 | Whirlpool Washing Machines
Avanti w798-ss e3 error
It seems there is a fault on the main controller unit of the washer. It seems to start and then drain off in mid cycle. Now choose a different program and see if there is any change. Also check individually the inlet valve, the water level sensor and also the drain valve. Also check all the connections to the main panel.
Mar 13, 2012 | Avanti Top Load Washer W797
Jan 27, 2012 | Frigidaire Washing Machines
Clogged draining boot?
Check the drain filter and the drain hose at the back.
Drain filter access is located in the fro lower section of the front size. You need to remove the trim at the base of the washer and to undo the cap, turning it counter clockwise. Disconnect power before starting and keep a container ready to collect the water.
Dec 08, 2011 | Kenmore HE2 Plus Front Load Washer
Kenmore series 80 washer won't drain after wash cycle
Try the 'drain' portion of a few of the other cycles (heavy, perm. press, delicates) and see if it will drain/spin there. You can also try advancing the timer slowly through the 'spin' portion to see if it kicks in anywhere.
If it will rinse and spin in the other cycles, you most likely have a bad timer.
Hope this helps.
Sep 25, 2011 | Kenmore 22422 Top Load Washer
My kenmore washer model number 110. 92573210 washer seems fine it just will not drain, is this the water pump?
HI,
Check back of washe with a flashlight for a bent or clogged drain hose. Do not move washer to check it. When you move it , it will straighten out and you will never know if it was bent
Also while it is pumping , pick up end of drain hose at drain and observe the volume of water being pumped.
If no water then the Pump may need replaced
Thank you for using fixya
Leo Ponder
Please rate me if this helped
Aug 12, 2011 | Kenmore 22422 Top Load Washer
My daughter has a new Whirlpool WTW4800XQ0, it takes the machine about 3 hours to go through the cycle. Okay this being said, when it gets to the spin cycle, it doesn't, she is having to pull the...
does it drain water, seems like it's gonna spin then starts filling up again? if this is what's happening it mean the washer is sensing that the load isn't balanced and it fill back up to move the clothes around and tries again, it will keep doing this untill it senses a balance of weight in the drum. if she tries moving the clothes around herself before it done draining she maybe able to keep it from doing this
Aug 05, 2011 | Whirlpool WTW4800XQ Washer
Frigidaire FAFW3801LW Washer Logo
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
