Question about Whirlpool Dryers
Need to know where the 4 wires to the accudry sensor switch on a Whirlpool dryer go
I unplugged the wires and don't remember where they go...does anyone know where I can get a schematic for this or know where the wires go?
aborcass
  • 2651 Answers
SOURCE: I have a Whiilpool electric
the "moisture sensors " are located just to the right side below the lint filter housing. pop your hea inside and youll see 2 metal strips. thats them. with a scotchbrite pad, you can clean them off, usualy become fouled by dryer sheet residue. twice as long to dry couldalso be an indicator of a vent thats not completly free, kinked or becoming clogged .
Posted on Mar 07, 2008
erpaalai
  • 999 Answers
SOURCE: need amperage draw and plug configuration for whirlpool dryer
Electric dryers all use the 30Amp plug and rated wire depends on length of your run and local building codes.
Posted on Jun 08, 2009
jsrock516
  • 5911 Answers
SOURCE: I have a whirlpool accudry electric dryer and it
If the dryer2.gif runs, but does not heat, the following link explains how to troubleshoot an electric dryer with a no heat problem:
http://www.fixya.com/support/r630242-dryer_runs_but_not_heat
First, begin by unplugging the dryer and verifying the voltage at the wall receptacle. You should read 220-240VAC across the two Hot terminals (left and right slots). If the voltage is incorrect, check to make sure you don't have a breaker tripped. Some homes use 2 separate 120VAC breakers to provide power to the receptacle vice using one 240VAC breaker.
If the voltage IS correct, leave the dryer unplugged and remove the cover plate on the terminal block in the back of the dryer (this is where the power cord is installed). Plug the dryer back in and take a voltage reading across the two hot (RED and BLACK) wires at the terminal block. You should read 220-240VAC. If the voltage is good, you have an internal heating problem. If the voltage is bad at the terminal block, but good at the receptacle, you have a bad power cord.
NOTE: If the wires at the terminal block are not color coded, the outer two wires (left and right) are the hot leads. The center conductor is neutral or ground.
The reason a dryer will still run if the input voltage is incorrect, is because the drive motor only uses a portion of the 220 service. The motor runs off 110-120VAC, while the heating circuits require 220-240VAC. So, if you are missing 1/2 your input voltage due to a tripped breaker or bad power cord, your dryer may exhibit these symptoms.
If you determine the problem to be internal, the heating circuits will either be located in the rear of the washer on the right hand, or under the dryer drum on the right hand side. Usually, an easy way to determine is by the location of the lint screen filter. If the filter is on top of the dryer, the heating circuits are in the back of the dryer. If the lint screen is in the door, the heating circuits are located under the dryer drum.
All dryers are not constructed the same. However, the Heating Element is located inside a heater box. The Thermal Cut-Out (TCO) will be located on the outside of the heater box on the end opposite the heating element terminals. The Hi-Limit Thermostat will be located adjacent to the heating element terminals. If either the TCO or Hi-Limit Thermostat are determined to be bad, replace both components at the same time. That is why these components are commonly sold as a set. Failure to do so may result in premature failure of any parts you replace.
If the model number you have this listed under is correct, the TCO/Thermostat replacement kit (if required) is part number 279816. The heating element is part number 279838.
All these parts can be found at appliancepartspros.com, searspartsdirect.com, pcappliancerepair.com, or repairclinic.com. The average cost of these components varies, so shop around for the best price.
If you have any questions, please let me know. If the model number is NOT correct, please post back with a correct number so that I may be able to provide you with better assistance. I hope you find this information helpful.
Posted on Oct 04, 2009
Fix-Fox
  • 7 Answers
SOURCE: schematic / wiring diagram for Whirlpool Dryer timer motor M460-G
Here you go:
http://www.imesa.it/areatecnica/INDICE%202009/ASKO/SERVICE%20MANUAL%20PES%2010.pdf
Posted on Jun 17, 2010
Fix-Fox
  • 7 Answers
Here you go again :-)
Lights come on, press start and nothing ..
Start Switch is bad, When they go out it leave's a open circuit and all light will come on but no action.
After the circuit is closed then it tells the dryer to start cause the circuit activates both the timer and the motor.
Good Luck
Mike Z
Dec 01, 2013 | Whirlpool Cabrio WED5500X 27" Front-Load...
Whirlpool Ultimate Care 2 LEQ8000JQ3 w/ Accudry- how do I make sure the Accudry feature works properly when I replace element?
The orange wire mounted to the 250 limit at the base of the heating element connects to the timer motor. When the element is on the motor cannot move forward in autodry. When the element is off the timer motor slowly advances. that is how it works. If you small limit on top is blown you have a restriction in your venting system or a clogged filter chute or a bad cycling thermostat. I worked on one and did a video recently. ROPER DRYER NO HEAT VIDEO
Jul 08, 2012 | Whirlpool Dryers
Dryer does not heat up. cleaned exhaust, tried different cycles. still nothing. possibly heating element?
On the back of your dryer there are two over temp sensors, most times one will go bad for know reason, looking at the wires on the back you will see them going into a small silver cap looking thing this is the sensor , after you unplug this dryer remove the back of this unit, follow the wires till you see the sensor this has two wires on it , remove the wires and check the sensor for continuity . And of coarse inone is found then replace this sensoe it has the part number on it and if i remember corect it was around $4 , remember there are two sensors so look for both , if you dont have a tester then remove the wires and use a small jumper wire in it's place , start the dryer to see if it heating , if it is order the sensor , do not use the dryer with out the sensor , you could get a dryer fire !!! Frank
Oct 17, 2011 | Maytag Neptune MDG5500AW Gas Dryer
I need to replace the door switch on my GE Profile Gas Dryer DPSB620GC4ww and don't know how to get behind the panel on the front of the dryer. Can you give me detailed instructions on how to do this?
unplug it,open the door and look up,you'll see two phillips screws,take them out and remove the top panel,if you want to remove the front panel just remove the two phillips screws one on each side of the panel around 4 inches down from the top.
May 20, 2011 | GE Profile DPSB620GCWW Gas Dryer
Doesn't automatically turn off in accudry sensor
yes,the moisture sensor bars inside the unit can be replaced,you need to tear down part of the machine to do so,to further assist you,a model/serial# would help
Jul 17, 2010 | Whirlpool Dryers
My Whirlpool Imperial (Accudry) is not receiving power
MOST OF THE TIME IF NOTHING WORKS IT YOUR DOOR SWITCH,OR YOUR MAIN WHITE FUSE ON THE BLOWER BOX,LET ME KNOW-MIKE
Feb 23, 2009 | Whirlpool LEN2000PW Dryer
Whirlpool dryer
is hte light going out?? ope nteh door and try physically pushing the door switch (grey rectangle in the top center of door opning, does it "click" as you push it??? if not really push it, pull it, samck it a fewt imes. sometomes i find they hang up and dont function properly. but when i go to replace one it pops out as i start to change it
Mar 11, 2008 | Whirlpool GEW9250P Electric Dryer
Need help
This is some basic info I could find on your dryer. I will need you Serial Number in order to determine the year it was produced. Please post back with comments and let me know.
Whirlpool Duet GEW9250P 7.0 Cu. Ft. Super Capacity 8 Cycle Front Load Electric Dryer With AccuDry Sensing System. Dry clothes in the time it takes to wash them. The dryers uses AccelerCare™ technology to work just as fast as the washer (Up to a 9 lb. load), giving you more time to enjoy all the good things you've worked hard to achieve.
AccuDry™ Sensing System - Monitor remaining moisture and automatically stop the cycle when the load is dry, with the AccuDry™ sensor. Reduce overdrying and save time and effort, by not having to return to the dryer to re-check progress.
Senseon™ Drying System - Moisture-sensing strips and temperature sensors inside the dryer drum monitor how fast the load is drying, how hot the air should be and when clothes are dry. The system automatically stops the cycle to help save time and prevent overdrying. Senseon™ technology safely dries clothes faster than it takes to wash them.
Wrinkle Shield™ Plus Feature (120 Minutes) - The Wrinkle Shield™ Plus option automatically tumbles the load without heat to help prevent wrinkles from forming.
Whirlpool brand offers an ergonomic solution for its front-load washers and dryers to help reduce bending, stooping, or arching. Based on your height and laundry room needs, optional 10 in. and 15.5 in. pedestals make loading, unloading, and filling the dispensers easier. The 15.5 in. pedestal doubles as a storage drawer with a convenient sliding shelf to support your laundry basket.
Item Features:
  • Super Capacity Plus - 7.0 Cu. Ft.
  • AccuDry™ Sensor
  • Senseon™ Drying System
  • 8 Automatic Cycles
  • Bulky Items Cycle
  • Adjustable End-of-Cycle Signal
  • Wrinkle Shield™ Plus Feature (120 Min.)
  • 5 Temperature Selections
  • Quiet Dry Plus Noise Reduction
  • Dry Rack
  • Reversible Side-Swing Door
  • Dryer Door Window
  • Reversible Side Swing Door
  • Electronic Controls
  • Front-Mounted Lint Screen
  • Interior Drum Light
  • 4-Way Venting
  • Porcelain SpillGuard™ Top
  • Optional Storage Pedestals Available
  • Stackable Installation with Matching Washer
  • Matches Duet® Washer
Specs:
  • Warranty: 1 Year Parts & Labor
  • Capacity: 7.0 Cu. Ft.
  • Dimensions (HxWxD): 38 in. x 27 in. x 31 1/2 in; Depth with Door Open - 51.5"
  • Construction: Front Access, Reversible Side-Swing Door Style, Powder Coat Drum Material, Dry Rack, Extra Large Front Mount Lint Screen, Power Cord & Venting Accessories, Stackable
  • Controls: Electronic Controls
  • Electrical Requirements: 30 Ampere, 120/240 Volts, 60 Hertz (1/second). AC-ONLY. USE COPPER WIRE ONLY. A FOUR-WIRE OR THREE-WIRE, SINGLE PHASE ELECTRICAL SUPPLY REQUIRED. A TIME-DELAY FUSE OR CIRCUIT BREAKER AND SEPARATE CIRCUIT IS RECOMMENDED.
You can get an owner's manual replacement for your dryer at laundrymanuals.com. I believe there is a membership fee for the website, however. I hope this info helps you.
Nov 23, 2007 | Whirlpool GEW9250 Electric Dryer
Dryers Logo
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
