Question about Belkin Surf N300 Wireless N Router
Enable tkip on belkin N300 router
How can i enable the tkip encription on my belkin router, i have selected the authenticatin and security mode to wpa/wpa2-psk and the AES is the default encryption technique with no other options available?!
    Top Expert:
  • 12,223 Answers
You must install the disk and uninstall the software. Install again the software and select the wep key with password coming with the label in your router/modem. Try again.
Otherwise you must get support from belkin via ONline chat.
go http://www.belkin.com/us/support
God bless you
Posted on Jul 30, 2013
Can you connect several n300 routers
Connect a computer to one of the Belkin's "LAN" ports with an Ethernet cable.Open a Web browser and enter "192.168.2.1" into the address bar. Press "Enter."Click "Login," then click "Submit."Make a note of the WLAN MAC address on the Status page.Click "Wireless Bridging" under the "Wireless" category.Click to check the two boxes "Enable wireless bridging" and "Enable only specific access points to connect."Type the MAC address of the Belkin router and the MAC addresses of the other wireless routers or access points that are participating in the bridged WDS network. If using Belkin devices, repeat the previous steps to obtain the WLAN MAC addresses, otherwise refer to the owner's manual of the wireless device to find the WLAN MAC Address.Click "Apply Changes" to save the settings.
Nov 19, 2011 | Belkin Wireless Surf Router (F7D2301)
I have this belkin and I want only myself to use this router, how do I blocked it from others?
Hi there.
I'm sure you want to secure your wireless network so only you can access it. There are many ways in doing this But first you have to change the router's default password to this You can enable the wireless encryption so you will be prompted to type a network password before connecting to your network. Lastly you can enable MAC filtering.
To enable wireless security click the link below: http://www.belkin.com/support/article/?lid=en&pid=F5D8231-4&aid=10177&scid=0 To enable the MAC filtering click this link below: http://www.corenetworkz.com/2009/07/enable-mac-address-filtering-in-belkin.html
Apr 05, 2011 | Belkin (F5D6230-3) Wireless Router
Well it has no secruity and i can't put it on... How do i do it ?
  • You can configure WEP or WPA. But you cannot enable both at the same time.
  • You can configure MAC Access Control list and also enable WEP or WPA for additional security.
  • After you enable wireless security features on the router, you must configure your wireless clients with the matching settings. Your wireless clients will not be able to connect to your network unless you configure matching settings.
  • It is recommended you enable these wireless security settings from a computer wired to the router.
    1. Connect a computer to any one of the four LAN ports of the Belkin wireless router.
    2. Open your web browser and type the router IP address of the router (by default, the address is http://192.168.2.1.) in the address bar and press Enter.
    3. Click Login on the top of the page to login to the router. By default the Password is left blank, click Submit.
    4. Click Security under Wireless menu.
      1. Under Security, Select 64 bit WEP (or 128 bitWEP).
      2. Select Key 1 and enter any 10 hexadecimal digits - any combination of 0-9, A-F (26 digits if you selected 128-bit as the encryption strength). You may also enter a pass phrase and have the router generate a key for you.
      3. Apply the settings. Please write down the key - You will need it later to configure your wireless computers with the same key.
Mar 30, 2011 | Belkin Wireless G Plus MIMO (F5D9230-4)...
How can I find or reset the security key on my D-link WBR-2310 wireless router?
In order to find the wireless security password of your Dlink wireless router G WBR-2310 , please follow these setps
1. Open up the internet explorer in the computer in which you are online and clear the address bar and type in the number 192.168.0.1 and hit enter.
2. You will be logged into the D-Link router setup page .
3. Under the SETUP tab, in the left hand side, click on WIRELESS SETTINGS? you will find Wireless security Mode under which you can find the password for the wireless settings.
Good Luck!
Thanks in Advance!
With Regards,
Prema.
Jan 11, 2011 | D-Link RangeBooster G WBR-2310 Wireless...
New d-link router ,how wireless configuration lan internet acess complte but wireless not found pls help me kindly
Hi Friend,
Please follow the steps:
1. Click Start\ Run\ type cmd and hit enter.
2. In the black window type ipconfig and hit enter.
3. Note down the default gateway and cloe this window.
4. Open the web browser and type the default gateway and hit enter. Enter the username and password.
5.Click Wireless and then click Manual Wireless Network Setup at the bottom.
6.Make sure you fill/select the fields as mentioned below:
* Check the Enable box and note down the PIn.
* Wi-fi Status must be Enabled/Configured
* Check the Enable Wireless box
* Wireless Network name: As per your choice
* Select the last option from the drop down of 802.11 mode
* Check the Enable Auto Channel scan box.
* Select Visibility Status as Visible.
* Security Mode : WPA Personal
* WPA Mode: WPA Only
* Cipher Type: TKIP and AES
* Group key : 3600 seconds
* Pre-shared key : Any ten digit number (note down this number)
Once you enter informations click Save Settings. Turn off the router for 30 seconds and switch it on. Use the pre-shared key whenever yu try to connect any wireless devices.
I hope this will resolve the issue.
Regards
Chiranjeet
Dec 09, 2010 | D-Link DIR-600 Router
I cant enable the password
Hi Friend,
In order to enable wireless security password, please follow the steps:
1.Type 192.168.1.1 in the address bar of the web browser and hit enter
2.Enter the username and password. If you have not set the router password then leave the username blank and type admin in password and hit enter.
3.Click the tab Wirelss in the setup page and fill the sections
Wireless Network Mode:Mixed
Wireless Network Name:As per your choice
Wireless Channel-6-2.437GHz
Wireless SSID-Enabled and click Save Settings
4.Click Wireless Security and fill the sections as mentoned
Security Mode-WPA Personal
PA Algorith- TKIP
WPA Shared Key-Enter 10 digit password(e.g-your 10 digit telephone number) and click Save Settings
You have now set a password to your wireless network and is secured. Enjoy
Regards
Chiranjeet
Sep 16, 2010 | Linksys Wireless-G WRT54G Router
Want to make my belkin wireless router secure
Login to its web-interface.
Change the default ID ('admin') and password ('admin').
In the "wireless" settings, change the SSID,
and change it to *NOT* "broadcast" the SSID.
Enable "encryption" ('WEP' has been "hacked" -- do not use it;
'WPA-TKIP' has recently ben "hacked" -- do not use it).
Set a "password" for every wireless connection.
Sep 10, 2009 | Belkin MEDIAPILOT WIRELESS 2.4GHZ...
How do I put an encryption on my linksys router?
Securing your wireless network is a simple process, which generally does not require a lot of time. This can be done by:
  • Enabling WEP or WPA on the Router
  • Enabling Wireless MAC filter on the Router
  • Disabling SSID Broadcast on the Router
NOTE: The wireless security modes available may vary depending on the model of the router and wireless adapter you are using.
Enabling WEP on the Router
Wired Equivalent Protocol (WEP) is a type of wirelesssecurity which does not change. It provides comparable confidentialityto a traditional wired network. There are two types of WEP you canchoose from:
a. WEP 64-bit: This type of WEP consists of 10-hexadecimal codes. To enable WEP 64-bit, click here.
b. WEP 128-bit:This type of WEP consists of 26-hexadecimal codes hence it is moresecured compared to WEP 64-bit. To enable WEP 128-bit, click here.
Enabling WPA on the Router
Wi-Fi Protected Access (WPA) is a type of wireless securitywhich is dynamic in nature. Meaning, it changes depending on the timerenewal you will specify. Hence, WPA is more secured compared to WEP.
  • Temporal Key Integrity Protocol (WPA-TKIP) – utilizes a stronger encryption method and incorporates Message Integrity Code (MIC) to provide protection against hackers.
  • Advanced Encryption System (WPA-AES) – utilizes a symmetric 128-bit block data encryption
To enable WPA, click here.
Enabling Wireless MAC Filter on the Router
Wireless access can be filtered using the MAC address of thewireless devices transmitting within your network’s radius. You caneither permit or prevent specific wireless computers access to yourwireless network.
To permit wireless computers to connect to your wireless network, click here.
To prevent wireless computers to connect to your wireless network, click here.
Disabling the SSID broadcast is one way of securing your wirelessnetwork. This procedure will prevent other users from detecting yourSSID, or your wireless network name, when they attempt to viewavailable wireless networks in your area. For instructions, click here.
Jul 11, 2009 | Linksys Wireless-G WRT54G Router
Cant connect PC after encription
You may have a setting on the router that limits the number of authenticated wireless connections at one time. You will have to enter the web utility and check the wireless settings, particularily the security settings.
Apr 14, 2008 | Belkin (F5D7230-4) Router (587009)
Setting
All you have to do it open up your web browser. Go to your router's setup page (usually 192.168.1.1) Go to either admin., wireless security, or security.
Select your security mode (pick WPA personal as it is most compatible with your network.)
Select TKIP for your encription and set your passphrase(password)
Mar 22, 2008 | Belkin (F5D7231-4) Wireless Router
Belkin Surf N300 Wireless N Router Logo
90 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
