Question about Electrolux Epic 6500 Vacuum
Electrolux 6500 can't open canister
Can't get rear compartment open. Peeled back rubber trim strips ... only to reveal white plastic "I-beam" strip. How to proceed? (My main problem is a cord that won't rewind) Thanks very much for your time Tom
  • 1 more comment
  • Anonymous Jun 19, 2008
    how do you acess the power cord in an electrolux 6500 cannister
  • Anonymous Aug 18, 2008
    Same problem. Cord will not rewind
  • Anonymous Aug 24, 2008
    How do I open cannister to change defective rear wheel? I have removed gray bumper down to white plastic. Do I some how remove this white plastic, or is there another way to get it apart?
    Problem Solver:
  • 5 Answers
This is what I used to open my vac... Note - the white plastic strips under the bumper clips into the case at the front end (to help these instructions, you may also want to put a thin flat blade screw driver between the white plastic strip and the case, @ the inboard most point)...
If you want to open the machine, the two bumpers on either side, that say ELECTROUX hold the egg shell together. This is the process....
1. remove the bag, leave the bag cover open
2. lay the vacuum on its side on the floor with the bag cover to your right hand side.
3. place screw driver blade flat against the bumper on the opposite end from the bag cover, near the cordwinder cover, strike the screw driver firmly with a hammer, this will unlock the bumper and it will slide off toward the bag end of the machine.
4. turn the vacuum onto the other side, and follow the same process.
5. after both bumpers are removed you can get into the vacuum.
http://www.howtomendit.com/answers.php?id=57063
Posted on Dec 29, 2008
Http://www.howtomendit.com/~howtomen/answers.php?id=28739 good luck
Posted on Sep 01, 2007
SOURCE:
Splitting the shell on Electrolux Epix 6500
With the vacuum on flipped on it's top and the bag door open, wedge a screw driver between the rear cover and the bumper. Gently tap the side of the screw driver blade toward the front of the machine. Make sure you pay very careful attention to where everything goes. It is very specific inside for reassembly.
Dec 24, 2009 | Electrolux Guardian Bagged Canister Vacuum
I need a service manual Electrolux 6500
I don't have a service manual but maybe I can give you some instructions that will make some sense. Open the front of the canister and remove the bag. As you are looking at the front of the unit, there are two vinyl covered strips that run the length of the unit. Pull forward on these strips and then pull out so that the vinyl separates from the plastic underneath. Now grab the plastic strip with a pair of needle nose pliers and pull towards the front of the canister. These can be tough if the machine has never been opened up before, but pull as hard as you need to, to slide the strip out. Once both strips are out, turn the machine over, pull out on the sides of the bottom of the unit, and lift up. The bottom should come of relatively easily, and everything will be exposed. The control valve rests under the bag housing, since the machine is now upside down. I hope this helps. Good Luck!!
Jan 01, 2009 | Electrolux Epic 6500 Vacuum
Power cord will not retract on my Electrolux UltraLux 2000
You will need to take the machine apart to correct this. Open the front of the canister and remove the bag. As you are looking at the front of the unit, there are two vinyl covered strips that run the length of the unit. Pull forward on these strips and then pull out so that the vinyl separates from the plastic underneath. Now grab the plastic strip with a pair of needle nose pliers and pull towards the front of the canister. These can be tough if the machine has never been opened up before, but pull as hard as you need to, to slide the strip out. Once both strips are out, turn the machine over, pull out on the sides of the bottom of the unit, and lift up. The bottom should come off relatively easily, and everything will be exposed. Now, assuming that the cordwinder isn't damaged, you should be able to wind the cord in by hand. Once it gets started it may start to retract automatically. Usually the spring just gets in a bind against the housing when it's over extended, and rolling it in by hand a little will free it up. Good Luck!!
Dec 18, 2008 | Electrolux UltraLux 2000 Bagged Canister...
I can not get the power cord to go back into the canister.
If you can't get it to go back in by pulling on it, you will need to open up the machine to rewind it by hand. Open the front of the canister and remove the bag. As you are looking at the front of the unit, there are two vinyl coverd strips that run the length of the unit. Pull forward on these strips and then pull out so that the vinyl seperates from the plastic underneath. Now grab the plastic strip with a pair of needle nose pliers and pull towards the front of the canister. These can be tough if the machine has never been opened up before, but pull as hard as you need to, to slide the strip out. Once both strips are out, turn the machine over, pull out on the sides of the bottom of the unit, and lift up. The bottom should come of relatively easily, and eveything will be exposed. You can now see the cordwinder and the spring that pulls the cord back in. If it's not broken, you should be able to manipulate the spring reel by hand and get the cord started so that it will rewind by itself. If not, you probably need to have the cordwinder replaced. Good Luck!!
Dec 08, 2008 | Electrolux Epic 6500 Vacuum
I need to open the canister to change the switch
Open the front of the canister and remove the bag. As you are looking at the front of the unit, there are two vinyl coverd strips that run the length of the unit. Pull forward on these strips and then pull out so that the vinyl seperates from the plastic underneath. Now grab the plastic strip with a pair of needle nose pliers and pull towards the front of the canister. These can be tough if the machine has never been opened up before, but pull as hard as you need to, to slide the strip out. Once both strips are out, turn the machine over, pull out on the sides of the bottom of the unit, and lift up. The bottom should come of relatively easily, and eveything will be exposed. Good Luck!!
Dec 04, 2008 | Electrolux Epic 6500 Vacuum
Repair manual for Electrolux EPIC 6500 SR
I don't have a manual for these but the trickiest thing about these units is taking them apart. If you have an Aerus/Electrolux dealer near you, it's not a bad investment to have them install the motor for you. You would probably receive a warranty with the work, and the things a long time. Great return on investment. But if you are determined to do it yourself, open the front of the canister and remove the bag. As you are looking at the front of the unit, there are two vinyl coverd strips that run the length of the unit. Pull forward on these strips and then pull out so that the vinyl seperates from the plastic underneath. Now grab the plastic strip with a pair of needle nose pliers and pull towards the front of the canister. These can be tough if the machine has never been opened up before, but pull as hard as you need to, to slide the strip out. Once both strips are out, turn the machine over, pull out on the sides of the bottom of the unit, and lift up. The bottom should come of relatively easily, and eveything will be exposed. Good Luck!!
Aug 19, 2008 | Electrolux Epic 6500 Vacuum
Bag Full Sensor
Opening The Unit:
Remove the hose, open the door, and remove the bag. Making sure that the door is open wide enough, pull the rubber strip on each side of the canister toward the opening until they are completely removed. With a little shifting, you will now be able to pry open the top cover from the bottom. Remove the obstruction sensor hose so that you can completely separate the halves.
Note: If the strips will not move toward the front, the you will have to slide them off to the rear. You will need two screwdrivers to pry open the top rear of the unit far enough to release the back cover.
Locating The Switch:
The "trip" switch is located on the inside top cover under the power button. The trip switch is activated by the sensor valve next to it.
Aug 17, 2008 | Electrolux Epic 6500 Vacuum
Continued problem
Remove the rubber strip from each side. Open to access the bag. Slip a thin srcewdriver between the case and the small strip (that runs the lenght of the case) about 3/8 of an inch in. You should then be able to slip the strip out. Be careful when opening the case; you will need to reassemble it!
Mar 18, 2008 | Electrolux Epic 6500 Vacuum
How do i open a electrolux ultralux 2000
If I am right, there is a strip down the middle, on each side, they slide off then, the 2 halfs will come apart.
Jan 15, 2008 | Electrolux UltraLux 2000 Bagged Canister...
Can't open rear compartment
To seperate the two body halves: 1-Set the vacuum on it's wheels & open the front door. 2-Place a wide screwdriver blade just between the reaer cover and the rubber bumper and tap the screwdriver on the side to push the bumper forward towards the door a little bit. 3-Grasp the bumper and pull it straight out. 4-Leave the vacuum halves together...flip the vac over on it's top. 5-Put your palms against each wheel with your fingers in between the body halves..pull each side out just a little and snap the lower body upwards. It will then come apart. 6-You can then mark the wires on the cordwinder for corresct replacement afer the repair. Make sure you put the bumpers back on each I-Beam before you put it back together. (they don't need to be removed). And the FLAT end of the rubber bumper is against the front door. Good Luck !
Aug 30, 2007 | Electrolux Epic 6500 Vacuum
Vacuums Logo
285 people viewed this question
Top Electrolux Vacuums Experts
Marvin
Marvin
Chris Nomland
Chris Nomland
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
