Kitchenaid sure care two speed leaks water into tub after water shut off.
After the cycle is through it drips water into the tub. Maybe a leaking valve in the washer. Is there a plumbing diagram available? It's 18-20 yrs old. Thanks.
catriver
  • 878 Answers
SOURCE: AMANA WASHER WILL LEAKS WATER IN TUB AFTER SPIN CYCLE.
Cylon, sounds like you need to replace the water inlet valve. It's not seating and weeping water. For series 10 the part number would be 40097701. Not that hard of a job. Catriver..post back.
Posted on Feb 21, 2007
Buffalo12980
  • 625 Answers
SOURCE: Maytag top load washer leak
underneath the agitator is a graphite seal ring and nut that seals the inner tub and the outer tub. a suitable spanner wrench or a 6 inch channel lock plier will remove this locknut. replace the seal.
Posted on Sep 02, 2007
dididsaythat
  • 291 Answers
you have a bad water valve.. replace the valve where the hoses are hooked to your washer
futureloginn
  • 734 Answers
SOURCE: Kitchenaid Top Loader leaks
It leaksYour washer can develop several types of leaks. You can track down a leak based on when it occurs:
During fill only
During drain and spin only
All the time
During fill only
If the washer leaks only during the fill cycle, check these:
Air-gap device -The air gap is a small device found on most washers that prevents the wash water from being siphoned into the household water supply. It's located either mid-way along or at the end of the black rubber hose that comes from the water-inlet valve. Often it's made of translucent plastic. If one of the air-gap components deforms or cracks, you may need to replace it.
The tube -There's a rubber tube that runs between the water-inlet valve and either the air-gap or the inlet spout. If it cracks or breaks, it can cause a leak.
Inlet spout -Most washers have a plastic spout near the top of the main clothes tub that directs the water into the tub. If the spout cracks or breaks free of its mounting, it can cause a leak.
A washer that leaks only during the spin cycle often has a leak in the main drain hose. Inspect the entire hose and correct any problem you find. Alternatively, the steel or plastic outer tubs can rust, split, or be punctured. This may be most visible during large loads and high water levels. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
All the time
If the washer leaks all the time, check these:
Hot and cold water fill hoses - Check the hot and cold water hoses from the household plumbing. If either hose is leaking, tighten it or replace it, as appropriate.
Main tub seal - The main tub seal is located between the transmission and the outer tub. It's the primary water seal in the outer tub for the transmission-shaft entry point. If this seal leaks, you can see the leak by opening up the machine's main access panel while the machine is full of water with a small amount of detergent in it. The leak appears at the underside of the outer tub, at or near the center. This seal is difficult to replace. You probably should call a qualified appliance repair technician.
Pump - If the pump leaks, you can probably spot the leak when the tub is full of water. The pump has two or more black rubber or plastic hoses attached to it and usually has a drive belt that spins the pump. If the pump is leaking, you need to replace it.
Outer tub - Over time, the steel or plastic outer tubs can rust, split, or be punctured. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
Posted on Dec 12, 2008
barkencoa
  • 3463 Answers
SOURCE: Washer leaking when filling up tub
Unlikely to be pump, sounds more like hose leaking, or drum seal.
Depending upon severity of leak, place a sheet of newspaper under front of m/c, pushing it as far back as you can. switch m/c on for a few secs, then switch off, remove paper and you should be able to judge where leak is.
Tilt m/c back and have a look underneath.
At 12 years old, if it looks major, I think I would replace m/c.
Plz rate my solution.
Thanks.
Posted on Dec 31, 2008
Water dispenser drips sometimes after filling a cup with water. Does not happen every time. If not addressed, the drip continues indefinitely. To stop the drip, I use my index finger to give a good poke...
When water leaks from the dispenser like this it will be caused by a defective water control valve that will not shut properly when off. The leaking water is the same as a leaking faucet. The KSCS25IN uses a=> W10247725-Water Control Valve or HERE
Sea Breeze
Sep 24, 2013 | KitchenAid KSCS25IN Side by Side...
MAH3000AWW FILLS WITH WATER ON WASH CYCLE BUT DOES NOT SHUT THE WATER OFF WHEN IT GETS FULL AND THEN LEAKS ON THE FLOOR. IT IS ONLY THE HOT WATER.
A defect in the water-inlet valve may mean that it's no longer able to shut off completely when the electricity has been turned off to it. If this occurs, the valve may leak and drip water into the clothes tub. In time, the water may accumulate substantially. If this happens, you need to replace the valve. A defect--or an obstruction--in the water-level switch may mean that it can't tell the water to shut off. So the machine overflows. This switch senses the water level in the clothes tub. It's usually a diaphragm device with a small, clear tube attached between the switch and the bottom of the washer's outer tub. As the water level in the tub increases, the pressure on the air in the tube increases. When the pressure reaches a certain level, it activates the switch, shuts off the water, and signals the timer to begin the agitate cycle. You can either clear any obstruction in the tube or replace the water-level switch.
Here is a link to the water inlet valve.Here is a link to the water pressure switch.
Dec 31, 2010 | Maytag Washing Machines
Speed Queen top loader leaks from top of tub at large load spin c
make sure unit is level possibly lower front legs down so front sits higher,,, and also when u put or load in push the tub back so when the water enters it all enters into the tub sometimes the water will splash on the tube and cause a problem u are discribing hope this help
Feb 03, 2010 | Speed Queen ATS90AWN Front Load Washer
Drips from center of front cover when filling at 3-4 inches
after carefully reading this, the leak is at the machines water valves, or from them to hose to tub.
Sep 10, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Water leaked from bottom of washer
Check the pump right where the motor shaft goes into it. The pump seal can leak right there and the water drips directly onto the floor. It will continue to run out after the cycle till the remaining water drains out of the tub and drain hose.
Jun 19, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Small amt of water drips into tub after washer stops fisher payke
  • Hot and cold water fill hoses - Check the hot and cold water hoses from the household plumbing. If either hose is leaking, tighten it or replace it, as appropriate.
  • Main tub seal - The main tub seal is located between the transmission and the outer tub. It's the primary water seal in the outer tub for the transmission-shaft entry point. If this seal leaks, you can see the leak by opening up the machine's main access panel while the machine is full of water with a small amount of detergent in it. The leak appears at the underside of the outer tub, at or near the center. This seal is difficult to replace. You probably should call a qualified appliance repair technician.
  • Pump - If the pump leaks, you can probably spot the leak when the tub is full of water. The pump has two or more black rubber or plastic hoses attached to it and usually has a drive belt that spins the pump. If the pump is leaking, you need to replace it.
  • Outer tub - Over time, the steel or plastic outer tubs can rust, split, or be punctured. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
  • thanks and please do not forget to accept the solution
Apr 03, 2009 | Fisher Washing Machines
Leak
Your inlet water valve where the fill hoses attach is stuck open.
Mar 18, 2009 | Washing Machines
During fill only
All the time
During fill only
All the time
Apr 16, 2008 | KitchenAid KAWS700L Top Load Washer
Leaks
Possible the leak comes from under the tub. Remove the wall plug & take off the rear panel. Check to see if the hose from the under the tub is secure, it could be the grip clip below the hose has come off. This is where it connects to the pump section. You need a grip plier or something to get it back on securely. If this is not the case take a good look to see where the leak comes from.
Next is the door gasket, maybe a tear.
Nov 25, 2007 | Maytag Neptune MAH5500B Front Load Washer
Leak from maytag top load coin machine during spin drain cycle only
Possible that you would have a tub seal leak if it is only noticable during spin cycle. Possible that it "drips" slightly while in agitation, but not enough to notice it. While in spin mode you have a lot more parts moving as well as a lot more water pressure on the seal itself. Pump could also be leaking, but highly doubtful since it would leak a constant amount at all times. Good Luck!!! Jim
Sep 07, 2007 | Maytag MAT13MN Top Load Washer
Washing Machines Logo
Top Washing Machines Experts
