Question about Vantec Nexstar Universal Storage Adapter with Built in Card Reader 2535525 IDESATA to USB (CBISATACR) IDE EIDE Serial ATA USB USB 20 Drive Case
Why do I get 4 "removable disk" entries in windows Explorer when I plug in my Nexstar Universal Storage Adapter
My Nexstar Universal Storage Adapter can connect to 3 HDD types (SATA, IDE, SCSI) and 4 memory cards (CF, XD, MS, SD). When I plug it in to a usb port with no hdd or card connected to it, I get 4 entries in Windows Explorer and 4 icons in MY Computer. They're all the same: "Removable Disk" followed by a drive letter. They must be referring to the memory cards, right? Is this normal? Are they supposed to be there even though no card is connected to the adapter? It's annoying if I connect an HDD and I get 4 meaningless entries in Explorer. If they shouldn't be there since no card is connected, how do I stop them from appearing?
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 183 Answers
5 Suggested Answers
fire sine
  • 382 Answers
SOURCE: Nexstar External drive
If neither computers detect it, which is a good form of process of elimination, I would test the cable with a known working. I would then extract the drive from the enclosure. And try mounting into a desktop machine as a slave, or find another enclosure.
Posted on Oct 22, 2007
SOURCE: Nexstar.3 Sata external drive woun't start
I also have the same problem. I bought a 500gb WD HDD and it worked great via USB for about 4 days, not the computer does not have it. i am running windows xp home. i can also hear the drive working and the blue light comes on, but it is delayed. When it was working correctly it came on instantly and the computer found it instantly.
Posted on Sep 11, 2008
wuntwowun
SOURCE: Computer not detecting NexStar 3 USB 2.0 External hard drive
I'm not a computer expert so I won't use too much tech language but after months of dissapointment, I finally got my NexStar 3 to work and it was actually easy!
At first I thought it was a driver problem so I tried to find a driver on line or in the disc provided (it wasn't neccessary as I run windows XP).
Then I actually opened the disc provided and found the PDF manual and opened that for a read (maybe the answer was in there?) Yep!! It has the answer you are looking for. Part of this manual 5.2 describes that "a partition is required" if the hard drive does not appear under My Computer.
To do this you:
Right click on your "My Computer" icon and choose "Manage",
Under "Storage" on the LEFT pane, select "Disc Management",
Find the drive (mine was around 300GB so I knew it was the one) at the bottom Left and "Initialize" the disc by clicking on "not initialized",
Then in the bottom RIGHT Pane, where the status bar is, Right click and choose New Partition,
Follow the directions from the Wizard. (Recommended partition type is "Primary" and file type "NTFS".
When this is done you should see your drive under My Computer.
NOTE: This formatted around 23GB on the newly created "E" drive I selected.
After this, by Right clicking the other unallocated area of the drive I went on to format the rest of the drive as a "F" drive which contains the other 256GB.
Hope this helps!
Keith in South Australia.
Posted on Sep 20, 2008
ViscamTech
  • 528 Answers
SOURCE: windows 7 NexStar CX USB 2.0
This is the usual reason:
USB port has 4 pins (connectors). The two at the ends supply 5 Volts to the hard drive (or any other appliance you connect. I don't think there's a problem with those two because you can see the power light on the hard drive.
The middle is for data transfer. If one gets damaged, although the device gets power, the OS cannot recognize the device.
Try changing the USB cable you are using. Connectors in the wire are damaged more easily than those in the device.
Posted on Jul 14, 2011
I purchased two identical hard drives. (MyBook Essentials 2T) The first one works fine, the second, loads the driver and says it is now ready to use, but when I look for it, it is not there. (Show...
What may be happening is it's conflicting drive letters.
Try this.. Plug in the drive. Right click on My Computer, choose Manage. Go to Disk Management under Storage.
Look for the WD drive there, it may have no drive letter associated with it. That would be the problem. Right click on the drive entry and choose Change Drive letter. Pick a Letter.
Exit out and open windows explorer and the drive should now show up.
Jan 28, 2011 | Western Digital My Book Essential...
My model # is USBFL880-C Yesterday I formatted my hard drive on my workstation. I moved all my data and 6 years of pictures to my SmartDisk without a problem. Ready to put the data back on my PC; plugged...
An external storage-device has four major components:
* the USB cable
* the power-adapter
* the disk-drive inside the enclosure
* the USB-to-disk-drive adapter inside the enclosure.
One of these components has failed.
Try a different USB cable.
Try connecting to a different USB port on your computer.
Try connecting to a USB port on a different computer.
Take a "multi-meter" and measure both the voltage and amperage output from the AC adapter, and compare with the specifications on the label on the adapter.
Open the enclosure, and remove the disk-drive, and then connect it as a "slave" disk-drive in a desktop computer, to see if it works at all.
Purchase a new, compatible, disk-drive, and install it in the enclosure, to "revive" your external storage device.
Get the part-number and serial-number from the label on your disk-drive, and access the manufacturer's web-site, and use "check warranty status", to see if they will replace the device, at minimal cost to you.
There exist commercial "data recovery" services that can try to repair your device, just long-enough to rescue and copy your files. For example, see: https://services.seagate.com/index.aspx?lng=en-US for a "no data - no charge guarantee".
Nov 17, 2010 | SmartDisk FireLite 40 GB Hard Drive
I've got an old dell laptop from which I want to accesss the photos and documents but the power won't stay on..the green power light stays on for only a few seconds then goes off! please help?
Get hold of a desktop computer that is working. Open the Hard Disk Drive cover of your laptop. Pull out the Hard disk. Get a cable (an example is Nexstar universal storage adapter) which can be used to connect your laptop Hard disk to the desktop via USB port. A desk top allows multiple drives. This way you can get the laptop HDD as a seperate drive in your My computer, (like you see a pendrive or a CD drive. You can try reading this drive and copy content to the desktop. Pretty easy to transfer data and a useful device to have. You can find this device at http://www.amazon.com/Vantec-NexStar-Universal-Storage-Adapter/dp/B002PXFZ3C
Jun 14, 2010 | Dell Latitude CPI Notebook
The external hard disc is not detected by the computer
Please Check in Device Manager
To Open Device Manager, Right Click My Computer icon and click on Properties. No click Tab called Device Manager. In open window please look at last entries that may be " Universal Storage Controller. and IS there any Entry Looks like MASS STORAGE Device with Yellow Mark on. IF yes then right click on that click un install and re- plug HDD.
Also please check whether LED is blinking or not in HDD. if not then try check by replacing USB cable.
Mar 16, 2010 | Computers & Internet
My drive showing removable disk in the my computer.but can't acess anything.also nt able to format my drive.
Remove the USB flash drive from the USB port on your computer. Restart the computer and wait for the operating system to finish loading. Plug the flash drive back into the USB port and attempt to access it again in case the computer stopped recognizing the drive for some reason.
Transfer any files on the flash drive to the hard drive of your computer if the USB flash drive has any functionality at all.
Open the Start menu by clicking on the Windows icon on the bottom tool bar. Click on the "Control Panel" link. Scroll down through the list of available options and click on the icon labeled "Administrative Tools" that has an image of a box filled with check marks.
Find the Computer Management icon at the top of the window and click on it. Wait for a new window to appear on the screen and click on the "Continue" button to bring up the Computer Management window.
Locate the "Storage" entry on the left side of the Computer Management window. Click on the black box next to the entry to expand the menu. Click on the "Disk Management" icon that appears below the Storage entry.
Right-click the name of the the USB flash drive that appears at the center of the window. Click on the option labeled as "Format..." from the menu that will pop up. Select the "FAT16" option from the first drop-down menu and click on "Start" to format the flash drive.
Return to the Control Panel and click on the "Device Manager" icon. Scroll down to the entry labeled as "Universal Serial Bus Controllers." Right-click on the entry for your USB drive and choose "Update Driver." Wait for the latest USB driver to finish downloading and then attempt to use the flash drive again.
Sep 01, 2009 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
I Need Windows XP Drivers for Sony VAIO VGN-NS10L/S Laptop
Good day!!! I know the link for the VGN series for windows XP drivers you can download the drivers there ( http://www.getpcmemory.com/drivers/download-sony-vaio-vgn-series-notebooks-windows-xp-drivers/ ) hope this one can solve your problem.Cheers and God Bless.
Jun 23, 2009 | HP LaserJet P2015 Printer
I have problems connecting my moto w230 mobile to my laptop through datacable...
motorola w230 is the cheapest mp3 phone ever made.
to connect it with PC we can only use it as a removable disk -or we can say as- same as an USB FLASH DISK ,in other way we can't use it as a modem.
because from my experience i think w230 is not design to be a modem.
and how to entry the mp3 file is by connect it to PC and use the phone as disk storage by clicking YES option every time it connect. for windows user use windows explorer or click my computer icon on the desktop then explore the computer & you'll find your phone as "removable disk" item. you'll find 3 folder ; music, picture, and system.
copy your mp3 and paste it to the folder "music" on the w230 "removable disk".
although can't connect to a PC/laptop we can still use the internet through the phone with a minimal facility.
Feb 02, 2009 | Motorola Mobility W230 Phone US with...
Sounds to me like driver related problem. Download this tool: Driver Update and update the drivers. Have a nice day
Tom
Sep 27, 2007 | Vantec 1 Bay NexStar 3 USB 2.0 External...
Vantec Nexstar Universal Storage Adapter with Built in Card Reader 2535525 IDESATA to USB (CBISATACR) IDE  EIDE Serial ATA USB USB 20 Drive Case Logo
108 people viewed this question
Top Vantec Computers & Internet Experts
Willem.
Willem.
Piyal Perera
Piyal Perera
David Payne
David Payne
Are you a Vantec Computer and Internet Expert? Answer questions, earn points and help others
