Question about Maytag Centennial 7.0 Cu. Ft. Super Capacity Plus Electric Dryer
Maytag centennial dryer medc400vw0
Where do you locate the thermal fuse so that one can check to see if it requires replacing?
SOURCE: Dryer does not start - Thermal Fuse is ok.
My Maytag Electric Dryer stopped working mid cycle and wont turn on at all now. Any ideas?
Posted on Jan 06, 2009
SOURCE: maytag PYE4558AYW
I bought the thermal fuse kit for this dryer (2 THERMAL FUSES)and replaced both of them. It came with an extra fuse for a gas dryer. It now works fine. Lift the top open. One is toward the rear of the dryer, the other is below the heating element as the other solution said.
Posted on Jan 09, 2009
kachbibi1
  • 979 Answers
SOURCE: where in Thermal fuse located maytag model #PYE2300AYW
Take the top off the dryer and you should find it located at or near the drum.
Posted on Jan 17, 2009
  • 492 Answers
SOURCE: where is the thermal fuse located?
In the back of the dryer. Look for the coiled heaters and follow the lead wires back to the fuse.
Posted on Apr 30, 2009
jsrock516
  • 5911 Answers
SOURCE: Location of Thermal Fuse
The thermal fuse is located near the heating element. The part number for the replacement kit is LA-1053. You can view an illustrated parts break down of your dryer at searspartsdirect.com. Just type in your model number and locate item 5 under the "Heater" section. Pay close attention to the instructions in the thermal fuse replacment kit. One thermostat is for a GAS dryer, one is for an ELECTRIC dryer. Read the instructions and make sure you use the correct one. If you have any questions, please let me know. I hope this helps you.
Posted on Jan 06, 2010
Testimonial: "Excellent info. Thermal fuse was out of sight. Mention about LA-1053 helped. Honestly, I didn't know how thermal fuse looked like."
My maytag centennial dryer takes almost two hours to dry a load, it is electric I was wondering if I can convert it to gas? Model # MEDC400VW0
No. Among many issues is that the control board is different. But why not fix the unit so it dries as is normal in under an hour. Half of your 240 volts is out? Your heating element is bad. Your fan is loose.
May 06, 2017 | Maytag Dryers
Where is the thermal fuse located at on kenmore microwave model 665
Depending on the total part number 665xxxxxx a replaceable fuse is located behind the control panel usuallyon the floor of the control cabinet.
on one specific model "not yours" to check out the fuse locations a part number 309796 was found and I've included an image. Values of the fuses change based on specific models.
A typical location is included in the following image.
26047724-i5ybdsgcpm55v0g4hkv2rsri-5-2.jpg During previous repairs the fuse holder has failed and has required repair in addition to the fuse being replaced. This work needs to be accomplished by a qualified repair person. Even with power remove voltages remain because of stored engergy in the capacitors.
Hope this has been of help?
Jan 10, 2016 | Kenmore Microwave Ovens
My maytag centennial dryer dryer wont heat up what could be the problem
model number should be listed,Gas or electric? sounds like your thermal fuse has popped or element is broken and needs to be replaced a continuity check can be performed on both
Feb 18, 2015 | Maytag Dryers
How do i get my electric dryer to work
In the Dryer doesn't Start up your Thermal Fuse it most likely Bad
you can do a continuity Test on the Thermal Fuse
Feb 16, 2015 | Maytag Centennial Series MEDC200XW
My centennial dryer MEDC200XW1 wont start.
Hello;
My name is Peter. I am a retired field service appliance technician.
There are several reasons your dryer will not start.
1.) Bad door switch?
2.) Plugged up with lint?
3.) Thermal fuse?
a.) On the back of your dryer is a hot air distribution manifold. It is easily un-bolted to remove. In the bottom of this manifold dryers get plugged up with lint. If you have a air flow problem your unit will shut down.
Your unit will also not run if you have a bad door switch.
But, here is where I am going to put my money on as your problem.
High limit thermostat on your heater element in the back of your unit.
  • The thermostat is functional to 221 degrees (Fahrenheit).
  • Install the thermostat in your dryer's heater element housing box. Be sure your dryer is unplugged during installation.
This High-Limit Thermostat part #3977767 Cost: $15.00
You can replace this part yourself.
Get back to me if this does not solve you problem. You cab jump the door switch.
Maytag model MEDC400VW0 continues to run after drying cycle is completed
Sometimes these machines have a cool down cycle which for most people is too long
Dec 15, 2014 | Maytag Centennial 7.0 Cu. Ft. Super...
What might stop electrical slow?
Hello, Vickie
Your machine does not turn on AND you have (or had) calcium deposits in the reservoir valve so, my best guess is:
First the calcium deposits blocked water from going into the heating unit.
Then, the heating unit over-heated and the thermal fuse opened to prevent a fire.
So, you may have to replace the thermal fuse.
This will require disassembly to access the water heating module, locating of the thermal fuse, reading the fuse information from the spent fuse, locating a source for a replacement fuse...etc. Thermal fuses cost about $2 at electronic supply outlets.
Ted
Dec 30, 2013 | Cuisinart SS-700 5-Cup Coffee Maker
thermal fuse..or switch in the door is broke
Oct 03, 2013 | Dryers
May be a thermal fuse or high limit switch.
Sep 26, 2013 | Maytag Centennial 7.0 Cu. Ft. Super...
Open Questions:
See all Maytag Centennial 7.0 Cu. Ft. Super Capacity Plus Questions
Maytag Centennial 7.0 Cu. Ft. Super Capacity Plus Electric Dryer Logo
177 people viewed this question
Top Maytag Dryers Experts
Tim Whalen
Sal De
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
