Question about LG 42LE5500 42 in. TV
LG LED TV not responding to panel or remote commands
Hello, I ve been having a problem with my tv, bought about a year ago. One day, when i turned the tv on, the front panels buttons kept their lights on (they used to dissapear after the tv switched on) and i couldnt operate the tv neither from the panel nor the remote control anymore. i had to unplug the tv and plug it again. then it worked normally. Now its happening 90 percent of the times i try to use the tv. the only use i gave to the tv was work as a pc monitor via hdmi, and not so many hours a day. nothing strange happened. sometimes If I turn the tv on (thats the only moment when the remote or the panel works) and touch the volume or input buttons, the tv responds but then not anymore. batteries are ok. i dont know what can be happening. I loaded the factory defaults by the menu but the problem stils happening please. help thanks a lot Alan PS: by the way, my tvs back label reads: model 42LE5550-sb (instead of 42le5500) does this means anything?? i havent found anything about 5550-SB .
LG LCD TV Remote sensor not responding.
Give it back to the dude that "repaired" it! Remote was working when you took it in so .......................
Call them - maybe they can walk you thru it - otherwise you know what to do!!!!!!!!!
Sep 25, 2015 | LG Televison & Video
47lx6500 buttons on tv don,t respond. Cannot switch of the television
touch button module isdead ir module also attached to the same board so replacing it might solve both of your problems
Jul 05, 2014 | LG 47LX6500 47-Inch 3D 1080p 240 Hz LED...
Tv fault finding
try diffrent sources of signal in put then if not work then service it
Nov 19, 2013 | LG Televison & Video
LE5400 stuck at welcome screen
yes the problem on you unit is the main pcb , signal board need to be replace
Feb 27, 2012 | LG 47LE5400 47 in. TV
Hello! I bought a LG 32-inch LCD (32 inch )
My best advice would be to call out your LG service repair engineer, it is most likely the current software in the TV is of an older version & will need to be re-programmed which an engineer should be able to check. This should cure the menu problem.
Mar 21, 2010 | LG Televison & Video
We just bought a 55LH90 LG LED tv. Our directv
I used my directv remote to access the setup and was guided through the steps to make my directv remote the "do everything" remote.
Nov 02, 2009 | LG 55LH90 55 in. LCD HDTV
The TV started acting odd a week ago. Initially, the picture would freeze on a frame but the sound would continue. Using the remote to then turn it off would take a long time for the tv to respond to the...
If it is less than a year old than it is still under Warranty from LG. Their Customer Service Number is 1800-243-000. It sounds like to me it needs a Main Board to be replaced. Let LG help you get in touch with a Factory Service Facility to get you back up running again.
I hope this helps,
Skyassoc
Oct 21, 2009 | LG 42LG50 42 in. LCD HDTV
Sony TV no longer responds to Harmony remote
try using some rechargeable batteries. they tend to have more miliamps and last longer.
Jan 14, 2009 | Logitech Harmony 670 LCD Remote Control
Remote problems
Replace batteries of your LG remote.
Oct 11, 2008 | LG 50PC5DC 50 in. Plasma HDTV
LG 42LE5500 42 in. TV Logo
78 people viewed this question
Computer Repairing
Computer Repairing
