Question about Samsung ML 2010 Laser Printer
Both led's are on!
I just installed a new toner/cartridge - my 3rd since buying this product in Feb 2006. It just won't print. Can someone help, please? Thanks.
  • 161 Answers
Both LED's usually indicate bad fuser unit. This is common after a power failure or voltage surge. Your unit is out of warranty, and a new fuser will most probably cost you around $90.00 - $110.00. I beleive a new unit will be your best shot.
Posted on Sep 22, 2007
I just changed the toner and the printer does not print.
If u have the CD of tht printer , u just delet tht printer from the Devices and printers settings. And re installed it
Aug 14, 2012 | Brother HL-2040 Laser Printer
I have an HP Color LaserJet 2600n. Recently I had to replace the magenta cartridge. I bought a 3rd-party cartridge and the printer display shows that magenta is now "full." But, it won't...
I guess you should try to reset it ..and get the cartridge out and see if the toner (ink ) is getting out ..by pressing it (with the part where you removed the tape ) on some absorbent paper ..when it is working well it should leave a mark on the paper ..the mark should be not washed ...but real color and all...
If it do not ..just use a syringe and blow air in the cartridge ..just to agitate it ..and make sure it is not dry ..
Insert it back ..repeat the procedure until works ..and also if you have the procedure ..reset it ..
http://www.ehow.com/how_6881778_reset-2600n-toner-chip.html
Aug 09, 2011 | HP Color LaserJet 2600n Printer
HP Color Laserjet Cp2025n Printer - driver says it's out of toner and won't print. No true. I put in new toner cartridge last week. How do I get it toreceognize the new toner?
Did you purchase a new OEM HP toner or a refilled or remanufactured toner. It is possible that the chip is bad on the cartridge in which case if it is a true HP cartridge have them replace it. If you purchased 3rd party go after the vendor to replace it.
Jun 28, 2011 | HP Laserjet Cp2025n Printer
Changed toner---back side now prints dirty with band on the top. Did the cleaning procedure - no luck
If you changed toner because old was empty and now you have this defect with the new cartrige, it is most likley a defective cartridge. Try the old cartridge again, if it prints clean, then you know for sure it is the cartridge. If you purchased a new HP cartridge, get it replaced by HP, they warranty their toners against defects. If you bought a 3rd party toner, return it to where you bought it and get them to replace it. If you had your old toner refilled by someone, get your money back, they don't know what they are doing. This type of defect is often caused by a filled waste toner bin then then runs back out when you print. Some refillers just throw toner in and don't empty the waste toner bin.
Jun 07, 2011 | Office Equipment & Supplies
I have a Brother Laser Printer HL-5350DN. I refill toner myself but the toner light will not go out. How do I reset it so it goes off?
There is a reset gear in the cartridge that needs to be "reset" or replaced. I've included a link to a PDF file that goes over the procedure to properly refill and reset the toner cartridge. This is a document that is used by a company that does a complete rebuild, so you probably won't need most of the information, just the part on resetting the reset gear.
http://www.uninetimaging.com/downloads/technical/TecArtWebAdded/Brother_HL_5300_Series_tn650_Reman_Eng.pdf
Apr 05, 2011 | Brother HL5350DN Laser Printer
How to change cartridge
Step one: Prepare the print cartridge CAUTION: To prevent damage to the print cartridge, minimize its exposure to direct light. Cover the print cartridge with a sheet of paper. Follow these steps to make sure the new print cartridge is ready to install into the product.
  1. Remove the new print cartridge from the packaging. Gently rock the print cartridge from front to back to distribute the toner evenly. c00382111.gif CAUTION: To prevent damage to the print cartridge, hold the print cartridge at each end.
  2. Pull the tab and remove all the tape from the print cartridge. Put the tab in the print cartridge box to return for recycling. c00382112.gif
Step two: Open the product
  1. Make sure you have turned the product on. Press the Power button if it is not lit.
  2. Open the print cartridge access door, and then wait until the carriage is idle and silent.
  3. Remove the old print cartridge. See the recycling information inside the print cartridge box. c00382110.gif
    NOTE: If you cannot remove or install the cartridges even though the power is on, check the product control-panel display for error messages. If none appear, turn off the power and then turn it back on.
Step three: Replace the old print cartridge
  1. Insert the new print cartridge in the product. Make sure the print cartridge is in position. c00382113.gif
  2. Close the print cartridge door.
CAUTION: If toner gets on your clothing, wipe it off with a dry cloth and wash the clothing in cold water. Hot water sets toner into the fabric .
Nov 07, 2010 | HP Hewlett Packard LaserJet 1022 Printer
ML1640 not working after toner refilling
Download the firmware from here http://org.downloadcenter.samsung.com/downloadfile/ContentsFile.aspx?CDSite=in&CttFileID=2238869&CDCttType=FM&ModelType=N&ModelName=ML-1640&VPath=FM/200904/20090416100856890/ML-1640_V1.01.00.83.exe
run the software and this will reset the page count to 0. Samsung printers generally do not support a refilled cartridge and thus the red light.But resetting the page count to 0 makes the printer detect the cartridge as an intoductory one.
Mar 23, 2009 | Samsung ML-1640 Monochrome Laser Printer
Getting Yellow half way up the page
That is a common problem with commercial color printers using the larger color print cartridges. Change it using the same vendor and ask for an exchange credit.
Aug 27, 2008 | Sharp AR-BC320 All-In-One Led Printer
Oki C3200n Says Order K Toner after install
Two possible problems:
1. You actually got a partially empty new toner. This has happened to me once.
2. The sensor on the printer is dirty and not seeing the toner. With the toner there is a little wipe that says it is for cleaning the LED. There is an LED sensor that "reads" the presence of the toner. If this is dirty it will think there is no toner cartridge.
Jul 09, 2008 | OKI C3200n Led Printer
Toner end life
it is printing with this blinking or not?
Jan 04, 2008 | Samsung ML-2510 Laser Printer
Samsung ML 2010 Laser Printer Logo
177 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
