Question about SanDisk 32GB Class 4 microsdhc Memory Card w/SD Adapter
Remove write protection
I try to copy Documents file to this chip and the computer tell me that is write protected
  • Jose Rivero Jul 29, 2013
    I do that but still said that is write protect, this happen only when I try to copy documents and pictures from my desktop.
  • 560 Answers
Please check if the adapter is not locked as shown in the screenshot.
Posted on Jul 29, 2013
Remove write protection from my LG External HDD HXE4 3.0 500GB
Using an external hard drive is a convenient way to transport files from one computer to another or share files with a co-worker or friend.
Activating copy protection, otherwise known as write protection, on the files that you place on the external hard drive is a good idea, as it will prevent that data from being altered inadvertently when connected to another machine.
Remove copy protection from your files when the external drive unit is again attached to a trusted PC and you wish to change the structure of the files.
Connect the external drive to your computer system.
Right-click "Start" and then click "Explore."
Click the external drive on the list of available devices.
Right-click on the copy protected files that you wish to unprotect status and click "Properties."
Uncheck "Read-only."
Close the Explorer menu and proceed to edit your files as desired.
http://support.microsoft.com/kb/326549
Sep 01, 2013 | Computers & Internet
Device media is write protected
To disable writing access to USB drives and make all USB drives has only read-only access, follow these steps:
  1. Run Registry Editor (regedit).
  2. Navigate to the following registry key: HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control
  3. Create a New Key named as StorageDevicePolicies.
  4. Highlight StorageDevicePolicies, and then create a New DWORD (32-bit) Value named as WriteProtect.
  5. Double click on WriteProtect, and set its value data to 1. write-protect-usb.jpg
Once set, all users on the computer is now blocked and prevented from copying, transferring or writing any files, documents and data to the USB disk drives, without the need to restart or reboot computer. Any attempt to download or copy files to USB drive will return the following error message:
The disk is write protected.
The media is write-protected.
Remove the write protection or use another disk.
usb-removable-disk-write-protected.jpg To revert and remove the blocked write access to USB drivers, just delete the StorageDevicePolicies registry key, or delete the WriteProtect registry entry, or change the value data for WriteProtect to 0.
For user who doesn't want to manually editing the registry, simply download the following registry registration files to enable or disable the write protection (block writing attempt) to USB removable drive. Double click the .reg file unpacked from the .zip archive to merge the registry key entries.
Download DisableWriteToUSB.reg
Download EnableWriteToUSB.reg
The trick works in Windows XP SP2 and SP3, Windows Vista, Windows Server 2003 and 2008.
Feb 27, 2011 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
HOW DO I UNLOCK MICROSOFT OFFICE 2007?
1) You have reached the end of the Microsoft Office 2007 Trial.
When this happens you are not able to edit any documents. You will only be able to view and print your documents.
To fix this you need to buy an office 2007 license from http://office.microsoft.com
2) You are trying to edit a protected document.
Some people protect their documents or parts of their documents from being edited. The only way around this is to get an original copy of the file or the password for the file.
Hope this helps you
Jun 26, 2010 | Microsoft Compaq Presario C501nr Notebook
Write Protected USB
hi Not only your pendirve your computer system is also affected by virus . please check your pendrive with any other computer .before you connected open your pendrive format your pendrive with any other computer. if it will not work you have go for any new pendirve. bye
Jun 16, 2009 | Disney High School Musical Mix Stick 2.0...
My 1gb kingston pen drive is write protected
Try to right click your pen drive then copy and paste it on your My Documents folder. When done, follow these steps:
1. Go to start menu
2. Click Run and type cmd
==A command prompt shows.==
3. Type cd\
4. Type format x:
5. Press Enter key
6. When done type exit
Note: Copy all the files you have transferred on your My Documents folder and paste files again to your pen drive. You can now do whatever you want on your pen drive.
Dec 25, 2008 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
PNY Write Protected
Check and see if you can copy and paste that file from it's location and place it on the desktop. Basically seeing if you can move that file within your PC. If this is a work computer, it might have precautions built-in to write protect it's documents. If you can move the file around in your computer then it's probably a problem with your flash drive. Can you copy anything to the drive?, such as a simple text file, music, etc. I'm also assuming that you checked the properties on the drive itself to make sure it wasn't locked. You could also try another flash drive to eliminate the possiblilty of your stick being defective.
Let me know how you do.
Sep 05, 2008 | Computers & Internet
How to remove write protected memory card
when i attach the card reader with system and when i store the software or any thing in memory card then msg show that(cannot copy because write protected error)
Aug 29, 2008 | Nokia 3230
How to remove write protect on my usb flash drive
I found out that i just had to move the switch on the micro SD card from lock to unlock.
Jul 05, 2008 | Motorola Mobility i880 Cellular Phone
SanDisk 32GB Class 4 microsdhc Memory Card w/SD Adapter Logo
Top SanDisk Cameras Experts
Henry
Nikki  Mclean
Nikki Mclean
Are you a SanDisk Camera Expert? Answer questions, earn points and help others
