Question about Zenith B27A11Z 27" TV
When i put my tv on video the pitcher goes from top to bottom
What do i do is there video 2 or what
    Top Expert:
  • Zenith Master
  • 74,136 Answers
If the transmission reception is OK, and the problem only persists with external video in, the format of recording that feed to the TV from the external video source will have the fault. Try an other disc or tape.
Posted on Jul 29, 2013
The black plastic screw on bottom of the pitcher is stuck on the base. We can't seem to get it off. Have any hints
Put the pitcher in the freezer for an hour, boil water in a pan bigger than the base of the pitcher, take the pitcher out of the freezer and stick just the base in the hot water up to the top edge of the base.. Remove it after about 15 seconds and have someone with gloves on screw the base off the pitcher
Aug 20, 2015 | Blenders
I can manually turn the blades inside the glass pitcher and I can turn the piece on the top of the motor base into which the pitcher blade attachment fits.
One of the parts is not being driven properly. Either the clutch on the top of the motor is not really attached to the motor shaft OR the clutch on the bottom of the blade is not engaging with the motor clutch OR the blade clutch is not properly attached to the blade shaft. On some models if you put the rubber sealing ring in the wrong place between the beaker and the blade housing it is enough to lift the clutches apart. The rubber wing goes between the beaker and the blade housing, not between the blade housing and the blade retaining ring.
Jul 14, 2015 | Blenders
TV PITCHER GOES TO BLUE
Absence of video signal. Contact any service technician. http://electronicshelponline.blogspot.com/
Sep 06, 2014 | Televison & Video
I DON'T HAVE INSTRUCTIONS FOR A TM4 MR. COFFEE ICE TEA MAKER I BOUGHT AT A THRIFT STORE TODAY. I DO NOT KNOW HOW IT WORKS. I PRESS THE BUTTON AFTER ADDING WATER TO THE WATER LINE BUT IT CLICKS OFF...
I just got the exact IcedTea maker that you have (model TM4) from Mr. Coffee. I think that we were both trying to make it work the same way, which is wrong. The plastic pitcher goes on the bottom, while the part that plugs in with the button&indicator light goes on the top. Put water in the pitcher to the indicated water line and then pour it into the part with the metal basket. I didn't have any directional sheet either so I didn't know that the water goes in there. I thought the water would be gently warmed while in the plastic pitcher. After pouring water into the heating part, fill the pitcher with ice to indicated level (about 2 ice cube trays). Place the heating part with the button&indicator light on top of the plastic pitcher and cover it with the white lid. Push the button and it will heat the water and dispense the brewed tea into the pitcher thru a valve. The indicator light will go off when the brewing process is done. The entire manual can be downloaded from going to: http://www.mrcoffee.com/manuals/MrCoffee/tm4.pdf I hope this helps you if you still have the item. I bought mine to give my daughter while in college. I really like that it is so space saving compared to many that I am finding in stores today. Good luck and happy brewing!!! Susan
Mar 05, 2011 | Vacuums
KitchenAid Blender Model KSB560GC0. Coupling is ruined. Looks to be a geared part at the base of the unit. [ top of motor ] Also there is a part that is geared at the bottom of the pitcher, attached to...
the older glass jar blenders were sold as a complete ***'y too.
no separate parts were available. i'm sure the stainless jars are sold in the same way...complete.
Jun 24, 2010 | KitchenAid KSB5 Professional Stainless...
Pitcher has double pitcher and one is in diffrent colors .also have a line about 4" from bottom of screen.
you need new convergence chips, 2 chips stk392-110, they have to be soldered in, very common problem, you also want to t\check for burned resistors around the convergence chips.
Sep 14, 2009 | Hitachi 57F710 TV
What is the answer to puzzel 5, 18, 23, 27, 28, 36, 37, 38, 41, 112. In professor Layton and the curious village.
Puzzle 5 -- Answer is Ten Times 10
Puzzle 18 -- Move Top far Right Match to Left of the Dust-- Move Middle Match slightly Left to make the Handle.
Puzzle 23-- Empty 8 (Litre Pitcher) into 5 (L.P) Empty 5 (L.P) into
3(L.P) then empty 3 (LP) into 8 (L.P) then 5 (L.P) into
3(L.P) then 8(L.P) into 5 then 5 (L.P) into 3.(Litre P.)
Pour contents from the 3 (L.Pitcher) into 8(L.P) You
will have 4 Litres in two of the Pitchers.
Puzzle 27 -- Bickering Brothers -- Sit them clockwise from the top
as follows -- 1-- 3-- 6 -- 4 -- 2-- 5 -- .
Puzzle 28-- Find the Dot. Bottom Point on the Right.
Puzzle 36-- Only 1 as the mouse you bought was a MALE
Puzzle 37-- Brother & Sister-- They were Twins Age--- 6 (SIX)
Puzzles 38 - 41 -112-- are all quite easy, just play around you will get the Answers.
Apr 12, 2009 | Nintendo Professor Layton & the Curious...
TV Has no pitcher
you could have a shorted tube Green disconnect CRT board from green tube if set stays on tube is shorted also check video ic on crt board.
Dec 07, 2008 | JVC AV-56WP74 56" Rear Projection...
My dad gave me his Mr. Coffee Ice Tea Maker, but I have no instructions on how to use it. Can you please help?
Specifics may have changed for newer models -- we've had ours and used it happily for many years -- but the basics are simple.
(1) Fill the pitcher with water up to the "water" line and pour that water into the top of the appliance.
(2) Fill the pitcher with ice up to the "ice" line.
(3) Place a coffee filter and a family-sized tea bag into the top of the brew/steep basket and put the cover on that basket.
(4) Put the brew/steep basket on top of the pitcher.
(5) Slide the pitcher next to the appliance, such that the hot water exit port on the side of the appliance lines up with the entry port on the brew/steep basket.
(6) Press the "on" switch on the front of the appliance and wait for the tea to brew.
(7) When the brewing/steeping process is over, the appliance turns itself off.  Replace the brew/steep basket with the pitcher lid for pouring and storage.  Discard the tea bag and coffee filter, and rinse the brew/steep basket.
(8) Enjoy your tea!
Aug 17, 2008 | Hamilton Beach Iced Tea Maker
How to
Fill the pitcher with water to the water level park on the pitcher and pour into water intake in the top of the tea brewer.
Fill pitcher to ice level mark (if there isn't one, put in about 2 - 3 trays).
Make sure that the brew basket lever is closed by pushing in then down.
Put 6 - 10 regular tea bags in brew basket and place brew basket on top of pitcher.
Slide the pitcher with the brew basket under the machine where the water comes out and make sure it is snug. Turn machine on.
When the machine is done brewing, the unit will shut off automatically.
Carefully slide the pitcher away from the machine and release the lever. This will let the tea pour into the pitcher.
That's it! Just don't put the pitcher, lid or brew basket in the dishwasher - that's how I ruined my first one.
Jan 24, 2008 | Mr. Coffee Iced Tea Maker TM1S
Zenith B27A11Z 27" TV Logo
16 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
