Question about Swisher T14560 T - 60" Trailmower with 14 - 1/2 - Horsepower Briggs & Stratton I/C12 Volt Starter
Change belt model t14560 a - Swisher T14560 T - 60" Trailmower with 14 - 1/2 - Horsepower Briggs & Stratton I/C12 Volt Starter
How do you change the drive belt that runs to the motor. I can't even figure out how to get the old blet off.
first -make a diagram of the belt position
next there will be adjuster pulley/s or spring loaded pulleys to release to loosen the belt
you may have to remove cutter drive belts to assist in the replacement
get diagrams of how they are before removing them
Aug 12, 2015 | Swisher T14560 T - 60" Trailmower with 14...
What could keep it from cranking?
change solenoid. check for voltage just because it is new it might be bad
Jul 16, 2014 | Swisher T14560 T - 60" Trailmower with 14...
I NEED A PART NUMBER FOR THE MOTOR TO DECK BELT
should be able to give serial & model # to distributor or dealer to get your belt #
Aug 07, 2013 | Swisher T14560 T - 60" Trailmower with 14...
What oil to use in motor
SAE 30 is what I would recommend, but any 30 weight will do.
Sep 03, 2011 | Swisher T14560 T - 60" Trailmower with 14...
Smaller belt on my swisher pull behind mower keeps breaking
make sure it's not coming into contact with any sharp surfaces
Jun 26, 2010 | Swisher T14560 T - 60" Trailmower with 14...
Cable streched on swisher trailmower
Pull the belt cover off on the side of the engage lever and you will see that it is not a wire cable that engages the idler pulley. It's a rod connected to a long spring. Perhaps the spring came off or is defective as it puts tension on the idler pulley against the drive belt when you engage the blades. Further, there is a return spring to pull the idler pulley away from the drive belt when you disengage the blades. Check all the connections for the springs and see that the engage lever is mounted tightly. Also check the idler pulley itself.
Jun 22, 2009 | Swisher T14560 T - 60" Trailmower with 14...
Trying to find out the thickness of the V-Belts on my Swisher T14560. 1/2, 3/8, or 5/8.
They are 1/2" V-belts. The lengths are 47" and 122". I have found that the blue kevlar belts last the longest. http://www.vbelts4less.com has great prices.
Mar 30, 2009 | Swisher T14560 T - 60" Trailmower with 14...
Swisher T14560 T - 60" Trailmower with 14 - 1/2 - Horsepower Briggs & Stratton I/C12 Volt Starter Logo
19 people viewed this question
Top Swisher Garden Experts
lnbn1975
Jim Parker
Jim Parker
Tim Whalen
Are you a Swisher Garden Expert? Answer questions, earn points and help others
