Using LG 47LN5750 functions on my TiVo remote control
On my old CRT television, I was able to power on and off, mute, and adjust volume from my TiVo remote. I have a brand new LG 47LN5750, and I would like to reprogram my TiVo remote for this new TV. I tried the codes suggested by TiVo, but my TiVo is several years old and the LG 47LN5750 is brand new. Any suggestions?
    Top Expert:
  • Televison & ... Master
  • 74,887 Answers
Old codes do not work with new ones. If you wish to get new codes, check the sites linked here. http://electrohelponline.blogspot.com/ Pull up previous posts there, either by its left side bar, or view it in Mosaic / Timeslide option. Try this link too. http://electronicshelponline.blogspot.com/
Posted on Jul 29, 2013
Testimonial: "For future users, it turns out the first code, 0011 is the one. I must have entered it incorrectly the first time. Thanks to Sasi, who pointed me in the right direction :) "
MikeNJ1964
  • 398 Answers
SOURCE: Toshiba TV Remote Control not working
I have been seeing a lot of Toshiba remote "eyes" (the infra-red receiver inside the TV) fail recently. If several known good remotes cannot control the TV then the IR receiver will have to be replaced. If you have no experience soldering and unsoldering PC boards then have a qualified tech handle it for you.
Posted on Jul 10, 2007
  • 133 Answers
SOURCE: Tivo remote code for Daewoo Tv
I own a One-for-All universal remote (model URC-4220), and my booklet says the setup code for a Daewoo TV is one of the following numbers: 0092, 0451, 0672, 1661, 1278.
If these numbers do not work, I would consider buying a newer universal remote. They can be bought at Walmart, for less than 10 dollars.
Hope these suggestions help you out. Please take a moment to rate the info that I have provided, by using the rating system below. Thanks.
Posted on Jul 12, 2008
SOURCE: JVC 27" CRT TV AV-27BP3 display shows single horizontal line
I have a similar problem on my CRT computer monitor (AcerView 76c). It is an old screen and I think it is just at the end of its life, much like your TV. Having some background in physics, I would be pretty sure that the problem is with the cathode ray tube's vertical deflection system. The horizontal deflection electrodes are working while the vertical one is not. This results in a display of a single horizontal line (or in my case, a few superimposed) in the centre of the screen. Where both X and Y (horizontal and vertical) deflectors fail then the electron gun firing would result in a single bright spot in the dead-centre of the screen.
So really, we have no choice but to move on and buy a new set as repair is probably just as, if not more, expensive than replacement with a new device. Seeing as your post was in 2007, I hope you managed to solve the problem.
Best wishes,
SZ (Sydney, AUS)
Posted on Oct 05, 2008
SOURCE: tevion television
tevion uses the same codes as "Konka".. if your universal remote has codes for konka, then it should work.
Posted on Nov 01, 2008
ShadeTek
  • 79 Answers
SOURCE: Can't change our Panasonic TV channel to watch DVD input
Buy a 21 way scart.This will have an 'AV' enable connection built in. After fitting, turn on the TV, then turn on the DVD player. It will automatically enable the DVD through the scart socket.
Posted on Nov 10, 2008
I have a Lg LED tv model 47LN5750 that turns on but then stays on the LG "lifes good" screen and will not do anything more. what could be wrong?
Corrupted firmware. A firmware update is necessary. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Nov 13, 2015 | LG 47LN5750 47" LED TV 1920x1080, 120 Hz,...
LG 42LC2D-UB TIVO Remote Stopped Working
Hi Did you check the batteries,and if they're put in properly.
Make sure you have fresh batteries and not 2 different kinds. then do your codes again. Good luck.
Feb 11, 2014 | LG 42LC2D 42 in. LCD HDTV
Suddenlink tivo apex tv code
Hi- My name is Shannon and I am with Suddenlink. The SL-TiVo remote can be programmed to control the TV and one other A/V device using these steps:
1)
From TiVo Central, select Settings & Messages > Settings > Remote, CableCARD, & Devices > Remote Control.
2) Highlight Part 1: TV power, volume, and mute and press SELECT.
3) The DVR displays a list of television brands. Use the UP ARROW and DOWN ARROW buttons and the CHAN DOWN and CHAN UP buttons on the TiVo remote to highlight your TV brand and then press SELECT.
4) The TV Remote Codes screen appears. Follow the instructions on this screen to enter a code into your remote control. If the first code does not work, repeat the instructions to enter the second remote control code, and so forth, until you find a code that works. The remote is now programmed to operate the TV.
5) If also programming to control volume & mute on an A/V receiver for surround sound; Highlight Part 2: A/V volume and mute and press SELECT.
6) The DVR displays a list of audio/video receiver brands. Use the UP ARROW and DOWN ARROW buttons and the CHAN DOWN and CHAN UP buttons on the TiVo remote to highlight your receiver brand and then press SELECT.
7) The AV Remote Codes screen appears.
Follow the instructions on this screen to enter a code into your remote control. If the first code does not work, repeat the instructions to enter the second remote control code, and so forth, until you find a code that works. The remote is now programmed to operate the receiver.
The TiVo remote will now turn the TV on/off and switch inputs and adjust the volume and mute the audio on the receiver.
If you have any questions, feel free to email me at shannon-AT-suddenlink-DOT-com. Thanks!
Nov 23, 2012 | Televison & Video
Volume control
not all remotes will program for all sets and if do may not have key features wanted or needed.
Jul 17, 2012 | LG Televison & Video
Need code to use for the tivo remote
Push the TiVo button on the remote. Then push "Messages and Settings," followed by "Settings," and finally press "Remote Control." This will show you the three areas of the remote that are programmable. "TV Power, Volume and Mute," is one section. "AV Volume and Mute," is the second section. The final section is "TV Input."
Pick "TV Power, Volume, and Mute" by pushing right on the direction pad of the remote. This will open up a list of all the brand names of TV that exist. You will find most TV brands will be there.
Find your brand of television and select that option. If your brand is not there, simply go to the TiVo webpage and under "Setup and Support" you will find others who have experience this issue. There you will find a code for your TV. This happens sometimes when the TV is a lesser known brand.
Hold down the button you are programming (i.e. TV Power) for 5 seconds until the red light on top stays on. Then enter one of the codes on the screen.
Push the newly programmable button to test its functionality. If it does not work, repeat the steps with all the possible codes available. One of the codes will work.
Push "Live TV" at this point to watch television.
Use the manual which came with your TiVo in addition to this guide. In the front of the booklet will be a starter guide, which will lead you through the steps necessary to set up your remote for optimum use.
Mar 23, 2011 | Televison & Video
Remote code for a tivo remote
Ok I found it!  For the Proscan 32LB30Q from Costco, the 5-digit code for the Comcast remote is 00030, and the 4-digit code is 0030.
However, I still haven't found the code I need for the TiVo remote... but we're making progress.
Jan 31, 2009 | Proscan 32LA30Q Television
I need to program the remote from my TivoHD to operate power and volume on my Samsung LN52A850
You should be able to go to the tivo menu and push Messages and Settings, followed by Settings, and finally Remote Control. Then follow the directions on the screen. You normally would program volume and mute, power, and tv input. It will walk you through the manufacturers and give you the codes to try.
If the codes do not work, it is possible that Tivo does not have the codes for the TV yet, but I would first make sure that you have the most recent version of the Tivo operating system (force a network connection a few times).
Nov 25, 2008 | Samsung PCK5315RX TV
Vizio and the directv dvr
Vizio recommends using code 11758 or 10178 for Cable/Satellite universal remotes that use five digits such as DirecTV. For four digit Cable/Satellite universal remotes , use 1758 or 0178. For three digit Cable/Satellite universal remotes, such as Dish or Echostar, use 627. These codes typically make the Power, Volume and Mute functions work.
Jan 13, 2008 | Televison & Video
Volume and mute buttons suddenly stopped working
Try changing the batteries. Most times the "tivo" buttons will work but the "tv" buttons will stop working when the batteries are low.
If you have done that, go back into settings and program the remote again for your tv, then give it a shot.
Nov 05, 2007 | Tivo DirectTV Remote Remote Control
Televison & Video Logo
94 people viewed this question
Top Televison & Video Experts
