Question about Home
We need to oder parts for our acifex Extazia shower dooors
Need door water deflector and bottom door deflector and handles for both doors
  • 548 Answers
SOURCE: I have frameless shower doors, the bottom sill
if the glass actually contacts the tile you can go to the homedepot or similar place and buy some glass silicone sealer and just run a nice bead of caulk along the line, make sure you get clear silicone and let it thooroughly dry before you get it wet
Posted on Sep 14, 2009
mrhotandcold
  • 248 Answers
SOURCE: i have a flair shower door and the runner is
yes you can order new runner from PlumbCentra You sould always put Vaseline on runners will last for ever
Posted on Sep 18, 2009
Testimonial: "delighted with feed back. problem solved"
  • 35 Answers
SOURCE: shower diverter push handle is squirting water out
If you are handy, the best solution is to call delta and have them send you a new diverter. They will need the model of your faucet. The new diverter will come with instructions on the install process. As far as fixing it without the new diverter, I don't believe you will be able to.
Posted on Nov 18, 2009
  • 105 Answers
SOURCE: Have a sterling 1500D-42S shower door. Need to
sterling is an inexpensive kohler product,....go to a plumbing supply store with your #s and they'll be able to get what you need.
Posted on Jan 03, 2010
  • 4 Answers
SOURCE: I need a plastic pivot part for the door of my
I found a supplier in the Netherlands, www.novellini.nl.
The parts are:
De benodigde artikelnummers zijn:
1 x R02YOB2G-40 (set scharnieren t.b.v. één deur) à € 23,80 incl. btw.
De prijs van de bovenstaande set onderdelen is € 23,80 incl. btw.
Verzendkosten zijn € 7,50 incl. btw.
You can mail them by:
info@novellini.com
Posted on Mar 25, 2010
Where can i find parts for my shower door
Go to nearest home depot. They can help yo.
Oct 12, 2015 | Home
Outside dooor handle
Replacement door handles are found at a Dealer, and Salvage yard. Some auto parts stores stock a universal car/truck handle on their "Help Wall"...Your interior door panel usually needs to be removed to switch out the handle. Most are held in place with 10mm head bolts...(2) What kind of car?
Apr 03, 2014 | 2006 Ford Focus
Replace dooor handle side by side kenmore coldspot 10656833602
There is a cover on the handle. Remove with a screwdriver by gently prying...careful not to break the plastic clips. Once removed, unscrew the main handle & replace.
Dec 17, 2013 | Kenmore 18.3 cu. ft. Top Freezer...
Window regulator replacement in 1988 olds cutlass calais (non-motor). How do I replace the window regualtor?
1985-1998 Oldsmobile Grand Am/Achieva/Calais/Skylark/Somerset
REMOVAL & INSTALLATION
Door Glass and (manual) Regulator
See Figure 1
Fig. 1: Common window attachment
SEE ILLUSTRATION #1 BELOW
1. Remove the door panel.
2. Remove the water deflector from the door.
Be careful not to tear the water deflector when removing it from the door.
The "water deflector" is also known as the "dew wiper"
3. Connect the power window switch/window regulator handle.
4. Lower window to full down position.
CAUTION
Use extreme caution when operating the window with the door panel removed. The window regulator can cause severe personal injury if body parts become entangled in the mechanism.
5. Remove the window run channel.
6. Move window to the half down position.
7. Remove the window retaining nuts.
8. While holding onto the window, lower the regulator to the full down position.
9. Remove the window by sliding it towards the rear and rotating the front of the window upward.
To install:
10. Position the new window in the door.
11. While holding onto window move regulator to half up position.
12. Install the nuts. Roll the window to the full up position.
13. Install the rear run channel.
14. Install the plastic water deflector. If necessary, secure with waterproof adhesive
15. Install the door trim panel.
Window Regulator
See Figures 2 and 3
Fig. 2: Location of the front door window regulator-1995 vehicle shown
SEE ILLUSTRATION #2 BELOW
Fig. 3: Exploded view of the rear door window regulator-1995 vehicle shown.
SEE ILLUSTRATION #3 BELOW
2. Remove the plastic window deflector. Be careful not to tear the deflector when removing it from the door.
3. Remove the door window assembly.
4. Remove the bolts securing the regulator to the door.
5. Remove the nuts securing the upper regulator guide.
6. Using a 1/4 in. drill, drill out the regulator rivets.
7. If equipped with power windows, detach the electrical connector.
8. Remove the regulator through the large access hole in door.
To install.
9. Install the regulator to the door, and attach the electrical connector if equipped with power windows.
10. While holding the regulator to the inner door panel, insert the rivets, and secure them with a rivet tool.
11. Fasten the regulator bolts and upper guide nuts.
12. Install the door glass, and inside door plastic panel.
13. Install the inside door trim panel.
14. Install the plastic water deflector. If necessary, secure with waterproof adhesive.
Fig.1---------------------------------------------------------------------- Fig. 2
Fig. 3
Oct 03, 2011 | 1988 Oldsmobile Calais
Back driver door won't lock or unloc without manualy doing . 2008 chevy impala
Hello, this is caused by a bad door lock actuator. the door lock actuator is part of the door latch. the door latch will need to be replaced to correct this problem.
  • Remove the rear door outside handle. .
  • Remove the interior trim panel.
  • Remove the water deflector
    May 29, 2011 | 2008 Chevrolet Impala
    Have a two handle Sterling shower stall. The shower head is leaking from the cold water inlet. Believe need a replacement stem. Have changed the O ring but has not stopped the leaking. Is there any...
    The part # you supplied is for a shower door and has no bearing to your question. There is no relationship. However, I can say there is no adjustment for any two handle shower stem or even single handle stem. Very rarely will just replacing an "O" ring stop a drip unless it it from through the stem itself and comes out under the handle. When in doubt replace the whole stem...shortcuts will only exasperate the problem. There are no shortcuts in plumbing.
    Oct 24, 2010 | Sterling Plumbing 1500D-31S VISTA PIVOT...
    Dispenser door broke off tab on disp
    here is an individual parts breakdown list
    they also happen to have the best prices online
    you should be able to oder any of the parts you need
    and use the breakdown as a map to how to get to it
    http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5150896&diagram_id=927973#d927973
    Oct 22, 2009 | Jenn-Air JSD2695KES Side by Side...
    How to take off dooor panels
    unscrew the door handle, then starting in the bottom corner, slowly pop it off, it just simply unclips from the door
    Mar 24, 2009 | 1994 Ford Explorer Limited
    Frameless shower door sticking to the opposite wall when closing
    you can fix this problem by loostening the clamp screw and putting locktite sealer(you can purchase locktite from hd or lowes locktite is not the only product you can call a glass supplier and as for recommendation) Be sure to read the directions on the tube I use it to seal joints on refrigeration threaded parts. Make sure it will adhere to glass and metal also review the clean up solvent when you do this place a wood wedge at the bottom of the glass dooor and the threashold to support he weight until the sealer driese
    Steps
    1 Place wood wedge/block under door where non hinged side meets wall
    2 losten top hinge(inspect bottom hinge to make sure it is snug and the glass dor is all the way into the hinge
    3 You may have to remove the top hinge completely to get enough of the locktite on the metal and glass place the locktite on the hinge flat plate and the glass
    4 recheck gap where door meets wall( I sometimes use paint stirs(wood) as shims to keep space between door and wall consistent
    5 tighten top inge screws( you can put locktite on the screw threas also
    6 Clean excess locktite and wait suggested time by instructions on tube
    Good Luck!
    Dec 31, 2008 | Home
    Home Logo
    51 people viewed this question
    Top Home Experts
    john h
    Tom Chichester
    Are you a Home Expert? Answer questions, earn points and help others
