Question about Plumbing
Summer escapes pool pump
I was vaccuuming sunken algae to waste without the filter in (should have had the skimmer basket in but didn't)I sucked up a leaf and heard the tone of the pump change so I unplugged it. I picked up the water return hose to force water backwards through the pump and leaves came out. When I plugged it back in and hit the reset button a red light came on and the pump doesn't work. It is a 16' x 42" and the pump and skimmer hang on the side on the side of pool. The skimmer has SFS1000 written on the side. Did I just ruin my pump?
  • 3 Answers
SOURCE: pool pump won't prime
check for air leaks, cover o-ring is common culprit. anything in front of pump can cause this.
Posted on Jan 19, 2009
  • 104 Answers
SOURCE: leaves in the skimmer line and its plugged
Is the obstruction on hte suction side or supply side of the pump?
Either way, you can disconnect the pump, and work from there. If the pump was installed correctly there shgould be unions ( fitting that can be reconnected on the pump suction and supply. If not, you can cut the pipes a few inches from the pump and then shorten the remainder to acomodate the length of the union. Glue these in place follow the instructions on the glue can.
Try using a water hose with the water on from the direction of the pump to the pool. see if this does the job. Leaves should be able to be pulled through by the oumop, I suspect somthing larger. Do you have a strainer on the suction line? Have you checked the pool filter?
I would check the filter first. Why do you think the problem is a clogged line? How do you know the pump is performing? Does it run a Spa, and nbot the pool?
\Good Luck
Posted on Mar 19, 2009
rockitman187
  • 2559 Answers
SOURCE: Pool vaccuum
are you filling the vacuum line with water before hooking it to the skimmer?
Posted on Jul 21, 2009
  • 990 Answers
SOURCE: Once I start the pump, it takes a while for the suction to start
If the pump over heated the fittings going into it heated up and tried to expand but couldn't as they were screwed into the pump when they cooled they did shrink. They seem tight but are probally bottoming out when you screw them into the pump. Try replumbing the pump with all new pipes in and out. This should fix the problem. Make sure you kill all the alge before you try to filter it as it will clog the filter bad and could be the orignal cause of this problem.Good Luck and have fun
Posted on Aug 25, 2009
SOURCE: air in filter on hayward above ground pool.
This is common the first 30-60 seconds after turning the filter on. The filter is purging its self of the air, sometimes algae or small debris will shoot back into the pool as well.
If it is constantly getting air then replace your o-ring on the that clear cover (Strainer Cover) make sure you use a lubricant, and like djtc66 said re-wrap all threaded areas with teflon tape.
Posted on Sep 04, 2009
Sand filter not filtering! It's been 4 weeks of
Air enters from the front of the pump, usually it is just the lid o-ring (over the pump basket) that needs to be lubed or replaced.
Sand filters do not filter fine particles very well. When vacuuming it is best to set the backwash valve to the "waste" setting. This allows the debris to bypass the filter and go directly to waste. Mind that you are removing water from the pool while on that setting.
Jul 07, 2013 | Pool & Spa
"Sucking" noise
check skimmer basket
May 04, 2012 | Hayward Pool & Spa
Polaris 9300 Sport Robotic Pool Cleaner stops in water after running about 10 seconds.
Check your pool cleaners filter screen in the in-line filter system and make sure that it is clear of debris. Also check the skimmer, basket, pump basket, and pool filter to make sure that they don't have anything blocking suction. A loss of suction would definitely make the cleaner stop moving. Make sure that your hoses and connections do not have leaks that could be causing air to to escape.
Oct 10, 2011 | Polaris 3900 Sport Pool Cleaner ()
I returned from vacation and the water level was adequate b/c it had just rained a lot. I think the water may have gotten low when we were gone. Now there is not enough pressure in the pump and the...
Any air getting into the suction line of the system can cause a low flow. If too much trans is in the skimmer basket or pump basket you cna get a low flow. If junk is in the pump impeller or the filter the flow can be low. Check each of these possible problem and you will likely resolve it. I hope this helps.
Aug 12, 2011 | Jacuzzi MAGNUM FORCE POOL PUMP 2 HP...
Hi I am having trouble getting consistent power. I have taken it apart and cleaned it thouroughly only to find that the problem still remains. Any suggestions?
Try bumping the filter. You might have D.E. coated with normal accumulation of pool dirt, algae, etc. Your pool filters pump strainer or skimmer baskets could be clogged. Make sure there are no obstructions in your impeller. Finally, check the cover gasket, hand knobs, hose, clamps, etc. Replace or tighten as necessary.
Jul 03, 2010 | Hayward EC-40 DE Pool Filter with pump
Will the intex saltwater filtration system work with the summer escape?
We, like others, purchased an Intex 56633E 2500GPH Intex Pump for our Summer Escapes 18 X 52 Pool. While this is not exactly the pump you are talking about, the installation is the same. It comes with the filter, hoses, and cut-off valves. It was easy to install, with a few modifications.
For those who need assistance on getting this to work with the Summer Escapes pool, here is what we did:
1. We installed the plungers that came with the kit on the pump, before the hoses. This was done to allow us to close them, so that we can clean the filter, when needed. They install without any modifications.
2. We installed the GAME 4552 Skim Filter Pump Adaptor (Avail. On Amazon) on the bottom of the existing skimmer assy. (You can skip this, and use the existing pump, if you wish. Just remember to remove the impeller assy, as it will reduce flow.)
3. We then cut off one of the threaded ends from each supplied hoses, just below where the flat part of the hose is located..
4. Next, we put teflon tape around the bottom of the Game adapter, and also, on the existing wall output tube.
5. Using 2 clamps for each of the connections, installed cut off ends onto the game adapter, and the output tubes.
6. We re-installed the existing C filter into the skimmer, and the basket.
7. Now, the easy part. We cleared all of the air per the manufacturers instructions.
8. Turned on the pump, and, were delighted to see more water move in the pool than we have ever seen before.
Jul 01, 2010 | Intex Automatic Salt Water System for ...
Why is my filter system losing prime?
It could be one of these issues with your pool filter. Try these solutions. If none of them work, let me know and I will do some more research.
1. D.E. coated with normal accumulation of pool dirt, algae, etc.
Solution: Bump your filter.
2. Pump strainer basket or skimmer basket is clogged.
Solution: Clean
3. Pump impeller vanes clogged.
Solution: Cleaning with a stiff wire brush through the pump strainer opening will usually work. Alternate method would be to disassemble and clean.
4. Air Leak on suction side of pump.
Soultion: Check cover gasket, hand knobs, hose, clamps, etc. Replace or tighten as necessary.
5.
May 17, 2010 | Hayward EC-40 DE Pool Filter with pump
Pool vaccuum
Jul 21, 2009 | Intex Krystal Clear Model 635 Pool Filter...
Sta-Rite S7M120
The brown-green gunk sounds like algae. You stated that you have cleaned the filter. Have you taken the cartridge completely out? If not, I would suggest that you do so. Scrub the inside of the filter tank with a 4:1 bleach water mixture, only 1 part bleach. Then soak the cartridge in an acid bath, like Muriatic Acid. This will kill any algae that is in the filter itself.
You may need to vaccuum your pool to waste, get rid of some of the water and refill it. This may help get the chemicals in order.
Another idea would be to run the system continuously for a couple of days. Vaccuum to waste, not to return lines, and clean the filter when it reaches 8 to 10 PSI above start-up. You may not be running the pump long enough to properly filter water. Keep trying to get chemicals in order.
Jul 05, 2009 | Sta Rite Sta-Rite Hydro 120 ft. Filter...
My pool pump won't prime
If the pump is above the pool water level the it is unlikly that the tank will fill completely with valves open (which is ok).Most pumps are self priming and will pick up a prime with water level below suction inlet on strainer. Try starting on main drain again and slowly open skimmer line. Did you remove water from skimmer line and winterize(if in cold weather climate)during closing?.I know this sounds stupid, but make sure water level in pool is well into skimmer. If air situation remains after scspriggs' and these thoughts then prepare for a pressure test on skimmer line to determine location of leakage.
Apr 21, 2009 | Hayward 3/4hp Super Pump Inground Pool...
Plumbing Logo
77 people viewed this question
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
