Question about Dishwashers
Miele G841 Salt PC light
MY salt PC light is on. What ddoes it mean?
  • 1462 Answers
SOURCE: the salt light keeps burning
the salt light is done by a reed switch operated by a float in the salty water. float may be stuck - give softener (where you put in the salt) a tap and also stir the water inside the softener. i assume you have put in enough salt. its not a serious fault
Posted on Mar 30, 2007
SOURCE: Salt Indicator Light Flashes Permanently On Indesit IDE 750 dishwasher
I've had the same problem on my Indesit (IDL-730, IDL730) and after pouring in salt until full for ages, without the light going out, I finally decided to do the reverse.
I left it to run down the salt over a couple of months, until well empty (not ideal, but I was getting desperate!), and then finally refilled it.
Problem solved - salt error light was no longer on
All I can figure is that a blockage had set in and casued the issue. Leaving it to clear over time sorted it.
Hope this helps in your situation.
Posted on Nov 18, 2007
gwshaw71
  • 83 Answers
SOURCE: Miele G638 CS Plus - Salt PC light flashes and will not run
have you added salt to unit?If so then you have a water intake problem or unit is oversudsing.
Posted on Dec 08, 2007
SOURCE: G892-SC Miele water intake/drain light blinks
The intake/drain light blinks. How do I fix this problem?
Posted on Sep 18, 2008
news775
  • 699 Answers
SOURCE: my bosh classixx dishwasher is
Inside the machine in base there is a large screw cap.
Undo that put DISHWASHER salt in not cooking salt.
Make sure the salt well is full of water in it before you put in the salt. Fill salt to top.
Please dont forget to vote this answer was helpful
Many thanks
Posted on Feb 14, 2011
Salt reservoir
Yes. The water flows throught the reservoir regardless. The only difference is the salt indicator in the front dash will not lit.
Jul 12, 2014 | Miele 23 in. Novotronic G841 Built-In...
Why is there water in salt reservoir when bypassing or is that normal?
There is always residual water left in a brine style water softener.
How do i add salt to miele incognito?
There is a cap inside the dishwasher on the bottom right side, unscrew it and dump a full box of salt in. Clean up any spilled salt and run a rinse and hold cycle to remove any salt residue. Miele recommends using their own salt, available online at www.mieleusa.com or at a local Miele dealer. They don't recommend using water softener salt or table salt. For more help call their tech support at 800.999.1360, they are very helpful.
Mar 31, 2014 | Miele 24 in. Incognito G843SCVi Built-In...
Miele dishwaher G638 Sc,,,,Salt PC light is on?
Hi - if its flashing rapidly then there a unrecognized hardware issue -if on permanently - it could be the float switch inside the salt container is not working/jammed - of course theres no salt in the dishwasher container..
Cheers
Jul 20, 2011 | Miele 24 in. G638 Plus Free-standing...
The red light for salt (PC) is on. What does this mean as we do not have the instruction manual. Thanks
Salt Light is connected to the level of hardness of your local water supply. If your water level is very soft (below 4gr/..) then you dont need salt, but the light will stay on. Otherwise need to add salt and the light should go off (if it is working.)
Apr 16, 2011 | Miele 24 in. Incognito G843SCVi Built-In...
The salt PC light is on....what does it mean
This is just to let you know that the internal water softener needs water-softener salt.
If you do not use the softener (I do not at my house) then the light serves as a convenient on/off light.
Feb 06, 2011 | Miele Incognito G818SCVi Built-in...
The PC light on my Miele dishwasher has been on for a few weeks now, although the dishwasher seems to be functioning normaly. What does this PC light mean?
The PC light is actually where the service tech connects his laptop to test your dishwasher - it should be a PC / Salt light. The light indicates that your salt container is empty
Aug 27, 2009 | Dishwashers
Salt PC indicator light
I downloaded the manual off line and it gave me the facts I needed.
Thank you,
Markus
Sep 08, 2008 | Miele 24 in. G638 Plus Free-standing...
Miele dishwasher film and crust on the inside-
Hard water has this "crust" which are minerals floating around that ionically attach to everything. Some machines from Miele have a water softener inside the machine. Special dishwasher softener Salt is added that cleans minerals off Xeolite beads. When cleaned they attract mineral ions. If you don't use the salt then the beads fill up on minerals until they can't hold any more minerals. The salt is used in the regeneration cycle. It washes the mineral ions off the xeloite replacing them with salt ions. As new water enters the machine mineral ions slowly knock off the salt ions and attach themselves to the beads again. This whole process keeps the crust off the dishes and the walls of the machine.
Use a dishwasher cleaner that removes scale. And if you don't have a salt light on your Miele you can instead purchase soap tablets that contain water softener built in. Miele dishwasher tablets have it. You can order them online or call Miele.
Dec 17, 2007 | Miele 23 in. Novotronic G841 Built-In...
Dishwashers Logo
35 people viewed this question
Top Dishwashers Experts
