Question about Radio Communications
How do i operate an M1300 bluetooth manuel HM1300
Mercedes vito radio
check owners manuel in regards to bluetooth concerns and operation also here are several places to check out good luck!
Dec 06, 2013 | Vehicle Parts & Accessories
Je neut installer mon bluetooth
Beaucoup de p?riph?riques Bluetooth livr?s avec des manuels d'installation. V?rifiez aupr?s de v?tre. Voici un lien ? le manuel de votre t?l?phone:
http://www.lg.com/fr/support/product/support-product-profile-mobile-redux.jsp?customerModelCode=KE970&initialTab=documents
Bonne chance!
Mar 03, 2011 | LG Shine KE970 Cellular Phone
Gateway M1300 tablet pc will not charge in the
Question 1: Will the tablet operate on the docking station (or power cord) without the battery in place?
If not, the power circuit on the tablet motherboard is broken.
Question 2: If you plug in the power cord into the tablet, is the connection "loose"?
Check the other tablet to see if it is the same loosness at the tablet power connector.
If it is loose, the power receptical in the tablet can be soldered back onto the motherboard.
Recommend taking it into a shop to re-solder.
If under warranty, get it repaired.
If not under warranty, your choice if you want to use it they way it is.
Hope this helps...
Sep 03, 2009 | Gateway m1300-3004372 Tablet PC
How to use / user manuel info
The HBS110 is a bluetooth headset. To pair it with your phone, first turn on the headset. Then turn on bluetooth in your phone and search for bluetooth device. When your headset is detected, just select it and follow onscreen instructions to pair it with your phone.
Hope that helps,
Sai.
Mar 16, 2009 | LG HBS-110 Wireless Headset
Connecting to my cell phone
get the blutooth in paring mode by pressing and holding the large button till it is solid blue. once that is ready go to your phone and click on menu button, then settings, then connection, then bluetooth, then once you turn on the bluetooth click "find devices" it shoudl find the samsung headset and then you put in the password "00000000"
May 31, 2008 | Cell Phones
Upgrading a Gateway M1200 to a M1300...
You can replace any motherboard, so long as your processor and memory are compatable and it fits into your case.
Mar 02, 2007 | Gateway M1200-3004265 Tablet PC
Radio Communications Logo
37 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
