Question about Maytag Bravos MGDB850WB 7.3 Cu. Ft. Gas Dryer - Black
Electrical on but dryer does not start
Control panel warped from dryer heat 8 months ago. Dryer cintinued to work until now. All of a sudden it won't start when the start button is pushed. Electrical components all light up but motor doesn't seem to to turn on
  • Dixie Jul 29, 2013
    It's a GAS dryer. What I meant was all the control panel lights, drum light and "bells" come on. When I push the start button, nothing happens. Motor doesn't start so of course drum isn't turning either. The control panel cover is plastic, which I didn't know until it was damaged. Service tech from extended warranty denied the claim, said it came from abuse (?). This was the second time it did this. Worse is I can't even find the replacement part, technician didn't leave a number with my daughter when he left and all I can find is the internal component of the control panel. I'm afraid to buy it ( pretty expensive) just to find out that it is something else :-(
    Problem Solver:
  • 11 Answers
Sounds silly, but because it's an electric dryer, it's run on a 220 line. Double check your breaker box to make sure both breakers are in the correct position. If only one breaker is in the correct position, you'll have electrical power, but the drum won't spin.
Posted on Jul 29, 2013
  • 409 Answers
SOURCE: Maytag Epic dryer won't start
hi there,
if it beeps it means that the keypad is sending a signal to the control board to start it but it doesn't. since the control board sends a signal to the motor to start the dryer to spin. does the dryer hum?
Posted on Dec 17, 2008
  • 289 Answers
SOURCE: my maytag neptune electric dryer will not work the
first check that you have 240 coming to unit.than let me know.
Posted on Nov 21, 2009
  • 1218 Answers
SOURCE: Maytag Dryer won't start withouth me turning the drum.
Good day. Ugly problem.
My first choice would have been the motor, but.......
Here is the process, it might help you.
The power to the motor goes first to and thru the door switch. It then returns to the timer.
When the timer is turned to any running position, power leaves the timer where it is split into 2 leads.
One of the power leads goes directly to the centrifugal switch Which is the switch on the motor with all the wires. If you spin the drum, you also spin the motor, and if spun fast enough will close the contacts on the cetrifugal switch, thus sending power to the motor, allowing it to run. I guess you have done that.
The second lead out of the timer goes to the push to start switch, it then leaves and goes to the centrifugal switch but on the power side, so it is directly connected to the main winding in the motor.
That is why when you press the press to start switch, the motor runs, and if held in it will continue to run.
In fact, at this point, the motor had 2 sources of power, either of which can run the motor.
Thus releasing the push to start switch doesn't matter, since it runs off the other source.
Possibilities.
The centrifugal switch is not wired right. Please recheck. (or the motor was bad out of the box. Happens).
The push to start switch is bad, and needs replaced.
Or, the wiring going to or leaving the push to start switch has broken or making a bad connection.
Lastley, I said the power comes out of the timer and splits into 2 circuits. Not always true, in some models the timer sends 2 seperate wires out carrying the power, with the possibility the timer could be bad.
Hope this helps.
and thank for using FixYa
Posted on Jan 07, 2010
Testimonial: "Jack was a great help. Really took the time to help me with my problem in depth. Thanks again."
  • 10865 Answers
SOURCE: I have a Maytag MED9600SQ0 electric dryer that
Hello. There are only 4 possible problem areas to check when it will not start:
Power from the house Check to see whether there's power getting to the dryer. Is it plugged in? If you plug something else into the outlet, does it work? If not, check for a blown fuse or tripped circuit breaker. Door switch If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. Thermal fuse On many dryers, there's a thermal fuse (a heat-sensitive fuse that blows if the dryer overheats) mounted to the exhaust duct inside the back cover panel. The fuse is about an inch long. It's usually embedded in black resin and mounted in a white plastic housing.
If the fuse has blown, it has no continuity. When this happens, your dryer either just stops heating, or it doesn't work at all. Be sure to inspect the venting/heating system before replacing the fuse to put the dryer back into operation. (You can't re-set this type of fuse.)
Wiring Often the main wiring connection from the house, at the dryer, burns and the connection breaks. In this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the wire is attached.
Posted on Aug 16, 2010
heatman101
  • 43501 Answers
SOURCE: when we push the button
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on May 20, 2011
GEW9200 electric dryer turns fine but won't heat up. I tested the thermal fuse, thermostat, heating coil and they are fine. What am I missing?
If you have 240 VAC to the dryer, the control likely has a faulty relay for the heater. Provided all the thermal fuses (especially the one on the side of the element can) are good and the voltage supply is good, the control will likely need to be replaced and is available below.
Control
Nov 24, 2013 | Kenmore Elite HE4 Electric Dryer
My dryer won't start!
the battery in your dryer is actually not working very well. I suggest you to change it because when the electronics pass the 2 years they start not working very well. Hope this helped you.
Feb 25, 2008 | Kenmore Elite HE4 Electric Dryer
Dryer does not start. It is model LER7646EQ1. I replaced the heating coil about a month ago. In the past few days, when the dryer was running, the control panel seemed to get quite hot. The dryer even...
This sounds like several faults rather than one, but the likely original cause is the thermostat. Thermostats most often fail in the closed (on) position which would mean that the element was always on, rather than switching on and off when your dryer reached the correct temperature. This would explain why the control panel seemed hot.
This also explains why the dryer was stopping during the cycle. Your dryer is fitted with a thermal-fuse which trips and cuts power when the dryer gets too hot. However, a faulty thermostat doesn't usually stop the dryer running. A broken thermal fuse usually will.
From your description, I'd say you are definitely going to need a new thermostat, but I doubt if that's the only part you're going to need. You may well need a new thermal fuse and as the control panel got hot, this could have been damaged also.
I wouldn't buy any parts until you've inspected the control panel. You really need a service manual . but they are not usually available free. Failing that you're going to need some test equipment (Voltage & Ohm meters) to find the problem but if you don't know how to use them, it's definitely time to get an engineer.
I wouldn't advise buying any parts until you've investigated thoroughly - unless you can get them cheaply and return them if they aren't needed.
Oct 18, 2010 | Whirlpool LER7646E Dryer
Our Maytag Intellidry PYE4558AYW dryer will not turn on
Check the door interlock switch. If it is defective, the machine will not start. If no help, then there may be trouble in the control panel.
Jan 02, 2010 | Maytag PYE2300AY Electric Dryer
Put clothes in, set the timer, push the start button and it makes a hum like it is trying to start but does not start and then there is a funny smell coming from the dryer. Is the motor burning/burned up...
it could be the belt slipping,the motor going bad, the motor start cap going out the drum bearing or motor bearings dried out causing over heating of unit causing electrical smell, hard to give a ball-park,anywhere from $50 to $300 for repairs depending parts required and labor/time
Oct 28, 2009 | Amana DLE330RAW Electric Dryer
Kenmore dryer makes no heat
replace the heating element. Or the control panel has weakening capacitor not sending correct current flow to the heating element
Jul 09, 2009 | Dryers
Hotpont/Zanussi Electric dryer TC7102W no timed heat
it seems thatyour getting no heat on the permanent press and gentle cycles correct? if we know the heater is working that takes care of a number of possible causes turn the power off and remove the rear panel of the dryer. you will see a couple of thermo disks mounted on the heater box.you probably will find tons of lint on these thermostats and what happens is you turn your dryer on low heat or automatic cycle where the dryer will run until it senses the clothes have no more humidity inside the drum every time the thermostat shuts off the heater the dial moves a little closer to the off position. if there is a build up of lint around these sensers the dryer will heat up until the sensers turn the heat off. what happens now is the thermostats are nice and warm as the lint buildup iacts like an insulator preventing the thermostat from calling for more heat so it will take forever to dry a load of clothes. brush the lint off the thermostats and while you are at it vacuum the back of the dryer there should be a lot of lint there
Jan 23, 2009 | Zanussi TC7102W Electric Dryer
Brand new Kenmore Front load won't work
It sounds like the plug is mis-wired. The panel works off of 110v but the rest is 220v. If one line is swapped with the ground you will get 110 only.
Jun 02, 2007 | Kenmore 85871 Electric Dryer
Maytag Bravos MGDB850WB 7.3 Cu. Ft. Gas Dryer - Black Logo
283 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
