Question about Refrigerators
Norcold mrft60 We have a MRFT60. It runs for five minutes and then shuts off. It does not cool.
5 Suggested Answers
  • 4 Answers
SOURCE: dryer gets hot and shuts off after five minutes,
Check your vent tube to make sure it is clear. It is probably getting to hot because there is no ventilation to the outside. When you have the front off, check all the way from the lint filter to the outsid of the house.
Posted on Apr 19, 2009
leecom72
  • 4806 Answers
SOURCE: My Gateway laptop shuts off after five minutes. I
Hi there.
There is probably dust trapped in the air vents and around the CPU fan, the best way to clear it is to turn the machine off, get a can of compressed air and give short blast through the air vents.
The CPU fan is usually located under the laptop and give a couple of blasts through that too.
Once your happy that all the dust is removed you can turn the laptop on again and it should stay on for much longer.
The cooling pad won't make any difference if the issue is dust.
Good luck and thanks for choosing FixYa!!
Posted on Jun 05, 2009
subikid90
  • 180 Answers
SOURCE: electric cooling fan on ford five hundred not
Check the fuse for the fan and you could test to see if you have a voltage running to the fan when the car starts to overheat. If you have no power to the fan then trace the wore and see if you cant find the problem. If you have power then the fan motor is most likely bad.
Posted on Mar 03, 2010
SOURCE: 2004chevymalibu2.2litre . Will sometimes shut off when it cools down for five minutes will start and run fine .
Hi Joe, I'm Al the owner of Big As Auto Repair
Joe, this is a hard one to help you with because without diagnosing what it shutting down the we are basically guessing. I want promise anything but I'll surely give it a try. The biggest problem with a hot dyeing problem and then it restarts OK when cold is that this is most of the time a loose connection or something going bad. If in fact it could be a loose connection it could be anywhere. Here's what happens, when it gets hot the wire if its a wire will pulls apart and lose contact and when it cools down it will retract and make contact again. Here is something to try. Start the engine and tap on the engine controller and see if the engine dyes. If it does then first check all the connectors and wires before condemning the controller. If nothing happens at the controller perform a wiring wiggle test and see if it dyes. If in fact it does dye in a certain area then pull the wires apart in that area and also check the connectors that close to that area. NOW, if nothing happens with the wiring and controller then you could possibly have a fuel pump that's getting hot a shutting down. You'll need to check this with a fuel gauge to see if the fuel is shutting off. For further assistance go to my website. Have an awesome day Joe. Auto Repair
Posted on Feb 15, 2015
Norcold n510ul. Why doesn't it refrigerate in any mode?
it possibly needs recharged with freon and sad to say that can only be done by a certified serviceman
Aug 25, 2015 | Refrigerators
It will run good for a while on hot heat and then shuts off for abut 5 mins but it doent shut off on cold cyc
why does my roper electric dryer shut off after five or ten minutes of running fine. then wait five or ten minutes, restart and it runs fine for another five or ten minutes, and so on....
Dec 29, 2012 | Roper REX4634KQ Electric Dryer
Trane xe1200 compressor fan motor only runs for about five minutes
Than it's not wired correctly. Did you splice the motor wires? Black on left, common to cap which should be the right from contactor and fan which I think, without looking, is brown. purple common...
Jan 17, 2018 | Heating & Cooling
My compressor runs for 3 seconds - then shuts down for 3 minutes - then runs for 3 seconds
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Mar 21, 2011 | Thetford NorcoldĀ® Model DE0061
I have a Norcold 611 and the freezer works fine, but the refridgerator wont get cold. Any answers?
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Aug 25, 2010 | Thetford Norcold RV Cooler/Freezer
The car runs great but when I shut off the engine the fan continues to run. How can I get it to shut off?
The fan is controlled by a thermostat, it will (should) shut off by itself after a few minutes, after the engine has cooled down a bit.
If it continues to run after about ten or fifteen minutes (i.e., it does not shut off at all, and will run the battery down if you leave it overnight), then most likely the fan relay is sticking on, and should be replaced. Less likely is that the fan thermostat is bad.
But if it turns off by itself after about five minutes, this is normal and desirable, it gets some of the excess heat out of the engine.
Aug 23, 2010 | Jeep Cherokee Cars & Trucks
Dryer gets hot and shuts off after five minutes,
Mar 23, 2009 | Frigidaire FEQ332E Electric Dryer
Refer Norcold DE 0051 not getting cold
Your cooling unit is shot, I suggest. Most likely, you've lost the R341 refrigerant. Norcold, so they can sell you another cooling unit at $500+, does not make these little fridges with a service port so you can recharge the system. Same with Dometic. Solution is to spend, again, $500+ for a new sealed unit that will fail in relatively short order (I'm on my second in five years) or buy a better refrigerator. I'm opting for a new fridge this go around (Vitrifrigo). Vitrifrigo has the needed service port.
Dec 28, 2007 | Thetford Norcold DE0051 Refrigerator
Refrigerators Logo
14 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
