Question about Vehicle Parts & Accessories
Not getting fuel in my 2002 jaguar x-type - Vehicle Parts & Accessories
That tells us nothing
You have a fuel pressure gauge on the motor?
You looked at scan tool data?
Don't hear the fuel pump run?
Car drives a few days then quits & starts
up again okey?
What are we guess at here!!
What has been done to bring about the question?
Posted on Jul 28, 2013
  • eric Jul 29, 2013
    The car has been garaged seince 2008 I put a new battery in it fresh gas cranked it over and didn't start sprayed it with eather it fired I push the valve on the fuel rail and its dry I pulled the back seat out and found the wires and the moudule
  • eric Jul 29, 2013
    Red wire has power and yellow has power when keys on then loses it when u crank it over scan tool says low fuel temp
Clean fuel sensors
https://www.youtube.com/results?search_query=t+2002+Jaguar+X-Type++Clean+fuel+sensors 2002 Jaguar Type Clean fuel sensors YouTube
Sep 16, 2014 | 2002 Jaguar X-Type
Location of the fuel pump relay on a 2002 jaguar xtype 3.0
No FPR fitted.
Works via fuel pump module.
Module powered from fuse 81 on diagram of fascia fuse box. This fuse gets its feed from the ignition relay.
dae5bb3c-0053-4ad2-8bb0-945413126f57.jpg a02d94cb-80b8-4f3a-8548-93247d9e0aa9.jpg
Mar 14, 2014 | 2002 Jaguar X-TYPE 3.0L
HOW DO YOU GET TO THE FUEL PUMP ON 2002 JAGUAR X TYPE
check truck for access area, or remove fuel tank
Mar 15, 2012 | 2002 Jaguar X-Type
No fuel entering fuel filter 2002 jaguar
It sounds like you may have a defective electric fuel pump, it is located inside the gas tank.
Jan 24, 2012 | 2002 Jaguar X-Type
2002 jaguar x type 3.0 not geting fuel,jumped car,crossed leads by accident,did this cause it? checked fuses all seem ok STARTS ON STARTING FLUID
CHECK IGNITION AND PCM FUSE.YOU COULD HAVE SHORT OUT PCM. IT CONTROL FUEL PUMP. CHECK FUEL PUMP RELAY.SCAN VECHICLE FOR PCM FAULT TO KEEP FROM SPENDING A WHOLE LOT OF MONEY.
Nov 13, 2010 | 2002 Jaguar X-Type
Where is the fuel filter located?
For 2002 Jaguar S-Type 4.0L SFI DOHC 8cyl the Fuel Filter is located under vehicle, driver side, below engine area, rear of wheelwell, mounted in fuel line.
Hope helps.
Aug 05, 2010 | 2002 Jaguar S-Type
Jaguar x type is not getting fire to it. Need to know how many components in the fuel system
CHECK IF THE FUEL FILTER IS BLOCKED UNDER THE BODY NEAR THE EXHAUST
Apr 30, 2010 | 2002 Jaguar X-Type
No pickup on hills- just replaced fuel pump, gas filter, but sluggish - jaguar 2003 x-type 2.5L
you might also need to get a good fuel injector cleaner and put it in the gas tank...it will clean it alright.
change the air filter..too...
when was your cars last tune up?
May 13, 2009 | 2002 Jaguar X-Type
How to remove fuel pump from tank s type jag 2002
Fuel pump is accessed through a hole below the back seat. Remove the seat and there is a rubber round cover over each fuel pump. Fuel pumps are held in place with a large round retaining ring that is screwed off.
Dec 01, 2008 | 2002 Jaguar S-Type
Fuel pump relay 2002 Jaguar x-type 2.5
in the mass fuse box, under the dash, unless you have the manual you will not beable to tell wich one it is.. get a chiltons repair manual or a haynes...
Sep 21, 2008 | 2004 Jaguar X-Type
Vehicle Parts & Accessories Logo
50 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
