Question about Vacuums
My Hoover Duros (blue color, S3000 something model with the power brush) worked fine for 3 years, than it died. The other day I couldn't turn it on... What can it be? A fuse? Where's is the fist in this model?
  • Vacuums Master
  • 18,424 Answers
Manual > http://hoover.com/file/682/
To reset the breaker:
(1) Push the ON/OFF switch
http://hoover.com/file/682/completely
down. You will feel some
resistance when the switch moves
downward. The switch will also move
slightly upward on its own.
(2) Wait one minute.
(3) Repeat step 1.
(4) Turn the cleaner ON and continue
cleaning.
If the brushes continue to stall and
the breaker trips again, clean the
brushes to remove debris. (Figs. 4-1
through 4-4)
To reset the breaker:(1) Push the ON/OFF switch
completely
down. You will feel someresistance when the switch movesdownward. The switch will also moveslightly upward on its own.(2) Wait one minute.(3) Repeat step 1.(4) Turn the cleaner ON and continuecleaning.If the brushes continue to stall andthe breaker trips again, clean thebrushes to remove debris. (Figs. 4-1through 4-4)
Posted on Jul 29, 2013
  • 126 Answers
SOURCE: Hoover WindTunnel Canister: Roller brush motor not turning
These motors have a fuse incorporated in the field winding and it sounds like that blew. These motors sometimes overheat at the front bearing and the bearing will melt into the plastic housing. This will cause the fuse to blow. It sounds like that's your problem. You can remove the motor by removing the three screws on the bottom of the powerhead and then check the front bearing for any bubbling or blistering in the plastic housing. The shaft of the motor should turn easily.
Posted on Jan 27, 2008
SOURCE: Hoover Vacuum
Our Hoover upright vacuum cleaner makes a very loud noise when it is running. What causes this?
Posted on Feb 13, 2008
  • 294 Answers
SOURCE: Hoover Steam Vac - Brushes not turned, no suction power
The Brushes not spinning is most likely is caused by seized bearings in the turbine, requiring shop service (easy fix). The suction issue can be caused by the standpipe seal missing or lower recovery tank not on properly, on some models missing front panel. I would need more exact model info to assist further.
Posted on Mar 15, 2009
  • 3 Answers
SOURCE: brushes don't work on my hoover steam vac v2
The bearing on the inside of the turbine is rusted. You will have to take the hood of the unit and unscrew the black piece that has to rub hoses going to it. Then take apart the black turbine. Inside you will find 2 white gears and a small 1/2inch bearing. Use wd40 to uncease the bearing. After this put the take pliers and make sure the metal post will turn. Spray wd40 on everything you see including Hoover for making such ****. After this put put everything back together. Now the best thing to do is get some automotive bearing grease and put a large amount on bearing and and other metal parts. Put everthing back together. Clean any hair off the brushes and you are ready. Now the bad news if your gears are worn you will have to replace the turbine. Go to an internet website and the part number will be 91001019. I know all this because I spent 6 years working for Hoover and they found it cheaper to send our jobs overseas.
Posted on Apr 30, 2009
SOURCE: hoover stean vac dual with 5 brushes
I think this is the same unit I have, I might have a couple of solutions. No, there is not a belt that turns the brushes and there is not a fuse.
First of all, make sure the brushes have been clicked into the machine properly. The entire plastic housing unit for the brushes can be removed by pulling on the casing gently. It should pop out. Make sure the pegs and clips line up with the holes in the machine when reattaching the brushes. You should hear it click when they are on properly.
If the brushes are attached properly and they still won't spin here is another possible solution. This happened to mine.
The plastic pegs on the housing unit for the brushes might have been stripped out. The pegs are supposed to be squared tip to click into the square hole of the machine. If the pegs aren't the same shape as the hole, the machine can't grab them to spin the brushes.
The tallest peg on mine somehow got stripped to a rounded shape. I tried wrapping tape, plastic, etc around the peg to make it fit in the hole snug, but it only worked for a few seconds and broke again. I am going to have to replace the brush set. You can order parts from Hoover but I haven't priced them yet.
I hope this helps you.
Posted on Aug 30, 2009
Hoover duros 3590
dont no wot you wont but here is the manual > http://hoover.com/file/396/
Nov 25, 2012 | Maytag Hoover Duros S3590 Vacuum...
Hoover duros no suction
you must see any clogged from Hose, or nozzles, and clean, or repair.
Will be a good idea tha yur use user manual, or download from the Hoover.com and proceed according.
God bless you
May 27, 2012 | Maytag Hoover Duros S3590 Vacuum...
The powerhead on my Hoover Duros will not keep running. If I push the on/off switch it will come back on sometimes, other times when I push it it turns the whole thing off as its supposed to do.
I just had the same problem with my hoover duros, the vacuum was running fine but the powerhead kept going off. I would make a sweep with it and powerhead would be running and then next sweep powerhead would shut off. I had tried checking connection and belt, etc. I thought it was the powerhead. But then I found the problem. On the duros there are 2 pieces of wands that hook powerhead to hose on canister. They both connected and clicked in fine but I decided to check them separately. I hooked just one piece to hose and powerhead and then turned it on and then I did the other piece. ta-dah! that's what it was...it was only one section of the wand. When I hooked them up separately, one piece the powerhead worked totally fine and vacuumed like normal. When I removed that piece of wand and tried the second piece (actually the bottom section when both are hooked together) the powerhead did not work at all. So I just need to get a new section of wand. Hope this helps!
Nov 17, 2011 | Maytag Hoover Duros S3590 Vacuum...
I don't know how to change the bag for the machine, bag # SR 401010. Vaccum is Maytag Legacy series. Is there a diagram or picture to show how to replace the bag. Thanks
http://www.hoover.com/CustomerService/Manuals/Default.aspx Enter your model number on Hoover's website to view or print a manual. I suspect that you may have accidentally discarded the bag frame ( part # 93001544 ), which holds the bag in position.
May 21, 2011 | Maytag Hoover Duros S3590 Vacuum...
MY WIFE BOUGHT THIS FOR ME FOR FATHERS DAY GIFT ABOUT ALMOST 2 YEARS NOW OR SO,BUT I HAVE THIS PROBLEM THAT THE BRUSH DOS'NT SPIN ANYMORE EVERYTIME I PUT THE SWITCH ON FOR BRUSH ON,THE HOSES BRUSH SPIN IS...
This unit uses a turbine assy to turn the brushes. The brushes could have something jamming them. Remove the brush unit, it is held on 2 spring hooks 1 on each side. The brush unit is driven thru a 1/4" square post, only one brush is driven and it drives the next then it drives the next etc. If something is jammed in these gears it will stop the entire brush assy. The turbine assy could be bad, but I would check the brush assy first.
Nov 10, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
Hoover Vacuum
Jun 28, 2006 | Hoover S3614 Vacuum
Vacuums Logo
71 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
