Question about Whirlpool ED5VHGXM Side by Side Refrigerator
Whirlpool regrigerator door auto locks
The refrigerator door on my Whirlpool side-by-side refrigerator/freezer keeps auto-locking. If I wait a few minutes it unlocks. Can anyone tell me why this happens?
    Problem Solver:
  • 11 Answers
As far as I'm aware, refrigerator doors don't have auto locks on them. What you're describing sounds like the door has a fantastic seal from a temperature change between the inside of the fridge and the room around it. When there is a drastic change, (usually warm) the refrigerator seal will seem to stick. This will wear off over time, or when the temperature changes.
Posted on Jul 29, 2013
peyton32034
  • 410 Answers
SOURCE: WHIRLPOOL GS6SHEXNL00 SIDE BY SIDE REFRIGERATOR LIGHT
funny you asked this question i just had this same problem this week at a customers home. you need the electronic control board located in the compressor compartment behind the refrig. it is mounted in the white box on the left hand rear corner. the whirlpool part number is 2304095 and it is around 175.00 i'm not sure who a local part supplier around you would be if all else fails you could get thru sears..
Posted on Jan 07, 2008
  • 27 Answers
SOURCE: WHIRLPOOL CONTROL PANEL
Hi. Your temperature control board display is bad. You may also have a power convertor board located next to the compressor. Normally you would replace the temperature control board first. I have a temperature control board listed on Ebay as item number 250211412492. Good luck, Mack
Posted on Feb 02, 2008
peyton32034
  • 410 Answers
SOURCE: Whirlpool GD5RHAXNT00 Side By Side Refrigerator
your  problem on this is the main control in the compressor compartment. unplug your refrig then remove this control unplug all connectors and reconnect. this will probably get you working temporarily In almost every case I've seen we ended up replacing the control board. thx peyton
Posted on Feb 07, 2009
SOURCE: Whirlpool Refrigerator Door Seal surface is HOT.
If the air flow on the condenser under the fridge is too low, the hot gas won't be cooled enough before it goes to the door jamb to stop condensation. Remove the plastic cover under the doors and look at the condenser (tube/wire thing underneath). If it is clogged with fluff, get a vacuum and nozzle and give it a good clean so the air can pass through. Other than that, your condenser fan may have stopped.
Posted on Mar 27, 2009
SOURCE: Whirlpool American Fridge Freezer Clicking noise
my whirlpool amerian side by side it has got warning sign on with a ! at it has stop frezzing
Posted on Apr 19, 2010
Testimonial: "Thanks very much for your help, really appreciate it "
Somehow the freezer door became locked and I can't figure out how to unlock it.
There is no lock on your refrigerator for either door. The lock/unlock button is only for the dispenser to keep small children from dispensing ice or water. If your door won't open it could be a few things. First, a package on one of the shelves dropped and is jamming the door on the inside. May require removal of the top hinge so you can tilt the door top forward and look inside to see what happened. Next, you may have one of the door hinges that actually broke and is keeping the door from opening. You will need to look close at both hinges but I would guess the bottom hinge would cause this more that the top since the door weight is all on the bottom hinge. The only thing that holds the doors closed is a magnetic gasket on most side by side models under normal conditions.
Mar 30, 2015 | Whirlpool Refrigerators
Whirlpool 6th sense fridge freezer electronic panel - how do i unlock? child lock not on
Emma:
The lock and unlock feature is accomplished by holding the lock button for 3 seconds, and you will see a count down number just above it that indicates 3, then 2, then 1, and a soft tone along with the lock icon appears. To reverse this hold the same button for 3 seconds following the same procedure and the unlock icon will appear.
Jul 14, 2014 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool American side by side fridge/freezer is making a clicking noise. Sometimes it lasts a few minutes and other times it can last over an hour. If I open the doors its stops and as soon as I close...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jul 17, 2011 | Whirlpool ED2FHEXN Side by Side...
The refrigerator is not cooling enough.
You will need remove the screws in the back of the freezer section, check to see if the little fan is turning, if not you will have to replace the fan motor, this is what circulates the air and keep the fresh food side cool.
Nov 25, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool
How to check stuff>
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
. Cut everything off for a few minutes then turn it back on and listen for a click from the compressor relay as the compressor tries to start.
Is the compressor motor running.If no check starter/overload relay.
Oct 03, 2009 | Whirlpool 25.3 Cu. Ft. Frost-Free...
Sounds like an alarm going off
Have you tried to unplug the unit...wait a few minutes and plug it back in?
Apr 23, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Refrigerator side is freezing contents
First, I think it’s important to know that the Ref side has no cooling coils, it’s basically a box and the cold air in the freezer is blown over by a fan through a channel into the Ref side. This channel has a door which regulates how much cold air goes through. You probably have two control knobs in the Ref side, one controls the temp with numbers 1-9, 9 being the coldest. This temp control tells the compressor how long to run. The other control is for that little door and it may have letters A-E, E being the coldest. If you set it on E (coldest) then this will close that little door and keep most the cold air in the freezer.
If your settings are right then the cold control switch is the problem
Dec 16, 2008 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool side by side fridge freezer alarm keeps bleeping and freezer has defrosted
whirlpool side by side fridge freezer alarm keeps bleeping and freezer has defrosted. the temp display on freezer shows - - flashing
May 16, 2008 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool ED5VHGXM Side by Side Refrigerator Logo
69 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
