Question about West Bend 77203 Electric Can Opener, Metallic
How can I repair a defective cutting lever?
Bottom line is: this can opener must be defective because it doesn't work at all. There is very little up-and-down movement in the piercing lever and neither my husband nor I can get the cutting blade to pierce the lid of any type of can. Once when we were attempting to figure out what was wrong, we were able to cut off the bottom of an empty tuna can, but nothing since then. Since I don't often need a can opener, I made the mistake of not using it right away, and now the return period has expired, so I can't do anything except throw the thing in the trash....basically a brand-new item and those dollars down the drain. I know some people are very happy with this product, so I believe I must have a defective unit. There is no troubleshooting guide in the manual. So, word to the wise: Use your product right away to make sure it works and keeps on working! I'm going back to the manual can opener. If anyone has suggestions for getting it to work, I'll hang onto it for a few weeks, but I'm not optimistic.
3 Suggested Answers
greenspan
  • 1734 Answers
SOURCE: West Bend Quik Serve Toaster--bread slides through
Ask them for the manual.
Posted on Aug 02, 2009
  • 1739 Answers
SOURCE: I didn't get a manuel and the toast does not go
The Instruction Manual for your West Bend 78224 QuickServe Toaster is available here:
http://www.westbend.com/supportdata/L5670-QuikServeToaster-ALL.pdf
Uneven or ragged edges on your toast can catch on the toast rack and prevent it from siding through on to the serving tray. Trim off any ragged edges.
Thank you for using FixYa!
Posted on Sep 16, 2011
GE washer WCVH6800J1WW - fabric softener doesn't empty
see the causes and remedies:
It spins, but doesn't pump
drain lines clogged, repair+sock in outer tub port, if the lines is not clogge the problem is pump replace
It doesn't spin or pump
frozen pulley pump, replace
It pumps, but the water returns improve the draininin laundry, if have reaches 4 inches cut off the excess. if is lower install air/gap siphon break assembly.
God bless you
Jul 18, 2012 | Washing Machines
I can hear the hot watre dripping into the washing machine when it is turned off
see this cause:
drain line clogged, +remove some sock with pliers maybe you can remove the agitator+pumps propeller defective.
frozen pulley pump, replace the pump
improve the drain line+if the drain line reach more 4 inches, cut of the excess. if is lower,install air/gap siphon break assembly.
God bless you
Jul 03, 2012 | Fisher and Paykel GWL11 Top Load Washer
Will not drain and spin
see this causes:
the drain line is clogged+ some sock remain, remove with pliers,+pump defective.
frozen pulley pump defective, replace
improve the drain line. If drain hose reach more 4 inche cut of of excess. If lower add air/gap siphon break assembly.
see diagram
God bless you
Jul 03, 2012 | Kenmore Elite 45986 Front Load Washer
I have the whirlpool model WTW495OXWD and it wont spin or drain,
see this causes:
drain line is clogged fix it,some sock is inside, take pliers and remove, if you can you need to remove the agitator, the propeel of pump can be defective replace.
frozen pulley pump replace
improve the drain line. if mayor that 4 inch cut of the diference, is a lower install air/gap siphon break assembly
Jun 21, 2012 | Whirlpool Washing Machines
Dishwasher will not drain
Hello there and welcome to fixya
Please check the following carefully
Drain line/air gap A clog in the drain line or air gap (if there is one) is the usual reason that a dishwasher won't drain. Often the problem is at the point where the drain line attaches to the garbage disposer or household drain line. If you remove this line, you can clear any debris from the hose or hose connection. Be sure to reattach the hose before starting the dishwasher again. Pump Your dishwasher pump ejects the water. The pump is usually mounted directly to the motor, then attached to the bottom of the dishwasher. You can reach the pump from inside the dishwasher, but first you need to remove the lower rack, the spray arm, and the spray arm support. Look for an impeller--a round plastic fan blade-type of device that spins around. This is the wash impeller, which forces the water through the spray arm. Beneath the wash impeller is the drain impeller, which is similar in size and shape to the wash impeller. The drain impeller pushes the water toward the drain port. These components make up the pump. If any of the pump components are defective, you need to replace them. Drain valve and/or solenoid Many dishwashers use a drain valve with an electric solenoid. When electricity flows to the solenoid, the valve opens and diverts the water to the drain. Sometimes the solenoid, or the diverting lever, sticks and prevents the dishwasher from draining or filling properly. Try to free up the solenoid to lubricate the lever. Otherwise, you may have to replace the solenoid or pump assembly. With these systems, the motor always rotates in one direction. When it's energized, the drain valve diverts the water. Other dishwashers simply reverse the direction of the motor to drain the dishwasher. These units don't have a drain valve. Instead, there's a drain hose connected directly to the pump housing. Belt One brand of dishwasher uses a belt to drive the pump. If this belt is broken or has fallen off, replace it. Motor If the motor isn't turning or working, the unit won't drain. First check to be sure you have power to the dishwasher. If not, see the section "It doesn't work at all." If the motor hums but doesn't turn, it may need to be replaced. Some dishwashers are susceptible to getting stuck if you don't run them regularly. If you haven't run the dishwasher for more than a week, you may need to manually spin the motor to free it up. If the motor is defective, you need to replace it. Dishwasher motors can't be serviced. Timer Part of what the timer does is control the motor and drain valve. If the timer doesn't work properly, the water may not drain and you need to replace the timer. This problem is uncommon.
Oct 05, 2011 | Neff 24 in. S5409X0 Built-in Dishwasher
I have a evcon 7200erc S-1 The pilot will not stay lit.ignitor cycles while i hold lever to pilot,pilot lites i hold for 60 seconds release lever and pilot goes out.I replaced thermal couple to correct...
Check the following: Pilot orifice or line partially clogged --- remove and clean.
use a fine wire or drill bit to do this.
Gas control valve going bad --- replace gas valve. Gas valves cannot be repaired.
Sep 12, 2011 | Heating & Cooling
Our switch doesn't stay in off position
you probabley bent the switch lever so the little indent on the lever won't stay positioned in the off detent. probabley need new switch lever. part doesn't cost much .not hard to put in if your mechanicly inclined , if not a repair center can do it for you.
Sep 12, 2011 | KitchenAid 32685 Mixer
Hello. after washing water still inside of machine. MAYTAG QUIET SERIES 300.
Hello there and thank you for choosing fixya
Drain line/air gap
Pump
Belt
Motor
Timer
Jun 29, 2011 | Maytag Dishwasher
Water dispenser does not work. When I depress the water dispense actuator, I have pressure at the bottom of the door,but none from the dispenser tube spout. I ran a wire up the tube from the bottom of the...
It could be the water valve side for the dispenser. So a couple of problems can be had with this description. 1. The electric solenoid for the valve is bad so it doesn't open the valve. 2.The valve itself could be bad so the solenoid opens it but nothing flows. 3. The water line could be frozen inside the door so no water flows. 4. The dispenser switch is bad or the plastic holder that holds the switch is bad so the switch fell out of its proper position. 5. The circuit board is bad.
Easy way to check is to pull out the fridge and take the water line off that valve by pressing down on the little ring around the line while pulling up on the line (tube thing). It should pull out easily(to reinsert just push the tubing back in without holding the little ring down, it goes in by itself and self-seals). With the tube out of the solenoid valve have someone operate the water dispenser lever and see if water shoots in your face ha ha. Read further if you're testing by yourself...
You can also do the same test from the front underside where the tubing has a coupling just under the door hinge area (so you can take the door off without cutting the tubing). Pull the lower skirt off the front of the refer and you should see the tubing and little coupling, it works the same, push down on the ring area and pull the tubing out. That way you don't have to move the fridge and can operate the dispenser lever yourself to see if water flows out the disconnected coupling. If water flows then the valve/switch/circuit board are working fine of course and your tubing is frozen at the door. You will need to defrost the tubing somehow, usually means a hairdryer blowing up into the dispenser area or turning off the whole refer and leaving the door open for a day.
If nothing happens (no water still) then you need to check if the solenoid is working electrically. Pull the fridge out and pull the wire plug off the ice maker valve and put the wire plug from the dispenser valve on the ice maker valve. Watch inside the ice maker and push the door dispenser lever, if water flows into the icemaker then the electrical door switch/circuit board is OK and the problem is likely the solenoid valve to the dispenser is bad or a frozen line in the door still. You get the idea, you can swap wires/valves and even tubing (if their the same size) around till you logically find the part not working. Remember in troubleshooting you're not really trying to find the broken part... you're trying to find ALL the other parts are working, which by process of elimination will lead you to the last part that ISN'T working.
If you are comfortable with electrical troubleshooting using a multimeter you can check for 110 vac at the plugs when the switch is press also but that depends on your tools and skill level, etc.
See this link for a diagram of that door assy and the parts involved.
Typically I'd be suspicious of the valve itself being bad or the circuit board, next on the list is the switch, and last would be the frozen line.
Jun 18, 2011 | GE GSS25LGM Side by Side Refrigerator
I hav dell inspiron 1464! a vertical white band of line appeared on left side of screen! i have no idea what is going on ! plzzzzzzzzz helpppp
Hardware defect - the line is made out of pixels that are no longer commanded because the cable that connects the screen to the motherboard is defective.
The laptop's lid will have to be opened and the cable reseated. If that doesn't fixes it then the cable will have to be replaced. This is a job for a repair shop - you will have to take your laptop to one.
Jun 09, 2011 | Computers & Internet
West Bend 77203 Electric Can Opener, Metallic Logo
20 people viewed this question
Top West Bend Dishwashers Experts
Are you a West Bend Dishwasher Expert? Answer questions, earn points and help others
