Question about Bose L1 Speaker
Bose L1 no volume
When I power up the unit the green indicator light comes on and after 3 seconds turns pale yellow. There is little to no volume available.
  • Bose Expert
  • 43 Answers
If the power light turns and stays yellow, there is nothing you can do to fix it. You'll need to talk to Bose L1® Support
Call Bose® Product & Technical Support at (877) 335-2673 (U.S. and Canada only)
Monday-Friday: 8:30 AM - 9:00 PM ET
Saturday 9:00 AM - 5:00 PM ET
Or write to them at the Bose Forum
Ask Bose for Help Forum
Posted on Feb 02, 2015
My bose solo has a yellow light instead of green
The yellow light means you are in reduced bass mode. Hold the mute button on the remote for about 3 seconds and you'll hear 3 tones going up and the light will switch back to green. Enjoy!
Mar 01, 2014 | Bose Solo TV sound system - Black
My L1 Bose system on light switches to red immediately after turning shystem onon
There are no user serviceable parts on the L1® Compact (except that you can order replacement extensions). If the power light (normally blue) immediately turns red and stays that way, the Compact will have to be serviced by Bose.
You can contact Bose Support online here:
Oct 06, 2013 | Bose L1 Compact System
Bose l1 crackle
Rotate the volume controls. Does this cause the crackle? Try working the controls through several turns up and down.
Also check that the lights on the top are not solid red. This would indicate that the inputs are clipping (the input signal is too strong) or the volume is turned up too high.
If that doesn't solve it call Bose® Product & Technical Support at (877) 335-2673 (U.S. and Canada only)
or write to them
May 18, 2012 | Bose L1 Speaker
Bose L1 Speaker Distorting
See this article on the inputs on the Bose L1®.
L1 Model Bose L1 Encyclopedia FAQ Wiki
Set the trim levels so that lights are solid green with occasional flickers of red.
Mar 15, 2012 | Bose L1 Speaker
Canon i470D Printer will not work. Yellow light
1. Turn off the printer ( "Power" button).
2. Hold the button "Resume", include printer (click "Power").
3. Hold the "Power" button, release the button "Resume" (power indicator / preparedness must turns green)
4. Not releasing the "Power" button, double click "Resume" and release both buttons
-- each time you click "Resume" power indicator / willingness to change color (one-click - yellow, the second hitting - green). U printers with more than one indicator - indication switches (power indicator / preparedness - green indicator error - yellow)
-- after the buttons are released, power indicator / preparedness will be for some time to blink green (Stamford time depends on the printer model), and then the green light permanently
-- If after these actions instead of constantly burning green printer continues to display error, or you are mistaken in paragraphs 1-4 (turn off the printer and repeat with paragraph 1), or if additional printer error that must be corrected, or it will not go down to a service mode.
5. Four times click "Resume" (each time you click "Resume" power indicator / willingness to change color, and the printers with more than one indicator - indication switches: the willingness / error).
6. Once you click "Power" to confirm the selected action (reset counter absorber). To disable the printer "Power" button to click again.
For some printers (for example, iP2000) to switch off clicking "Power" again, that is three in a row.
May 08, 2010 | Canon i 470D InkJet Printer
I need the code for sharp tv please
Configuring codes:
  1. Turn on the component that you want to set up. In the code listing find the 4-digit code numbers for your component brand.
  2. Hold the component key down until the green indicator light comes on. The green light should come on after approximately 3 seconds.
  3. Release the component key.
  4. If you are programming the DVD or CD device press the "action" key. The red indicator light will come on.
  5. Within thirty seconds, enter in a 4-digit code number. The component key lights will blink with an upward motion when a code has been successfully entered. In this case proceed to step #5. If the code has not been successfully entered, the componment lights will not blink. In this case return to strep #1 and start over.
  6. Test code by pressing "Power" key. If the component turns off, you've got the right code. Follow the same instructions to set up your other components. If the component doesn't turn off, return to step 2 and use the next 4-digit code listed. Note: If none of the codes turn your component off, try the Auto Code Scan function.
Auto Code Scan:
    The Auto Code Scan feature allows you to set up your components without having to enter in code numbers. The Jensen will do the work for you! (It may take a few minutes to find your code using this method.)
  2. Hold the component key down until the light comes on. The green light should come on after approximately 3 seconds.
  5. Press "0" - "9" The green light will blink as codes are sent.
  6. As soon as the remote turns your component off, press the "action" key. (You have 1 second in which to press the "action" key to save the code.) The component key lights will blink with an upward motion when a code has been successfully entered. The component is now programmed. To find that code, proceed to Code Readback.
  7. If none of the codes turn your component off, return to step 2 and start over.
Code Readback:
  1. Hold the component key down until the green indicator light comes on. The green light should come on after approximately 3 seconds.
  2. Release the component key.
  3. If you are programming the DVD or CD device press the "action" key. The red indicator light will come on.
  4. Press the "enter" key.
  5. Count the number of times the green light blinks. There will be four numbers, separated by a two second pause. The red light will tum off after the remote is finished reading numbers back. Make sure you write the code number below for future use!
Multi-Component Power On/Off:
    The Jensen remote has the ability to turn On/Off multiple components at once. When you perform the following steps, you can turn On/Off the TV, VCR, Satellite, Cable Box and Audio Receiver.
  1. Press the "action" key.
  2. Press the "power" key. Note: This feature does not work for DVD and CD.
Volume Priority Punch-Through:
    When you press the volume keys on the remote they will control the volume on your TV. If you have a home theater system and want the volume keys to control your receiver only, you may set your volume priority to the receiver.
  1. Hold the "RCVR" key down until the green indicator light comes on. The green light should come on after about 3 seconds.
  2. Press "RCVR" key.
  3. Press "Vol+" key. To disable the volume priority you have to set and return to the default.
    To change back to TV priority:
  3. Press "Vol-" key. The volume priority will now default to the TV volume.
hope this helps
Robb
Apr 22, 2010 | Jensen SC-570 Remote Control
Sometimes I hit the power button on my s3710t and it won't turn on. What should happen when it comes on properly is that the power button should turn blue that indicates the unit is turning on. Rather what...
These are usually symptoms that lead to your power supply. I would say that your power supply is on its way out the door. If this unit is under warranty, call Dell.
Hope this helps.
Oct 06, 2009 | Dell Hp Pavilion Slimline Computer s3710t...
No sound Bose Lifestyle 38 III
I am quite sure that the indicator lights should be green. The blinking yellow likely indicates that there is no communication between the head and the audiomass. Verify that the connections are tight and then try powering off (unplugging) the system (both head and audiomass) for 30 seconds and then powering on again. That will often re-establish communications.
Aug 18, 2009 | Bose (321GS) System
Samsung aircon cuts off. lights green/yellow flashing
lg air cond.multi split led lamp blink power 1 times,good sleep 2 times
Feb 11, 2009 | Heating & Cooling
Bose L1 Speaker Logo
139 people viewed this question
Top Bose Audio Players & Recorders Experts
Electro Med Services...
Ben Armstrong
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
