Question about Avanti RM18W / RM19B Compact Refrigerator
Need 2 parts:
Need interior shelf and ice cube trays
Kenmore icemaker tray leaking water (model 795.51022.012)
Do the old 'KISS" thing first (keep it simple ......thing). Chances are that there are tiny calcium deposits in the ice tray which makes an ice cube stick in the tray. If one ice cube sticks, the water will overflow as it needs all the trays empty for the filling. The water will drip down into the freezer area causing chunky ice and stalagmites. The calcium deposits are very teeny in size but will hang up an ice cube from dropping. If more than one ice cube (basically all the ice cubes) didn't drop then the heater in that unit that initially gets the ice cubes to drop could be bad.
I've taken the ice cube assembly out and used vinegar with baking soda to dissolve the calcium and that worked. I left it in for a couple of days. "Do NOT" use anything like a knife or whatever to scrape the bottom of the tray as it will destroy the finish and keep the ice cubes sticking.
When I had the warranty service come out, the technician explained what happened to the tray (calcium). He replaced the tray but the next time it happened I used the vinegar and baking soda. I eventually bought a new tray for 1/2 the price on the internet when the problem happened later on in life.
Jun 13, 2014 | Kenmore Side by Side Refrigerator
Ice Maker No Longer Working
The icemaker contains an electric motor. You might have drowned it.
Nov 13, 2013 | Kenmore Refrigerators
How do I un freeze the ice cube maker?
The heater on the bottom of the ice maker has failed and you will need to replace the ice maker mold. Here is a link to the part.
If you would rather replace the ice maker, here is that part.
Oct 19, 2012 | Kenmore Refrigerators
Frozen solid cube tray
Unplug the frig. Take a hair dryer and melt the ice tray. Then get a paper towel and soak up the left over water. hope this helped
Mar 30, 2010 | Refrigerators
The plastic notched tray of the ice cube maker is broken
Those parts are available and require disassembly of the IM to replace.
Eric
Oct 16, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice cube tray will not release ice cubes
Simply buy a replacement tray. The flexability of the old tray is gone and so no flex means cubes stay put. Aggrevating. A new flex tray is around 20 bucks and very easy to replace. 59688-1 is the part number.bca6e53.jpg
May 22, 2009 | Freezers
Ice maker will not push out ice cubes once frozer
That means that the evaporator fan system that releases the the ice cubes is not working as it should.
The heater, or evaporator fan and heating system must be checked, and fan, or solenoid, or element must be replaced.
Use the number listed on the owner manual if you want to call a technician.
Enter model number on this website to find schematics and replacement parts.
May 12, 2008 | Whirlpool ED2FHEXN Side by Side...
Ice maker tray
There is a fix for this problem.  Call a qualified LG tech to order the updated metal bar for this icemaker.
Feb 02, 2008 | LG LFC25760ST 25 Cu. Ft. Panorama French...
Avanti RM18W / RM19B Compact Refrigerator Logo
Top Avanti Refrigerators Experts
Vernon Taylor
Are you an Avanti Refrigerator Expert? Answer questions, earn points and help others
