Question about Whirlpool GR773LXSS - Stainless Steel Electric Kitchen Range
Whirlpool range preheat ten shuts off.
I have a whirlpool self cleaning oven model # RF396PXVN 3 and when I set the oven to bake and set the temperature to say 350 it goes into pre bake mode. While it is in pre bake the broiler element is bright glowing red all the way back except 1/2" to where it plugs in. The bake element is red but not the glowing red. It also it not red at all about 4" out from the plug in. When it reaches it preset temp the bake element goes off and the boiler element stays on. Of course everything burns on top and not cooked on the bottom. Any help is much appreciated ! Thank Paul
  • Paul Jones Jul 30, 2013
    Is there any questions I can clarify to help with getting a answer to my problem ? I don't know what w
    I don't know what else I can do to explain
jsrock516
  • 5911 Answers
SOURCE: Whirlpool electric range model # RF261PXSQ oven not heating
I'm afraid you may have a blown Electronic Oven Control (EOC) board. The EOC controls all the functions of the oven. The surface elements are controlled by individual infinite switches behind each control knob.. That's why the surface elements all work, but the oven does not. A replacement EOC can be purchased on line at searspartsdirect.com. Just type in your COMPLETE model number and you will find it under the "Control Panel Parts" heading as item number 12. There are several listed, based upon the color you need (White, Biscuit, and Black). This is a very simple repair that any do-it-yourselfer can accomplish if you wish to perform this on your own. All you have to do is UNPLUG the appliance and remove the back panel of the console to access.
Before assuming the EOC is defective, however, inspect the board to see if it has a fuse on it. I do not have a wiring diagram to confirm. Some of these boards do have fuses and that's all that it may take to repair it. However, if the board shows signs of burned components, replace it. NOTE: Check for any loose connectors to the board as well.
I hope you find this information helpful. Let me know if you have questions and/or require additional assistance.
Posted on Sep 25, 2008
freetek
  • 5568 Answers
SOURCE: Whirpool electric range - RF196LXMQ - Will not reach 350 degrees
When using Broil, it is normal for only the top element to work and it depends on the oven whether both should be on or not for baking but typically, baking does not use the upper element otherwise it could burn baked goods.
If setting the temperature higher than 350 does not cause the lower element to turn on, then it's likely that the thermostat has failed and can no longer respond to the temperature set.
The fact that both elements work under some conditions means that both of the heater elements are working at least some of the time. Because of the primitive nature of the elements, it isn't possible for them to just become 'weak' but they can interrupt themselves if there is a break in the resistance element but you could only separate the two possibilities by measuring the hot coil and that would be difficult unless you can pull the range out and access the AC feed lines that go to the element. Obviously, the power would have to be disconnected and the measurement done quickly so the element didn't have time to cool and regain continuity.
Posted on Nov 27, 2008
SOURCE: Whirlpool Gold Range Mod GLP84900
Hi I have a whirlpool gold range mdl GJSP 84902 and had replaced the bottom hidden element after finding out it wasn't getting any heat. So replacement took a little figuring out. it ws easy after a removal of screws and pulling out the whole oven casing out fron the front. Anyhow I still don't get enough heat generate from the bottom element, what other cause are there. checked fuses wiring all is connected HELP ME PLEASE !!!!! thank you Paul
Posted on May 26, 2009
TheMobilian
  • 8220 Answers
SOURCE: Whirlpool oven/range model RF396PXVN - Set knob
That control is expensive 3150200
Looks like to fix this you will need to replace the control. OR you could send it to Texas to get rebuilt for way less: fixyourboard.com
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Apr 16, 2010
Daniel S
  • 4323 Answers
SOURCE: Have a Whirlpool 30" free standing electric range.
Hi
The issue can either be a bad electronic control/clock assembly or the oven temperature sensor (probe) has gone bad again. To solve this issue start by checking the oven temp. sensor for 1100 ohms, if the rating is more then that then check the control and door switch and replace the part that is bad. Hope this helps...
Daniel
Posted on Jan 14, 2011
My oven will self clean and the top will come on when in Broil but oven will not preheat in bake mode.
self clean and broil will make same heat for self clean
if this is a gas range then change bake glow ignition
more info can be yours send us full model # of range for more exact info of your range.
electric range will be element bake or broken burned wire
Dec 06, 2014 | Hotpoint Kitchen Ranges
Whirlpool sf362lxt oven sets off carbon monoxide detector randomly yet all flames are blue
This is caused by incomplete combustion of the fuel, DO NOT operate this oven until a qualified repair person look s at this problem. CO gas is a killer and nothing to fool with.
Feb 02, 2012 | Whirlpool SF362LXTB Range
When the oven is set, it heats for about five minutes. Then "F-2" appears on the screen and it shuts itself off completely.
F2 Oven temperature is too high
1. Look for welded relay contacts on bake or broil relays. If this happens, replace oven control (also called clock or ERC).
2. For SELF CLEAN models: check door lock operation.
3. Look for a high resistance connection or any other cause of high resistance in the oven temperature sensor circuit. Check sensor, sensor harness and sensor harness connection at sensor and oven control. Replace sensor if found defective.
Dec 24, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
After setting my oven to preheat (the oven ignites) around 5 mins. a beeping noise sounds and the oven displays F2. I can't find my owner's manual. Thank you for your help. Connie Acosta
This is likely the oven temperature sensor needs replacing (step 3) But if that checks good follow steps 1 and 2 .The videos will walk you thru performing the checks.
Oct 07, 2010 | Whirlpool GS460 Gas Kitchen Range
I have a Whirlpool Self Clean oven Model number:RBS305PDS17. I used the self clean feature and now my oven will not heat up. All the digital controls work such as preheat and temperature, however there is...
Error code E2F3 indicates oven overheating, i.e. sensor is not cutting off heat. Replace the sensor, about $75 online. If you have done this more than twice, or if oven is acting strangely (for instance, broiler comes on during "bake" preheat), replace control board OEM part #8302994, about $170.
Aug 16, 2010 | Whirlpool Ovens
Whirlpool oven/range model RF396PXVN - Set knob only goes so high and doesn't go in order... for both clock and timer.
Apr 16, 2010 | Whirlpool Kitchen Ranges
Whirlpool Gas Range E2 F3
I HAVE A WHIRLPOOL GAS RANGE MODEL NUMBER SF379LEMS.OVEN WILL LIGHT UP BUT AFTER TEN MINUTES IT WILL KICK OFF ANF ON ON ,THEN AFTER AWHILE I WILL JUST SHUT OFF.ANY SUGGSTIONS. ADAM
Nov 23, 2008 | Whirlpool GS470LEM Gas Kitchen Range
Whirlpool GR773LXSS - Stainless Steel Electric Kitchen Range Logo
65 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Ismael Rodriguez...
Sal De
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
