Question about Refrigerators
Kenmore Coldspot 106 door handle
Model 106.56662500 Bought a new house with refrigerator. The refrigerator door handle is not installed properly. There's a gap between the door and the top of the handle. How can I reposition the handle so it's flush against the door?
  • 172 Answers
SOURCE: Kenmore Coldspot w/Ice Maker Not Making Ice
hi LOP7,
In most cases you can easily solve this problem.
step one would be to make sure your freezer is getting cold enough. If you have icecream in your freezer is it frozen solid or is it soft. Most icemakers cycle around 0 degrees and if your freezer is not getting to 0 then it will not cycle and it will not make ice.
Step two would be to make sure you icemake is cycling. To do this simply lift the little shut off arm on your icemaker and wait about an hour then go back to the icemaker and drop the arm down. The icemaker should start going through a cycle. You should notice the arm slowly begin to raise and the ice dispencer fingers will begin to turn. Then you will hear it call for water. You may hear a humm.
If the freezer is cold enough and the icemaker is cycling that only leaves the inlet valve. replace the valve and enjoy the ice.
If the freezer is cold enought and the icemaker does not cycle, then you have a bad icemaker. Simply replace the icemaker and viola.
Third if the freezer is not cold enought 0 defrees. Then you may have a defrost problem. In this case post more info and I will be happy to help. Good luck mca0824@aol.com
Posted on Apr 30, 2008
SOURCE: Kenmore Coldspot 106 door needs aligning not closing properly
kenmore coldspot water not cold when it comes out of door.
Posted on Aug 17, 2009
SOURCE: kenmore coldspot model 106: top freezer leaks
Have you tried adjusting the freezer temperature to a higher level? This worked for my Kenmore. It will take a couple of days to quit leaking.
Posted on Dec 19, 2010
heatman101
  • 43501 Answers
SOURCE: kenmore coldspot model 106-54592400. The
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Dec 27, 2010
heatman101
  • 43501 Answers
SOURCE: Kenmore Coldspot refrigerator not staying cold.
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Posted on Apr 14, 2011
My Kenmore Coldspot Mod 106. 9651810 refrigerator make a loud buzzing noise
If you hear it more when the doors are open you need a new evap fan
Nov 03, 2013 | Refrigerators
Kenmore coldspot 106 door handle is loose
Gently slide the handle up until it releases. Then slightly turn the screw underneath it, and slide the handle back on. Do this until it fits properly.
Jul 28, 2013 | Refrigerators
How old is my Coldspot refrig Model 106: 9738312?
http://www.kouba-cavallo.com/refdate.htm
your model #'s dont match coldspot numbers.. but here is a website to help..
Dec 28, 2010 | Refrigerators
Kenmore Coldspot Ice Maker Modle #106 56622500 I
these have to be in correctly to lock back in and allow the unit to function. Try removing the bin again and be sure there isn't any small pieces of ice trapped anywhere. Also make sure there aren't any broken pieces from the bin. Hope this helps. Good luck.
Aug 18, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kenmore Coldspot model 106 - Snowing in freezer!
its not defrosting. check heater operations. bimetal near heater. check defrost timer
Feb 08, 2010 | Refrigerators
ICE MAKER NOT WORKING
Check to make sure you freezer is at 0 to 5 degrees. If it is not the water valve to the ice maker will not even open.
Nov 20, 2008 | Kenmore 53642 / 53644 Side by Side...
Refrigerators Logo
35 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
