Huawei phones can be reset by accessing the recovery menu. first pull you battery out and put it back in. Hold the volume UP button and then also press and hold the power button until the phone enters the recovery menu. use the volume down button to scroll down to "factory reset" and select it by pressing the power button. unfortunately all data in the phone contacts/pictures/videos/emails/etc. will be lost but at least phone will be unlocked.
SOURCE: my phone got locked after
Try taking the battery out and letting it sit for 10-15 mins. here is a post i found somewhat relative.
1. try entering null as password.
2. try entering your username without @gmail.com
3. Combine 1 and 2
4. Call yourself from another phone, answer, without hanging up press the home button, then menu button, settings, try to disable pattern-lock
5. Call yourself from another phone, answer, hang-up, directly after hanging up start pressing your buttons like a madman for <30-60 seconds ending with your home button (might take a while to get the timing right). Go into settings and disable pattern-lock.
6. Try the normal recover password routine from GMail.com
7. Perform a factory reset. YOU WILL LOOSE all not-synced DATA (SD card will be left untouched).
1-6 are possible workarounds, these doesn't work for everyone but can be worth a try to avoid factory reset. 6. is what should work but hardly never does. 7 - The factory reset always work
SOURCE: how do i retrieve my gmail password from my cricket huawei android
you can contact the service provider......
SOURCE: how to unlock when i forgot my gmail account samsung sph-m580
The only 100% effective way is to do a factory reset. And with that you will loose anything that is not synched, and your settings.
SOURCE: Is a gmail account the same as a google account
No your google account keeps track of all your other accounts like your gmail account.
SOURCE: PHONE LOCK, UNABLE TO SIGN IN ON GMAIL ACCOUNT, DUE TO GMAIL 2 STEP VERIFICATION PASSWORD.
u first ur volume up key+homekey+pwrkey long press.and next reset ur mobile.
