Question about Garden
I have a Craftsman YS4500 that when I engage the blades the start spinning slowly and kills the engine.
  • 30 Answers
Assuming any belt changes were correct..check the path of the belt to make sure it's not pinched in the guides..and with the blades disengaged and the engine off..that one of your blade hubs isn't seized up.its normal to slow the engine during engagement but not stall at medium rpm.
Posted on Jul 29, 2013
  • 376 Answers
SOURCE: craftsman riding mower repair starter will spin but not engage
You need to buy a Starter Drive Kit. If you starter has a flat piece on top held on by a retaining ring, it's part # 696541. If you have the older type starter with roll pin holding the drive on, you need part # 696540. You probably have the first one. To install the retaining ring, use a 3/8 socket to tap it into the groove. Dwain
Posted on May 29, 2009
wireguy212
  • 1627 Answers
SOURCE: Auger blades won't turn
You need what they call a "friction wheel" replaced.
Posted on Oct 31, 2009
  • 38 Answers
SOURCE: RE: Lawn mower blades will not engage
This sounds like a faulty ground condition, the PTO clutch requires a ground provided by the chassis wiring harness to function and a ground for the ignition switch to kill fire to the coils. The other components work as they should because the voltage regulator, fuel shutoff solenoid and starting interlock system have their own grounds. The ignition switch in these mowers is a large round plastic switch not capable of grounding itself, it should have a black wire leading from the terminal marked "G" on the backside of the switch.
to diagnose a faulty ground you'll need a basic 12V test lamp:
Unplug the switch and and install a the test light clip on the positive terminal of the battery, probe the ground wire in the unplugged harness that corresponds with the "G" terminal only. If the ground is good the lamp in the test light will illuminate brightly, if poor or faulty the lamp will not light or be noticeably dim.
Further verification of a faulty ground or failed PTO switch can be tested at the PTO Clutch harness, turn the key on, engine NOT running, and pull the PTO Switch to the engage position, with the test light clipped onto the Negative Battery terminal or chassis, back probe the connected PTO clutch terminals. If the PTO switch is good and the ground is good then Only one terminal will illuminate the lamp, if both wires illuminate the lamp then the ground is faulty, if no lamp illumination then a loss of power is suspected, check the terminals on the PTO switch and Ignition switch for power.
Typical Ground termination locations are on the frame near the rear of the tractor frame, above the transmission, in the steering column area and near the solenoid, check for a loose or corroded eyelet terminal, broken wire, or a missing fastener in these areas.
Posted on Jul 04, 2010
  • 721 Answers
SOURCE: swisher 44" mower starts and runs but engine bogs
The engine in this machine seems to be powerful. If you can remove the belt from the pulley that drives the blade. Try turning the pulley buy hand. If it turns tight or not at all this is your problem. The unit that is the pulley to blade assembly is seized or ready to seize. Sometimes they are designed to be taken apart and repaired, and sometimes they are not. Did you check for a grease fitting within the pulley to blade unit?
I would like to hear how this works out for you. Best of luck.
Posted on Jun 14, 2011
BAMOUT
  • 2478 Answers
SOURCE: cub cadet 1040 blades spinning when pto isnt engaged
Sounds like you forget a spring or the routing belts are
wrong.
Posted on Sep 30, 2012
Does model # 917.276021 have a mower lock out on the transmission
The PTO when engaged draws a lot of power from the battery. Check the battery for proper voltage. If your battery is low or say 1/2 charge, it will never engage the blades and will die every time you try to engage the blades.
Aug 04, 2014 | Craftsman Garden
I have a 3 year old ys4500, wont start
Have you tried bypassing the cut off switch, by joining the wires together
Sep 20, 2012 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
Craftsman ZTS 7500 dies when engage blades or when engage transmission
check the "kill switch" they are usually located in the seating area. it senses for pressure or seat angle and will kill the mower if nobody is sitting on the mower. Good Luck
Apr 17, 2012 | Craftsman Garden
Every time I use the lever to get the blades started it kills the engine. it does it even after i removed the belt. what is causing the blade rotation lever to kill the engine?
hi there talane
sounds like you have a safety switch problem
try disconnecting seat switch and retry if works could be wire grounding some where or faulty switch then try fitting a jump wire to seat switch wire connector then retry then check blade engagement switch may be playing up or a nuetral switch playing up but more likely a seat switch
with operator off seat and park brake on engine runs, but with pk brake off and operator off seat
engine stops , same if operator leaves seat and blades engages -engine stops,
if unit not in nuetral and pk brake not on unit wont start
take look
hope it helps
cheers pauly46
Jul 03, 2011 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Craftsman YS4500 won't turn over
low battery charge or the teeth on the starter gear is bad. the fly wheel should turn if the starter is engaging. i have disconnected the seat switch and it still turns over. the blade and parking brake switch will not let it do anything if disconnected. to change the starter gear only takes a few minutes after the covers are removed.
Apr 24, 2010 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
What would cause my craftsman zero turn to die when i engage the blades?
First, sort out between two possibilities: 1. The safety system is killing the engine -- for example, if the seat switch is faulty or misadjusted, the engine ignition is killed when you activate the blade engagement switch. 2. The blades, spindles, or belts are binding or stuck, which would "drag" the engine to a stop. I suggest you remove the belt that drives the mower from the engine. If the engine still dies when you engage the blade switch, it's problem #1. Check all connections, and check the seat switch with an ohmmeter. If the engine does not die, then you have mechanical drag. With engine off and the belts taken off, turn each spindle to find out if one is frozen or binding. Good luck!
Apr 05, 2010 | Craftsman 21 HP 42 in. Zero Turn Tractor...
Lawm mower back fires and kills when blade is engaged
Check your spark plug. Or maybe your choke is stuck
Jun 19, 2009 | Craftsman Garden
42 inch Craftsman blades won't engage
model 917258862 mower was given to me. sat outside numerous years. I've managed to get it to start run and drive, but cant get blades to engage. don't know what the wires are for or do that go to some sort of pulley attached to the bottom of motor. can somebody help me pls ?
Jun 13, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I have 16 hp Craftsman riding mower with a Kohler engine.
It may think you are in reverse and is killing the motor to keep you from backing up with the blade running. Look for switch that is telling it when you are in reverse, maybe it is stuck with grass or other debris. another possibility is that the blades are jammed and they are stalliing the motor. Mines stalls easily when cold.
Mar 09, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
