Question about NEC 85880 Database Back-Up Phone
Need a manual for NEC ETW16DC-1 system
We have inherited this system sans manual and are now wanting to add call display to our line. I need to know if this system has a scrolling feature to view missed calls. There is a FNC key which I assume means function but I have no information as to the functions of this phone. Ignore the product selection below.
    New Friend:
    Problem Solver:
  • 7 Answers
NEC is a advance and multi functionality phone system. This is better option to your simple phone system we are encourage the best NEC and PBX hosted phone system.
Posted on Apr 17, 2014
Fonedud - The ETW model terminal will work on several NEC systems. Without knowing what system the telephone is connected to, it is impossible to address your concern. You should be able to find a local NEC Authorized dealer in your area to assist. djantz@necunifiedsolutions.com
Posted on Aug 31, 2007
How do I change the display name on a NEC ETW-16DC-1 display phone that is on an Electra Professional Level II phone system?
You will probably need to add the extension name via system programming. The following installation manual for the NEC Professional Level ll phone system may help (copy & paste)
http://pdf.textfiles.com/manuals/TELECOM-A-E/Electra%20Professional%20Level%20III%20Install%20Manual.pdf
Jun 14, 2018 | NEC Lands Phones
Tip
How to add a tag / label cloud to your Google Weblog OR Blogspot Template
You can use several widgets that are available that require you to register and claim your like the leading website Technorati you will then be on their blogroll which you might as well do anyway. At the time of posting the widgets section is being revamped so if you just want a simple cloud just for your blog not linked to another site read on.
First you need to add Bloggers own Configure label widget through the dashboard., this may suffice for you needs but its not much of a cloud.
Next you need to add several lines of HTML code to your template in the editor I suggest you donwload it first for a backup copy should you make a mistake.
Next you need to do a search for this line of HTML code this the where you add the next two pieces of code
]]></b:skin>
Above this code add this code in place of the single line I suggest that you add a carriage return either side of it, you must not add it after the last </head> tag
/* Label Cloud Styles
#labelCloud {text-align:center;font-family:arial,sans-serif;}
#labelCloud .label-cloud li{display:inline;background-image:none !important;padding:0 5px;margin:0;vertical-align:baseline !important;border:0 !important;}
#labelCloud ul{list-style-type:none;margin:0 auto;padding:0;}
#labelCloud a img{border:0;display:inline;margin:0 0 0 3px;padding:0}
#labelCloud a{text-decoration:none}
#labelCloud a:hover{text-decoration:underline}
#labelCloud li a{}
#labelCloud .label-cloud {}
#labelCloud .label-count {padding-left:0.2em;font-size:9px;color:#000}
#labelCloud .label-cloud li:before{content:"" !important}
]]></b:skin>
<script type='text/javascript'>
// Label Cloud User Variables
var cloudMin = 1;
var maxFontSize = 20;
var maxColor = [0,0,255];
var minFontSize = 10;
var minColor = [0,0,0];
var lcShowCount = false;
</script>
NEXT : - Find this HTML code, best to leave Expand Widget unchecked, for the label widget and then replace it with the code in this download HERE
You need to then save your template and you will see your new label cloud.
You can change the details of the CSS section above to change the font typeface, size and colour if you want to for example to change the font to arial alter the line
change the font-family to one of your own choice like trebuchet.
#labelCloud {text-align:center;font-family: trebuchet.;}
If you do set the display to block you would probably want to change the sort frequency from alphabetical to frequency do this in the actual blogger label widget in the design dashboard. also change the display line from
display:inline to display:block to get the a flat listing.
on Jul 10, 2010 | Google Chrome
URGENT: How can I connect my tv to my NEC VT695 projector?
Do you want to duplicate the image going from the source to the projector on your TV? If so, then if your TV has a VGA port, just use the monitor Out on the projector. If your TV doesn't have a VGA port, you'll need an appropriate converter. (Avoid a VGA to component video or VGA to composite cable.) If you add a comment with more information on the inputs for the TV (or the model of the TV), then I will try to point you to the correct converter.
If you want to get your TV signal to the projector, you would need a set-top box (cable, satellite, digital tuner) as the source. Most TVs do not have a video output. You can connect a computer or DVD player to the projector.
The manual and quick guide for the VT695 are available from NEC here: http://www.nec-display.com/dl/en/pj_manual/vt695_491.html . The direct link to the English language version of the manual is http://www.support.nec-display.com/dl_service/data/manual/english/vt695_491_manual_e.pdf .
I hope this helps.
May 25, 2014 | Office Equipment & Supplies
How to assign trunk lines on NEC SL1000 Keyphone System?
Try posting here:
http://www.tek-tips.com/threadminder.cfm?pid=937&page=1
Dec 07, 2012 | NEC PABX SL1000
My cordless phone in my restaurant is finally had it. NEC wants $300 for a new cordless! If I buy a different cordless made by a different company, will it be compatible with my NEC corded phone?
No, You must use an Nec telephone, thus the price. If you need it on one line only you could connect any cordless phone on the dial tone before the NEC system. This will ring and also you can call out but you will not be able to transfer from or to it and you cannot use any NEC system features.
NEC $279.45 from me gregdownes@verizon.net
Jan 11, 2011 | NEC DSX Systems NEC-780020 DTR-1-1 BLACK...
I have a NEC Dterm Series II phone. I need to
This phone works on different NEC phone systems.Elite,IPK, 2000, 2400. Each speed dial code is different in each system. what system do you have
Jan 05, 2010 | NEC Dterm DTP-2DT-1 Phone
NEC Electra Professional Level I Upgrade
The NEC Electra Professional Level 1 has a maximum CO line capacity of 8 in any configuration. If you need more outside phone lines, you will need a different system. If you need to limit cost as much as possible, the cheapest avenue would be to upgrade to a used Electra Professional Level II. That way you can still use the same telephone instruments, but ALL cabinet hardware would be different. Also, you can only get to 8 outside lines if you have software level 3.00 or higher by using the COI-C(2A)-10 card. To verify which software version you have, I think you press FNC(3) on sta. 10 ( or the first station in the system). If that doesn't work, let me know, and we can access the system program to verify version number.
Dec 29, 2008 | NEC Electra Professional ETW-16DC-2
NEC DTU-8D wiping the directory list
If it is in the system speed dial directory you have to go one by one and type "Feature, Redial, bin # where it is stored (system 00~79, station 80~99), Feature". This should wipe each Speed Dial listing.
If it is in the voice mail unit you may want to go phone by phone and log into the box. You will need to redo the following:
Personal Greeting
Recorded Name
Spelled Name
Directory Listing
Security Code
All these options are listed in each mailbox through a series of soft keys. Let me know if you need more info.
Aug 13, 2008 | NEC DTH-8D-1 Corded Phone
RE: NEC DTP-2DT 2 Line Digital Phone HandSet
i believe the nec dtp-2dt maybe a phone system phone for offices. you didn't mention if it's for home or office use.a phone system phone will not work in a regular phone jack. it needs to go thru a phone system. also if you buy any 2 line phones, you need 2 lines for both lines to work. you can also have a 2 line phone with only 1 line and order a 2nd line if needed
hope this helps
wg
Jan 30, 2008 | NEC Dterm DTP 16D-1 Corded Phone
NEC Dterm 80
NEC Dterm 80 phone, 1 ext. is blinking and we can't get it to turn off. It shows a busy signal when you try to call it.
Help it is the owners phone!!!
Sep 29, 2007 | NEC Dterm DTP 16D-1 Corded Phone
Lands Phones Logo
214 people viewed this question
Top NEC Lands Phones Experts
Craig Butler
Craig Butler
Norman Al-Anbar
ray gallant
Are you a NEC Lands Phone Expert? Answer questions, earn points and help others
