Question about Samsung WF337AA Front Load Washer
Sud error on the screen there is the word SUd and the machine stops working so I have restart it again
  • Samsung Master
  • 5,389 Answers
Most front load washers will give a version of this code if the debris trap is clogged or you use too much detergent. If you don't use HE detergent, the error is extremely likely.
If the error is from an excess of detergent, once the suds dissipate, the washer should restart on its own. It may do an extra rinse cycle.
You should try running a wash cycle with no clothes or detergent added to the washer. This will get rid of excess detergent that may be in the unit. In the future, use less HE detergent for each load.
The debris trap is between the wash tub drain and the pump. This area collects coins and other foreign objects to protect the pump. You should be able to access and check the trap by taking off the back panel. Use a bucket to catch any water that may be in the trap. Take off the hose and check the trap. Make sure nothing is in the pump area that you can see. (There is at least one video for cleaning the debris trap available on YouTube.)
I hope this helps.
Posted on Jul 28, 2013
2 Suggested Answers
  • 1531 Answers
SOURCE: sud error showing what does this mean?
usually this alerts you to to much soap suds in the unit.run the washer with no soap this should clear the system and try and reduse the amount of soap you use
Posted on Sep 27, 2009
I have a Samsung eco bubble WF1804WPU model that started showing the error message SUD. Any time it happens the machine stops washing as if paused and I have to press the pause button twice for it to start...
The SUD error indicates an excessive amount of soap suds in the wash. It will be difficult for the machine to rinse / spin all the soap out during the cycle, and may need to be run thru the cycle again (do not add any more detergent!).
Remedy:
Stop using regular detergents! Front loaders specifically call for "HE" (High Efficiency) detergents as they require less detergent and clean better with the reduced amount of water in these machines. Look for your favorite brand and select the one with the distinctive HE logo show below:
Use only the amount as directed on the bottle - do not use too much. Clothes should come out clean and soap free - and the SUD error should no longer appear - if it continues - double check the amount of detergent you're using as it is probably still too much.
Jan 30, 2015 | Samsung Washing Machines
Final spin cycle I get sud error code or f2, water mostly drained but no spin. When I restart the spin cycle just starts to spin then stops, sounds like it drains some more water then makes a small...
Check the drain hose and make sure it is not plugged or kinked • Check the electrical connections at the pump and make sure the pump is
running. • Check the drain pump filter for foreign objects • If the above does not correct the problem replace the pump
The motor control unit senses a suds lock condition by analyzing the current draw on the drive motor. If "Sud" is displayed a potential suds lock is detected. This may signify a bad pump, an extra heavy load, excessive detergent, or excessive suds.
Feb 05, 2011 | Whirlpool Duet GHW9150P Front Load Washer
What does SUD mean?
SUD means a detection of suds in the machine. These machines are very sensitive to over sudsing. Try adding just plain water or bleach to break down the suds level. They say to use 1/4 of the detergent you would use in an older machine.
If you see "Sud" or "Sd" with the Rinse status light on, the washer is in the process of removing suds. Let the cycle finish
If you see "Sud" or "Sd" and the Cycle Complete light is on, the washer detected too many suds during the cycle and your load may not be fully rinsed or water may not be fully removed. You may want to select a Rinse/Spin cycle for further rinsing.
Jul 31, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet -Sud displays and washer stops
I;ve had the same problem (SUD on first fill) and found this most helpful for my WFW9600TW01 Duet washer
http://www.tellingmachine.com/post/Fixing-Sud-and-F35-errors-on-my-Whirlpool-WFW9600TW01-Washer.aspx
I duplicated his actions and it cleared up my SUD/F35 error. I think running the diagnostic test multiple times flushes the sensors/sensing lines to eliminate the problem.
Jan 30, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Frontloader shows SUD but no visible suds ....then machine stops working. also shows F34 numbers. Have tried resetting by un-plugging . then works fine for a few times then shows SUD again and we have to...
You may have a clogged drain filter.
Remove the bottom front panel to access the filter. Unscrew the filter,clean and replace the filter. Also,run 2-3 wash cycles with no detergent at all.
When using HE detergent,use the exact specified amount. With front load machines more is not better.
Nov 28, 2009 | Whirlpool Washing Machines
F35 Sud errors
OK, you can't use regular Gain detergent in this washer. you will need to use the recommended (HE-High Efficiency) brand. its the only way to avoid the SUDS.
Jun 10, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet washer flashing sud then f21 ????????
The "SUD" error is in direct relationship the other error code. "F21" is a Long Drain error. The following link explains:
http://www.fixya.com/support/r1484065-f21_error_code_whirlpool_duet_kenmore
If something is preventing water from pumping through the drain pump, you will often get a "SUD" error as air is developed in the pump. Make sure you double check all the drain lines as well.
If you have questions, or require additional assistance, please let me know before you rate the solution. I hope this helps you.
Jan 28, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Spinning and draining does not work, F error or sometimes Sud
Sud means you using to much soap and the f code means soap is locking the drain pump up and wont allow unit to drain and spin.
Nov 22, 2008 | Kenmore Elite 45986 Front Load Washer
Persistent F02 / SUD error. Tried all the tricks!
how about the line from pump to bottom of tank?not excess suds?might be bad control bd..f code is generated when control bd senses incorrect current draw by drain motor ..could be glitch in readings or a misread
Nov 02, 2008 | Kenmore 4292x Front Load Washer
Wont start and says "SUD"
yes I can the suds is from too much soap it will go thru a flush cycle and should go away after 4 min of opert. let me know if it does not clear you may also get a LD code on the machine to clear press cancel twice
Feb 12, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Samsung WF337AA Front Load Washer Logo
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
