Question about Brother DCP Office Equipment & Supplies
Makes grinding sound - DCP Brother Office Equipment & Supplies
    Champion:
  • Brother Expert
  • 265 Answers
Usually from the maintenance unit, chabge it.
Posted on Dec 09, 2014
Front load washer will not spin
Good Afternoon Kevin,
I see that you are having trouble with your Frigidaire washer not spinning and making a grinding sound as if something were stripped. I also see that changing out the door lock and switch assembly, did not help the issue.
I would suggest contacting either the manufacturer or your local authorized technician for further assistance. They will be able to diagnose what is causing the grinding sound and better assist in resolving the grinding sound. Hope this helps.
-Best Regards-
WP
Apr 21, 2014 | Frigidaire FRT18HS6JS Stainless Steel Top...
I have a 90hp yamaha two stroke, makes a grinding
I had the same thing happen to me this weekend. I tried to slam it in reverse after my dog fell off and it sounds like yours. Have you found anything about the issue?
Nov 15, 2009 | Boating
Grinding noise from passenger side engine
The water pump bearings could be going out and they will make a grinding noise.The water pump doesn't always leak when the bearings are going out.
Sep 01, 2009 | 2002 Dodge Neon
Power door locks dont work right
THE ONLY WAY TO FIND AND TRY AND FIX PROBLEM THAT IS YOU'LL HAVE TO REMOVE THE DOOR PANELS THAT ARE MAKING THE GRINDING SOUND, AFTER YOU REMOVE THE PANEL TRY TO OPEN THE WINDOW WITH THE REMOTE AND THIS TIME YOU'LL SEE WHATS MAKING THE GRINDING SOUND...MY GUESS IS THAT THE GLASS COULD BE OF THE TRACK. AND WHEN YOU USE THE REMOTE THE FORCE OF MOTOR AND GLASS CAUSES THE GRINDING SOUND..
GOOD LUCK.
Feb 05, 2018 | 2001 Ford Expedition
Washer is making a grinding sound when draining water.
hi, this grinding sound is coming from the pump. the pump device seems to have a broken impeller that is located inside the pump. You will not be able to replace this internal part. This device is fixed and you will have to replace the entire pump assembly.
This will happen if some debris or coins make it threw the pump housing. these debris will settle in the pump housing near the impeller and it will grind while in operation or, draining procedure. the solid debris will eventually damage the impeller and break it off the drive bolt. this will all happen in time but, it usually starts with the minor grinding sound.
May 16, 2009 | Kenmore Washing Machines
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
