Question about Mitsubishi Heating & Cooling
What is menning check p8.then how can i fix the problem
Model number PU-10YAKD 3phase out door unit
4 Suggested Answers
relaga58
  • 158 Answers
SOURCE: p8 eroor code
P8 error is abnormal pipe temperature indoor. If you are running it on heating P8 error will appear because the disc pressure is too high. It could be overcharged.
Posted on Jun 01, 2009
SOURCE: amcoraire / aos241hx / code p8 / unit shut down will not restart
for all error codes. http://www.digelair.net/pdfs/TECHLIT/MITSUBISHI/MrSlim_P-SERIES_Troubleshooting_TIPS.pdf
Posted on Jul 13, 2009
SOURCE: Mitsubishi Mr slim Airconditioner error check P8
I Have same problem
Posted on Sep 28, 2009
Mitsubishi Error Codes what is a P8 error code on an under ceiling unit that is not cooling
P8 denotes a fault related with its power supply regulator board. If you wish to get more details about the error codes to Mitsubishi, check this link. http://electronicshelponline.blogspot.com/
Pull up previous posts by its left sidebar, or type in the brand name and model number to of your set, to its search box, and press 'Enter' or view it in Mosaic / Timeslide option
Oct 05, 2013 | Televison & Video
We have a P8? CAN'T FIND MANAUL
P8-Abnormality in outdoor unit.
1.Wrong wiring of indoor/outdoor
connecting wire.......................Check the indoor/outdoor connecting wire.
2) Reversed phase......Change the connection of electric wiring.
3) Protection device is working........ Check the protection device.(LP,HP)
4) Damaged outdoor coil thermistor.....Measure the resistance of the outdoor coil thermistor.If the resistance is normal, replace the outdoor controller board.
5) Check out door coil is cleaned. If not do it.
thanks.
Jan 30, 2011 | Mitsubishi Mr. Slim MXZ30TN Air...
Our air conditioner has been switched off for some months. Last week we had a power outage. When I switch the unit on now it runs for a short time then P8 along with two zeros flashes on the control unit....
P8 due to outdoor pipe temp high. Due to condenser blocked. But you said it's cleaned. Check speed of fan rpm. After short time fan may rotates slowly. Please replace fan capacitor in out door unit.
Jan 01, 2011 | Heating & Cooling
Mitsubishi mr. slim showing P8 on thermostat
p8 means problem at out door unit google mr. slim p8 fult code describes in more detail
Jan 15, 2010 | Humidifiers
Ac unit shuts down
See this document for P8 code on Mitsubishi Mr Slim MXZ30TN... It is likely you can get the fix just from following the diagnosis steps 1-7. http://www.digelair.net/pdfs/TECHLIT/MITSUBISHI/MrSlim_P-SERIES_Troubleshooting_TIPS.pdf
Jul 02, 2009 | Mitsubishi Mr. Slim MXZ30TN Air...
P8 eroor code
May 31, 2009 | Mitsubishi Mr. Slim MXZ30TN Air...
Mixed numbers
Proper fraction e.g. 3/5, input 3, divide, 5, =, answer 0.6
Improper fraction, either enter as improper fraction, or enter the whole number first, then +, then the proper fraction as before, then =.
E.g. 8/5 which is "1 and 3/5': enter 1, +, 3, "divide", 5 =, answer is 1.6
Or, just 8, "divide", 5, same 1.6 answer. Why go to mixed number first?
13/5 which is "2 and 3/5", enter 2, +, 3, "divide", 5, =, answer is 2.6. Or, just 13/5, same answer
Dec 17, 2008 | Texas Instruments TI-30XA Calculator
No heating from Mr slim
P8 refers to outdoor protection device activation usually caused by low gas charge or blocked condenser coil. any good a/c company can resolve this for you. however please note that if it is gas related a pressure test must be carried out to determine where that potential leak may be and that can be very costly.
regards
Ed
Nov 13, 2007 | Mitsubishi Mr. Slim MXZ30TN Air...
Problem with mitsubishi slim
I am not familiar with a P8 code nor do I understand where you are seeing this But, go to mrslim.com and look under Customer resources, Library and then input your model number. Select Technical & Services. Product Catagory is Mr. Slim Ductless, Sub Catagory is M-series Multi Split, Current models. Remember you have inside units and one outside unit. You will need to look at each model number to find information on both. Usually Mitsubishi's will have two lights that will blink in patterns to indicate what could be wrong. The P8 code is new for this Diamond Dealer!
Sep 30, 2007 | Mitsubishi Mr. Slim MXZ30TN Air...
Heating & Cooling Logo
50 people viewed this question
Top Mitsubishi Heating & Cooling Experts
D. E. Hev
MightyMikeJr
Are you a Mitsubishi Heating and Cooling Expert? Answer questions, earn points and help others
