Tgb 202 my speedometer, fuel gauge and miles counter doesn't work whats wrong with it
    New Friend:
    Problem Solver:
  • 6 Answers
Could be broken or disconnected, check the cable.
Posted on Aug 14, 2013
A Used Transmission is installed now my speedometer doesn't work.
Sounds like the wiring harness was damaged or left disconnected when the engine was installed.
Jun 12, 2013 | 2004 GMC Envoy
Speedometer and tach don't work
my speedometer stop working too, and the needle was on the wrong side of the nib.
I pushed the little black nob (trip counter) at lower left corner for ten sec.it seem to reset things, it works fine now
Feb 08, 2013 | 2000 Dodge Caravan
Gas, fuel, and temp gauge doesn't work
You have blown a fuse..check fuse box. There may be one fuse box one in the cabin but also check for the fusebox in the engine compartment.
Oct 04, 2017 | 1992 Dodge Caravan
Speedometer doesn't work
For speedometer related issues,the help links are provided below.Click the link below to go through its details :----
How to trouble shoot speedometer?
http://schematicsdiagram.blogspot.com/2011/06/speedometer-not-working.html
why speedometer not working? http://technoanswers.blogspot.com/2012/01/1996-fiat-bravo-speedometer-not-working.html
Speedometer works but odometer not working? http://technoanswers.blogspot.in/2012/01/speedometer-works-but-odometer-not.html----------- Speedometer runs backward?
http://technoanswers.blogspot.com/2012/01/speedometer-runs-backward.html
Warning lights on and speedometer died?
http://howtobyme.blogspot.com/2011/08/warning-lights-on-and-speedometer-died.html
ABS & Brake lights warning indicator steady on dash and speedometer not working?
http://howtobyme.blogspot.com/2011/11/abs-brake-lights-warning-indicator.html
Vehicles Cluster panel Not reading Miles?
http://schematicsdiagram.blogspot.com/2011/12/vehicles-cluster-panel-not-reading.html
Odometer works properly but speedometer works intermittently? http://technoanswers.blogspot.com/2012/01/odometer-works-properly-but-speedometer.html
How odometer works in cars?
http://technoanswers.blogspot.com/2011/11/how-odometer-works-in-cars.html
Speedometer not working on Ford?
http://repairhelpcenter.blogspot.in/2012/02/speedometer-not-working-on-1993-ford.html
This will help.
Thanks
Feb 14, 2012 | 1996 Plymouth Voyager
The speedometer in my 2002 chevy prizm stopped working. From what I can tell that is the only issue. I'm not sure if it is a fuse or a relay or something different altogether. It does tend to just...
Sounds like a broken speedometer cable. The bounce around erratically, because the cable is still connected under the hood and still spinning. Even though its broken the two ends make contact and still causes some movement of the speedometer.
Usually runs from the transmission through the firewall and into the back of the gauge cluster.
Sep 24, 2011 | 2001 Chevrolet Prizm
2005 FORD MUSTANG--FUEL GAUGE AND SPEEDOMETER DOESN'T WORK--WHAT'S LEAST EXPENSIVE SOLUTION
This is due to a problem with the gears in the speedometer and fuel gauge; there was a manufacturing defect that ford fixed in later years. The cheapest solution is to replace these gauges. I found a local mechanic that knew how to fix it, and did the job for $60. I recommend checking craigslist for a local person, because this is a very common problem.
Jun 14, 2011 | 2005 Ford Mustang
Just bought a '92 plymouth Acclaim with 37000 miles. It's in great shape but I'm not sure if the fuel guage is working. Only drove it home, less than 10 miles. Is the guage mechanical or...
There's a float inside the tank that the fuel gauge works off of. If you step on the brakes or accelerate hard it causes the gas inside the tank to slosh around and you can see the fuel gauge move when you do this. If you know the vehicle has gas in it, the best way to check if the gauge is bad is to drive around enough to where you should have burnt a noticeable amount of gas. If the gauge doesn't move, then there's something wrong with it.
Since the gauge moved when you braked hard, I would assume it's working properly because it picked up on the level change inside the tank where the float's at.
May 19, 2011 | 1992 Plymouth Acclaim
2000 yamaha roadstar 1600. electronic speedo and fuel gauge works as it pleases. when working turn signals make it quit. or anything including horn makes it stop. thinking ground. any ideas
Hi tcjones65 !
Did you find any solution? I have the same problem on my XV1600. I've changed the speedometer assembly, but it still the same, fuel gauge and speedometer doesn't work...
May 19, 2011 | 2000 Yamaha XV 1600 Wild Star
I have 1992 dodge B250 van the speedometer is working but the miles counter not working.
if the speedometer is working but the counter is not - then the counter gear is broken.
it is not worth trying to fix -- just buy a new gauge and install it.
c...
Feb 22, 2011 | 1988 Dodge B250
Computers & Internet Logo
62 people viewed this question
David Payne
David Payne
