Hyundai iload problems
Removal of side loading door handle removal
philbran
  • 242 Answers
SOURCE: Door handle
If this is a side by side door refrigerator you can not move the doors or the handles.
Phil
Posted on Jan 13, 2009
DJ_Doc
  • 3 Answers
SOURCE: hyundai accent '02 inside door handle & Lock removal
Removing the door is very tricky, trust me on this. I ended up breaking it the first time, so please learn from my mistake.
1. Remove all visible screws: 2 at bottom of door, 3 on front near hinge, 1 on inside the door lever. You will need an average size phillips screwdriver to do this.
2. On the door handle itself, you will see two circles. Pop the front one out. You will need a LARGE size phillips screwdriver to do this.
3. Once screws are removed, take a (standard) flat-head screwdriver, preferable one with a large face, and pry the triangular piece of plastic (that covers the outside SIDE mirror) off. This will aide in puting the door panel back on...TRUST ME!!!
4. Take the same flat-head screwdriver, and pry behind the door lock (at the same time, push forward toward the door hinge). The assembly should pop out.
5. Gently pry the door panel from the door, making sure not to break any unnecessary pieces along the way. The door panel should be hanging by the window sill opening.
6. This is where it will get tricky. It is advised that you use help with this part: Angle the door panel at a 45 degree angle. AT THE SAME TIME, slightly bend and twist the door lock handle until it fits through the hole. You will see the 3 pegs the held it in the door from before. Also note: Be careful not to break the 2 poles that are attached to the lock.
7. After popping the lock through the hole, you should be able to lift the door upward, and off the sill. Repeat these steps in reverse order to re-attach door panel.
Be careful not to rip sound-deadening paper found on inside of door unless you intend to remove or replace it! Not only does it prevent dirt and moisture from entering your door (and possible rusting it from the inside out), but it makes your speakers sound better too!
-SportTunerFreak
**It is also recommended to put a tiny bead of silicone on the inside of the door panel to help suppress any rattling, and prevent moisture and dust from entering. It also helps your screws obtain a tighter fit. Hope this helps!
Posted on Mar 24, 2009
  • 274 Answers
SOURCE: Drivers Side Door Handle
You need to take inside door panel off This just clips on but there are screws in armrest and inside door handle look for any other small square covers that may hide screws Lift panel up Make sure window is up Disconnect wiring from panel and you can now get at door handle linkage and bolts
Posted on Jul 10, 2009
  • 12 Answers
SOURCE: Hyundai accent 1997, the driver side door handle broke
taking off the door panel is a lot of work. i can explain it all to you if you still have the same problem. i've replaced all of my door handles for all 4 of my hyundai's doors, so i'm experienced in this department. would you like a step by step walkthrough still?
Posted on Aug 05, 2009
  • 490 Answers
SOURCE: Removing door panel on 1997 Hyundai Accent
Look under the round part of the handle,see if there is a small allen screw there,if it is unscrew it until the handle comes off.if not send a new message
Posted on Sep 06, 2009
Remove interior door panel 2002 Chevy tracker
No you don't need any special tool . Find all screws on out side of door trim panel and the window handle , the mirror cover plate , then just pull on edge of the panel .
Gently pry the front side door trim panel (3) from the front side door by disengaging the plastic retainers which secure the panel.
Position the door trim panel (3) away from the door in order to gain access to the front side window switch electrical connector, if equipped.
Disconnect the window switch electrical connector, if equipped.
Remove the door trim panel (3) from the vehicle.
Remove the front side window switch from the door trim panel (3) by releasing the 4 plastic retaining tabs, as needed.
Use a cloth in order to pull off the snap ring which secures the front side door window regulator handle (1), if equipped.
Remove the window regulator handle (1), if equipped.
Remove the front side master window switch, if equipped. Refer to Power Accessory Switch Panel Replacement .
Remove the front side door inside handle (1). Refer to Front Side Door Inside Handle Replacement .
Remove the outside rearview mirror opening cover (2).
Remove the screw which secures the front side door pull handle (4).
Removal Procedure
Remove the screw which secures the front side door inside handle (1).
Slide the inside handle (1) forward in order to release the retaining tabs which secure the handle to the door.
Open the front side door inside handle rod retainer and remove the front side door inside handle rod from the inside handle (1).
Remove the inside handle (1) from the vehicle.
Check out youtube video showing how to do it !
How To Remove Install Front Door Panel Suzuki XL 7
Jun 10, 2017 | Cars & Trucks
Replace Front Door Handle on 2007 Hyundai Accent Hatchback
remove the door trim and get to it from the inside of the door
Jun 08, 2016 | 2007 Hyundai Accent GS Hatchback
How to change the mirror of hyundai iload
Remove door panel to get access to mirror retaining nuts
Feb 13, 2015 | Hyundai Cars & Trucks
I need written instructions on how to replace a outside driver side door handle for an 06 ford focus
Close/wind up the window. Remove the inside door panel. Be careful with power window switch and door speaker wiring connectors. Disconnect them before pulling the door panel away. Remove any plastic covers that may be glued to the door. Have a look at the door handle from inside the door. You will have some idea as to how to remove it. Usually door handles are secured by screws from the inside. Locate and remove them. Remove linkages to the door handle then pull handle form outside.
Jul 20, 2014 | 2006 Ford Focus
Need to intall new front exterior drivers side door handle on a 2002 Hyundai Elantra GLS
remove the interior door trim and you will see small nuts holding the handle onto the outer door skin. Remove any rods /clips and undo the nuts and the handle will come out.
Mar 18, 2014 | Hyundai Motor 2002 Elantra
How to switch my door to other side
Remove hinges and screws, lay door on floor and remove screws around the edge of door then turn exterior of door around so handle is on the side you want (make sure the shape of gasket that seals the door is correct so it closes)and put screws back on edge of door . Remove all rubber plugs on side you now want to install hinges on and place hinges there . Remove door latch and place it on opposite , that should do you .
Feb 07, 2014 | Samsung DV422EWHDWR 7.2 Cu. Ft. Top Load...
Looking to replace the inside driver's side door
i believe after you remove the door panel you can access the inner door handle and remove it from the door shell
Aug 21, 2013 | Cars & Trucks
Remove inside door handle driver side hyundai elantra 2001
probably not. most inside door handles are push on and held with a spring clip that requires a flat tool that slides between the handle and the plastic washer or the plastic plug in the center of the handle prises out and ther will be a small screw to remove then the handle slips off. Normally the screw has a 8 mm head or a philips screw recess
Jan 10, 2013 | Hyundai Motor 1999 Elantra
Iload spark plug locations
they are at the rear of the engine against the bulk head side carborettor or injectors are here also if there is a plastic cover remove this they should be on the inlet manifold side of the engine hope this helps
Aug 25, 2012 | Hyundai H1 Cars & Trucks
Need to put passenger miror on. i need help to show me how to take the door panel off.
Section 01-05: Trim, Interior 1998 Windstar Workshop Manual REMOVAL AND INSTALLATION Procedure revision date: 01/22/1999 Trim Panel, Door Front
Removal
  1. Remove door latch cover by prying from top edge and pulling trim free of retaining clips and sliding trim away from latch.
  1. Remove portion of armrest containing door lock switch and window regulator control switch (14529) by pulling straight up.
  1. Remove rear view outside mirror mounting hole cover assembly by prying at top and pulling upward to release double-sided clip.
    Trim Panel
    Item Part Number Description 1 23942 Front Door Trim Panel 2 56908-S58 Screw (1 Req'd), Right Door 56906-S58 Screw (1 Req'd), Left Door 3 18B978 Radio Speaker Grille Name Plate 4 56911-S58 Screw (1 Req'd) 5 17D720 Cover Assembly Rear View Outside Mirror Mounting Hole
  1. Remove screw attaching front door trim panel (23942) to front door (20124) under switch plate.
  1. Remove two screws located at bottom of front door trim panel.
  1. Disconnect the door lock switch (14028) and window regulator control switch electrical connectors.
  1. Remove door window regulator handle if equipped by unsnapping and pivoting away the handle cover from base to expose retaining screw. Remove screw from the door window regulator handle.
  1. Pull front door trim panel from the top to release hooks from front door .
  1. Remove front door trim panel.
Installation
  1. Replace any bent or damaged fasteners.
  1. Follow removal procedure in reverse order.
Body Side
Removal
  1. Remove door handle retaining clip by sliding a shop towel between handle and door trim. With tension on the cloth, pull one end of the cloth so it slides between the handle and the door trim. If handle does not come out, reverse direction.
  1. Unfasten 13 christmas tree fasteners using double-acting spring-loaded trim removal tool and pull body side trim panel from body side door.
  1. Remove forward and rearward mating sections from under window trim.
Installation
  1. Replace all christmas tree fasteners.
  1. For installation of handle, install clip to handle, then push handle onto shaft to snap in place.
Back
Removal
  1. Disconnect rear window defroster wires.
  1. Remove the liftgate window garnish moulding as described.
  1. Remove screws attaching liftgate handle to liftgate and liftgate inside trim panel.
  1. Using Rotunda Windshield and Moulding Trim Removal Kit 107-R0401 or equivalent, pry pushpins retaining liftgate trim from the liftgate.
  1. Remove liftgate trim.
Installation
    Liftgate
2010&c18=modelyear&c35=wsm%2ctrim%20panel%2c%20door%2csww%2c01-05%2cremoval%20and%20installation&s=1366x768&c=32&j=1.3&v=y&k=y&bw=995&bh=405&ct=lan&hp=n&[aqe]
Mar 07, 2011 | 1998 Ford Windstar
Washing Machines Logo
52 people viewed this question
Top Washing Machines Experts
