Question about Sony SS-CT150 Sound Bar and Subwoofer -No Remote
Reset home soundbar
How do I reset my soundbar
How do I connect my Sharp HT-SB30 soundbar to Samsung UHD7500 TV
Should be able to use Bluetooth. Need to "pair" the devices (the TV and the soundbar). On soundbar, press On/Standby to power it on, press Input to select Bluetooth (pairing indicator blinks), press & hold pairing button until pairing indicator blinks quickly. Now go to the TV's setup menus: Sound > Speaker Settings > TV Speaker > SoundShare Settings, Add New Device=On, select the Sharp GT-SB30 from device list. If passcode, password, etc is needed, enter 4 zeros (0000). After the devices are paired. the pairing indicator on the soundbar should stop blinking. The pairing information should be retained so you only have to do this one time unless you do a full reset on the TV or soundbar.
Dec 23, 2014 | Samsung Audio Players & Recorders
SOUND BAR IS ON BUT SUBWOFFER DOESNT WANT TO TURN ON RED LIGHT IS ON BLUE LIGHT NOT ON
turn the soundbar off, then press and hold the reset button on the back of the subwoofer until the blue light starts blinking fast. the point the remote at the soundbar and hold the mute button until"ID SET" shows on the display. Then turn on the soundbar and it should find the sub and pair with it.
Sep 12, 2014 | Samsung HWE450 Wireless AirTrack Sound Bar
Having trouble getting the subwoofer and satellite speakers to work with the soundbar.
hello anonymus if your system is working and the soundbar does not
make sure you have the right connector to inject signal to soundbar some of them like you have has a tiny hole to reset it and dont forget to use the remote control i hope it works
Aug 25, 2014 | Vizio S4251w-B4 5.1 Soundbar System 5.1...
Soundbar wont work
It basically has an Optical input, or a coaxial input. Use whichever input is available for you from your TV digital output, to the soundbar. If it still doesn't work, the soundbar is probably damaged. For more information, please visit my website at audioserviceclinic.com. Thank you.
Nov 27, 2013 | Philips CSS2123B/F7 SoundBar Home Cinema
After the soundbar has been running for awhile the sound disappears. At that point I have to turn it off for a few minutes and turn it back on. After another period the sound will disappear again. This...
Hello, that sounds a power supply problem, maybe a bad capacitor or the amplifier chip is overheating, basically the board inside needs be checked and fixed.
Thanks
Nov 22, 2013 | Philips HTS8100 AmbiSound Soundbar DVD...
How to pair my soundbar and wireless lg soundbar
Press and hold the reset button on the back of the subwoofer until the light on the front starts blinking. Then with the soundbar turned on, press the stop button on the soundbar and the mute button on the remote at the same time. The display should say "REMATE". The sub light should stop blinking then and should be linked.
Feb 03, 2013 | LG Lsb316 Sound Bar With Wireless...
Soundbar will not turn on
1. Check the power cord is plugged in properly by removing it and replacing it. 2. Try a different outlet on the surge protector.3. Most surge protectors have a reset button, try resetting it.
Is the sound bar the only device plugged into the surge protector?
Oct 25, 2012 | Vizio VSB200 40" Soundbar - SRS...
We bought a Samsung Soundbar x810 but the Subwoofer does not seem to be working properly although the blue and red led light up. I have tried rebooting/resetting per user manual instructions but it still...
Purchased a x810 & everything tests out fine except TV signal sounds from cable box. We have the Comcast cable box connected to the 50" Samsung Plasma TV hooked up to Samsung x810 Soundbar all using HDMI cables. But we are not getting cable shows sound through Soundbar. Please advise
Nov 04, 2009 | Samsung HT-X810T Theater System
Reset my soundbar
Amp is probable going into protection mode. Disconnected all speaker and av wires (only power) and check if it switches on. Try to plugged it in also at another wallsocket. Presume PSU damaged by surge
Aug 12, 2009 | Philips SoundBar DVD Home Theater with...
How can I reset my Philips Soundbar system
You just remove batteries , unplug all cables, then put everything back together. This will reset the unit to factory settings.
May 15, 2009 | Philips SoundBar DVD Home Theater with...
Sony SS-CT150 Sound Bar and Subwoofer -No Remote Logo
80 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
