Question about Exercise & Fitness
Currently in the process of moving and I need to transport my treadmill. The problem isn't getting it out of the old house, it's getting it into the new house with a smaller door frame. Are there any directions on how to take it apart?
    Top Expert:
  • 12,223 Answers
See the video and fix it. God bless you
Posted on Jul 29, 2013
  • 74 Answers
SOURCE: I am moving and my treadmill won't fit thru the door
Follow the steps from the user/assembly manual in reverse. Find the manual here:
http://us.home.lifefitness.com/resources/content/8/2/0/documents/T3%20Manual.pdf
Installation begins around page 9
Posted on Aug 29, 2009
  • 13 Answers
SOURCE: I need to move the treadmill and can't find the
You will need to take out the screws on each side that holds the console to the uprights. When you lift up the right side of the console be carefull as you will need to disconnect the upright cable from the console cable. There is a clip to press as you pull the cable connectors apart. Tie a string around the cable connector that is in the upright cable that runs thru the upright as you will have to pull it out when reassembling. You can now lift the console off. You may be able to turn it on its side and fold the uprights down to carry it through the dorway. If it still won't fit, remove the struts too.
Posted on Oct 03, 2010
SOURCE: I have just received an Avanti 928 Swing arm
Hello, I also have a 928 and we removed the top section to get it through the door. Do you by any chance have the user manual as I was hoping you could scan a page for me.
Posted on Feb 18, 2011
  • 84 Answers
the console first and then the uprites that hold the console. that should be enough
Posted on Mar 08, 2011
StuartB
  • 807 Answers
SOURCE: my treadmill belt doesn't move at all
Contact the seller for help or send it back if it's only a month old, it must be under warranty.
Posted on Jan 25, 2012
Lost manual for roger black silver treadmill
see the video and proceed according., God bless you
Apr 03, 2013 | Exercise & Fitness
Lights come on but motor isn't working
1) adjust the REED switch, see the diagram clean it, tight the connector wires.
2) Lube the deck belt very well. VERY IMPORTANT
3) Lube the rollers bearing too,
4) Test the input voltage motor, if there are the Motor need repair
5) Test the output voltage board, for input voltage motor, if there are NOT the board is faulty.
God bless you
Sep 03, 2012 | NordicTrack Treadmill
Password reset
Procedure 2.3 - Accessing the User Parameter Program
This procedure allows you to change the following settings:
• Set Measurement Units
• Enable/Disable Password
• Set User Name
Procedure
1. Plug the power cord into the wall outlet, then turn on the treadmill with the circuit breaker.
2. Press keys STOP,5,6,7,1 sequentially.
3. The display will momentarily read SELECT UNITS
4. The currently selected measurement unit will then be displayed.
5. Use the UP, DOWN arrow keys to toggle between U.S. STANDARD and METRIC.
6. Press the ENTER key to select the currently displayed measurement unit.
7. The display will momentarily read, PASSWORD
8. Use the UP, DOWN arrow keys to select either PASSWORD ENABLED or PASSWORD DISABLED
9. Press the STOP or ENTER key to exit the program.
Aug 24, 2012 | Precor 9.31 Treadmill
My treadmill belt doesn't move at all
Jan 25, 2012 | FreeMotion Exercise & Fitness
Healthrider s300i treadmill does not turn on
Check the fuses under the lower hood. One should be a 10 amp fues, the other should be 15 amp fuse.
Replace them if blown. If they should blow again, move the treadmil to an outlet closer to the fuse box/breaker box of the house. the house wiring where you have the treadmill may not be adequate for the treadmill.
Jan 24, 2012 | HEALTHRIDER Exercise & Fitness
I want to install a vinotemp Model: VT-TC32SB. Currently, there is a trash compactor in the space. If I pull the trash compactor out, can I just slide the fridge in place? The countertop and cabinets are...
Hi, It depends a little bit on how your trash compactor and cabinetry are currently set up. Some people have a tough time getting the trash compactor out/cooler in because of the lip that comes down off their counter. However, if you can pull one out, you "should" be able to just slide the other one in. Likewise, you'll need to be sure there is an electrical outlet available in the space. Usually, this isn't a problem as your new Vinotemp will plug right in where the trash compactor was plugged in. But in very old houses sometimes the trash compactor was wired right into the electrical. As long as your counter/cabinets were designed with enough room to move units in/out, this change should go smoothly for you. Best of luck!
Aug 30, 2011 | Refrigerators
Can passive and active transport occur in dead cell?Explain
The definitive answer is: it depends. It depends on how the cell "died". Most forms of cell death include getting holes in the membrane, and if that happens any type of transport (active or passive) is pretty much impossible. The transport proteins might still be working, but whatever they're moving across the membrane would just leak back through the holes, so there's no transport. If there aren't holes in the membrane, then passive transport should still work. For active transport, it depends again. Usually for active transport you just need the transporter and an energy source (like ATP). As long as the energy source is still around, active transport will still go on. Chances are, though, that the dead cell isn't making more ATP as the old is used up, so pretty soon it will run out and active transport will stop. Other forms of active transport don't use ATP directly, but they still count on the cell using energy. When the cell dies, those transporters will also stop working before long.
Aug 08, 2011 | Health & Beauty
I was shifting from reverse to drive and all of the sudden it won't work. Have had no problems with it whatsoever. I have been hearing a tapping sound, but thought it was coming from and exhaust leak...
If an automatic- older model- crawl under and have some one shift back and forth. Something is going to move and the thing it's supposed to move won't. there might be some cheap plastik connector broke or some spring clamp to hold the outer cable steady poped off. It will be real simple.
Get the toddler a helmet!
May 26, 2011 | Chevrolet TrailBlazer EXT Cars & Trucks
3 days old and when I push any of the buttons that are supposed to cause belt to start moving or to change incline there in no response, though the electronic display starts counting the seconds as if it...
The single most cause of no motor output is failure of the DC motor control Look for any test lights on the power boards beneath the motor shroud use caution when removing the motor hood because you may still have electricity in the motor area even if the treadmill is unplugged.
One of the lights should be labeled PWM when hitting the start button that will start flickering , because the upper console is sending a signal to the lower board telling it to start the motor. if that process happens then you need to check the motor
Cordless drill battery- get a fully-charged, 18 volt (preferred) cordless drill battery and on most treadmills connect the red and black motor leads to the battery (some have different colors but if you have two wires and get it hooked up backwards, the motor will just run backwards and won’t be harmed). If good, the motor should operate at about 1 MPH.
Car battery- these are 12VDC high amp batteries so the motor will turn slowly but you can walk on the belt. Always be careful with battery acid on these things so we don’t recommend bringing them in the house…take the treadmill to the battery. If does move then the controller board needs to be replace.
May 24, 2010 | Nordic Track NordicTrack Elite 9500 PRO...
9100 life fitness treadmill
Sounds like you need a new lower board replacement. You can get that for that treadmill by call lifefitness or sportsmith.com Please rate me good
Apr 22, 2009 | Life Fitness 9100 Next Generation...
Exercise & Fitness Logo
128 people viewed this question
Top Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
