Question about Metra 99-5717 2004-2007 Ford Taurus Radio Dash Kit
Why would 2007 taurus not start and say low oil l pressure
Car won't start (no sound either)- was parked w/ tires turned and steering wheel locked; message center read "low oil pressure"and battery fine. Next day,straightened out steering but still no start. What is keeping the car from starting
    Top Expert:
  • Metra Master
  • 49,327 Answers
Have the battery load tested as a cell may have failed and you will not have enough current to engage the starter
Posted on Aug 02, 2013
Hissing sound when turning steering wheel to MAX turn, low speed
the noise is normal your maxing out the hydraulics in the lines [only does it when wheel is turned to max either way] the noise goes away when u release its max position
Jun 01, 2015 | 2006 Chevrolet Impala
2007 ford taurus w/ locked steering wheel and car won't start
try pulling the steering wheel slightly to one side and turning the key to unlock the steering wheel
Jul 28, 2013 | Cars & Trucks
1997 taurus key won't turn in the ignition, gear selector won't go into gears
Usually a sign the tumblers in the lock cylinder have worn out or jammed.
You may have to get the lock cylinder drilled out and replaced.
Jan 13, 2013 | 1997 Ford Taurus
Why won't my ignition key turn over and my steering wheel is locked in place at the sametime?
I'm assuming you mean your key wont turn in the ignition. first off check to make sure the car is in park. then what you gotta do is put in the key and put a little pressure as if turning but dont turn too hard, then even though the steering wheel is locked you will have to try to move it a little, if you parked with your tires turned then you will want to try to turn the wheel in the same direction, (even locked you should be able to move it about a half inch) you will have to turn the wheel hard but it should move enough to allow the key to turn, you may have to jiggle the key a little in the ignition but it should eventually turn, just remember not to try turning the key too hard, the extra force wont make it go but can cause the key to break. this tends to happen when you turn the car off andthe steering wheel gets locked if the wheels are turned hard in either direction. also if multiple attempts at this still dont work, try taking the key out and turning it over and trying again. Even though both sides of the key are identicle, because of wear on the key and the ignition, sometimes when the wheel locks the ignition, it will only turn if the key is put in a certain way. Hope this helps, good luck
Aug 29, 2012 | 2002 Pontiac Montana
Ford 1993 Taurus steering
Have you checked the power steering fluid level? The reservoir for the fluid will be at the front of the engine, where the belt runs the power steering pump. If it's low or out add a little power steering fluid till full, then start car and slowly turn wheels back and forth from stop to stop-not too ******* the stops (when the steering won't turn further that way...that's what I mean by stops)....Turn wheel one way full travel, then reverse and turn the other way. Check the fluid level again, and add as needed.
If fluid is not low, the belt may be too loose to make the power steering pump work, or you may have a bigger problem that needs professional attewntion.
May 24, 2012 | 1993 Ford Taurus
How do I check power steering/it keeps coming on and now my steering is very constricted?
If its EPS (Electronic Power Steering) it's better to diagnose it in a local repairshop.
If it's a hydraulic system - check the fluid level, refill if low. Check for leaks starting at the pump, the hoses and the power unit at the steering wheel.
Front tire pressure shouldn't be too low. Low tire pressure stresses the power steering unit to the max.
Jul 02, 2011 | 2005 Chevrolet Malibu
My shifter is stuck in park
If the steering wheel is turned the continue to turn the steering wheel in the same direction as the tires are going while applying firm pressure to the brake the try to pull it out of park. I know this sounds crazy but they have so many safety swithches on them, you may have one not activating.
Feb 07, 2010 | 2007 Chevrolet Monte Carlo
Steering wheel very hard to turn left or right
Check and fill power steering fluid. If this won't help the power steering pump might be faulty.
Nov 26, 2009 | 1990 Toyota Pickup
Metra 99-5717 2004-2007 Ford Taurus Radio Dash Kit Logo
64 people viewed this question
Top Metra Car Audio & Video Experts
xxxxxx xxx
Are you a Metra Car Audio and Video Expert? Answer questions, earn points and help others
