Question about Koolatron CVF18 Coca-Cola Retro 10-Can-Capacity Vending
Green light on refrigerator will not come on
Power cord is working but the green light on the refrigerator will not come on.
Model E402b. Why is the alarm going off?
Fridge keeps beeping or buzzing: The following is for Frigidaire models but others can be addressed similarly.
Several Frigidaire refrigerator models have an electronic control panel on the freezer door the owner can use to adjust the internal temperature, dispense ice and water and receive notification about issues such as the need to replace a water filter. The refrigerators also emit a beep for various actions and as an occasional alarm. Determining what causes the beeps necessitates some troubleshooting.
Temperature Controls ·A Frigidaire refrigerator's display panel blinks when the control panel is touched to set temperature controls. After pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, press the arrow buttons within five seconds to increase or decrease the desired temperature. If you do not press the arrow buttons within five seconds after pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, the refrigerator beeps to indicate the current setting will stay in place.
Door Open ·When you leave the refrigerator or freezer door open, the refrigerator beeps. Also, the "Door Ajar" indicator illuminates on the appliance's display panel. Shutting the door and pressing "Alarm Reset" stops the beeping and turns off the "Door Ajar" indicator light.
·The Frigidaire refrigerator has a control lock feature that prevents use of its control panel or dispensers when the unit is locked. When the control lock is active, a beep sounds when a keypad or dispenser is pressed. Release the control lock by pressing the "Control Lock" icon for three seconds. A beep will sound, and the icon's light will go out.
Power Reset ·A power reset is occasionally necessary if the Frigidaire refrigerator's control panel does not work normally or a reset function on the keypad does not work. A power reset involves disconnecting power to the refrigerator by unplugging its power cord from the electrical outlet, waiting 30 seconds and plugging the power cord back into the electrical outlet. When the control panel resets, a beep sounds. If the refrigerator beeps even after a power reset and the beeps' source is not known, contact Frigidaire.
Read more :http://www.ehow.com/info_12148688_cause-beeping-noise-frigidaire-refrigerator.html
Cause of Beeping Noise in Frigidaire Refrigerator eHow Cause of Beeping Noise in Frigidaire Refrigerator eHow
Jun 02, 2015 | Fisher and Paykel Refrigerators
Open door 18 beeps lights flash red green fridge not cooling
Mar 14, 2015 | Refrigerators
Light for filter does not turn green
Hi friend, thanks for your post!
I see that your filter light is not turning green on the panel of your Frigidaire refrigerator. If you have recently changed your filter I would suggest pressing and holding the filter reset button. Should that not correct the issue I would perform a reset on your refrigerator and you can do that by unplugging your power cord or flipping the household circuit breaker off for roughly ten minutes. I hope this has been beneficial. -Matt
Oct 10, 2014 | Frigidaire Refrigerators
Why does my garman not come on when plugged into car power source, and power light shows green light?
Your car adapter wiring might be faulty.. Green light shows it is receiving power from your cig socket but there isn't any power from the adapter to the plug to your gps..
Jul 19, 2014 | Garmin nuvi 1450 GPS Receiver
R60 Wont Charge
What's the make and model of your laptop? Most times the flashing lights will tell what the issue is.
If the laptop will not boot up so you can use it then the things below applies.
Sounds like your power cord is bad. Or the DC Jack is not soldered on good. Just because the power cord is new does not mean it works. Some Power Cords have a little green light on the adapter to show that it is plugged into the wall and getting power, check yours.
Anything ever post to the screen when you hit the power button? Do the fans start up, the hard drive spins? If not, maybe your power cord has enough power to emit a light but not enough to start the fan or disk drive.
If it's not the power cord or dc jack, then you have a Memory or Video Card issue.
OK after reading your post a 2nd time I think your only issue is that the battery is not charging, correct? If that is true the things below applies:
Either the battery is bad or the power cord is bad. Just because they are new don't mean they work. See if the Adapter portion of the power cord has a green indicator light that comes on when you plug it to an outlet. If it does, and that light is not on the power cord has issues. Also I hope you did not buy one of those one size fits all power cords from the big box stores where the end has a bag of different interchangable parts until you find one that fits into the laptop. If so, buy a power cord off ebay that is made for your laptop.
The battery might be bad and not hold a charge. I have seen new batteries that did not work.
May 16, 2012 | Computers & Internet
Drive stopped working
I had the same problem - green light on power cord but when plugged in the green light would go off and the hard drive would do nothing. I took it into Geek Squad finally and it turned out that the problem was hard drive casing, which I had to have replaced.
Jun 07, 2009 | Western Digital 500GB ELEMENTS 500 GB USB...
Green light flashing on back of unit near power cord also green light flashing on motherboard near power supply plug in.
I would suggest trying to replace the power supply. If that does not fix the issue, i would need to hear more about the computer.
May 06, 2009 | Sony VAIO VGC-RB40 PC Desktop
Laptop won't turn on/stay on
Is the fan blocked?
If no air goes in, CPU could overheat.
Aug 26, 2008 | Toshiba Satellite 1135-S125 Notebook
Koolatron CVF18 Coca-Cola Retro 10-Can-Capacity Vending Logo
60 people viewed this question
Top Koolatron Refrigerators Experts
Ilia Bichin
richie46
Your Consultant
Are you a Koolatron Refrigerator Expert? Answer questions, earn points and help others
