Question about Boost Mobile Kyocera Hydro Smartphone
Kyrocera hydro boost phone bottom buttons do not work
The bottom buttons stopped working....Happened before but my son talked to someone and they said it was a "bug" walked him thru step by step, for awile it cleared up, now they don't work again...the 4 buttons at the bottom....I can accesss pages on my home page, but if i want to go back to my home page, i can't....the home page button does not work, the back arrow button does not work....nothing on the bottom works....to get back to my main page, i have to shut it down and start it up again! This phone was purchased for like 75.00 a month or 2 ago! Way too much money to spend not to mention the service for 50.00 or 55.00 a month, and then the phone doesn't work now? on a new phone!? very very annoyed!
  • Katelynn Boden
    Katelynn Boden Feb 20, 2014
    Mine phone (Kyocera Hydro) just started doing this same exact problem. I just got it for christmas about two months ago. Does anyone know if you can fix it or do you have to get a replacement?
  • Anonymous Mar 30, 2014
    the buttons on the bottom of the phone dont work
    Problem Solver:
  • 17 Answers
Almost all electronics come with a 1 year warranty. Since this is a manufacturers defect then it would be covered under that warranty. Contact your service provider for a replacement. If they give you the run around then contact Kyocera.
Posted on Jul 28, 2013
2 Suggested Answers
  • 13 Answers
SOURCE: Why does my phone say no service and won't connect to the network?
Its a 3G phone from what it looks like so there is no SIM card to worry about I assume. If there is a SIM card I would replace that right off the bat. I would go back in and make the store fix the phone or do a manufacture warranty replacement on it. I am surprised they didn't resolve things in the store.
Posted on May 23, 2013
Can someone tell me if the hydro boost could
Depends on the car and the problem.
The hydro-boost gets pressure from the power steering pump on some models, so the pump could affect the hydro-boost but usually not the other way around. You could disconnect the hydro-boost lines and the power steering should still work.
Sep 19, 2014 | Cars & Trucks
How can I get my kyocera hydro phone to stop running slow?
Disable 3G and data roaming except when you need to access internet.
May 12, 2014 | Boost Mobile Kyocera Hydro Smartphone
My kyocera hydro edge was in water for 2 hours and wont turn on
my daughter dropped her iphone in the pool. we put it in sealed plastic bag of rice for three days and that took the water out and it worked. u might try this
Apr 13, 2014 | Boost Mobile Kyocera Hydro Smartphone
How to remove lcd screen on kyrocera hydro
  • Remove the battery cover from the back side of the cell phone. Remove the battery from its compartment and set it aside.
  • Use the screwdriver to remove the Phillips-head screws from the back panel of the cell phone. You may also need to remove the antenna from its retaining slot and remove it from the cell phone if you can
  • Separate the back panel of the cell phone from the rest of the cell phone's body. Place the cell phone face up and then remove the cell phone's faceplate from the rest of the cell phone. This should leave the LCD screen, keypad and circuit board completely exposed.
  • Tilt the LCD screen downward and then disconnect the LCD screen's ribbon cable from the LCD screen and set the screen aside.
  • Repeat this procedure in reverse to replace the LCD screen and reassemble the cell phone.
Mar 17, 2014 | Boost Mobile Kyocera Hydro Smartphone
My brakes and power-steering are not working. The brake pedal is hard, but the brakes will not engage. The power steering was not working at the same time. It has brake fluid, but when I took the power...
Yes, your brakes are boosted by the power steering pump rather than by vacuum. I don't think it's air in the system. More likely your pump has failed, but you can try bleeding the pump. Here is a procedure from autozone.com:
Observe the following:
Use clean, new power steering fluid type only Hoses touching the frame, body or engine may cause system noise. Verify that the hoses do not touch any other part of the vehicle. Loose connections may not leak, but could allow air into the steering system. Verify that all hose connections are tight.
NOTE Power steering fluid level must be maintained throughout bleed procedure.
  1. Fill pump reservoir with fluid to minimum system level, FULL COLD level, or middle of hash mark on cap stick fluid level indicator.
    NOTE With hydro-boost only, the oil level will appear falsely high if the hydro-boost accumulator is not fully charged. Do not apply the brake pedal with the engine OFF . This will discharge the hydro-boost accumulator.
  2. If equipped with hydro-boost, fully charge the hydro-boost accumulator using the following procedure:
    1. Start the engine.
    2. Firmly apply the brake pedal 10-15 times.
    3. Turn the engine OFF
  3. Raise the vehicle until the front wheels are off the ground.
  4. With key in the ON position and the engine OFF , turn the steering wheel from stop to stop 12 times. Vehicles equipped with hydro-boost systems or longer length power steering hoses may require turns up to 15 to 20 stop to stops.
  5. Verify power steering fluid level per operating specification.
  6. Start the engine. Rotate steering wheel from left to right. Check for sign of cavitation or fluid aeration (pump noise/whining).
  7. Verify the fluid level. Repeat the bleed procedure if necessary.
Oct 24, 2010 | 2005 Chevrolet Silverado
Boost Mobile Kyocera Hydro Smartphone Logo
304 people viewed this question
Top Boost Mobile Cell Phones Experts
John mullen
Lawrence Oravetz
Are you a Boost Mobile Cell Phone Expert? Answer questions, earn points and help others
