Question about Port Incorporated 2007-2010 Honda CR-V Receiver 4XN0
Broken Aux port in Saturn Vue 2007
The little plastic ring that keeps my plug tight in the aux port broke. Best Buy says the entire radio has to be replaced. Is there a way to fix this or replace the aux port without the entire radio system?
Is the aux port on the right side of the glove compartment in a chevy uplander 2007? It is also hard to pull, will it break?
About 23,400 results (0.81 seconds) Search Results
    Plug in glove box?? ' VW TDI forum, Audi, Porsche, and Chevy Cruze ...
    www.myturbodiesel.com/threads/plug-in-glove-box.16414/
    Oct 22, 2012 - 17 posts - ‎8 authors
    Asked vw and they said it is a iPod/mp3 player port. Plugged in ... 06 jetta tdi and there is a plug in my glove box that looks like a headphone jack. Asked vw ... Joined: May 23, 2007 ... Try pressing CD twice to go to aux input .... box. It is locateded on the farright side where the light is on most mk5 models.Missing: uplander
    Head unit "Aux" input information... - Suzuki Forums: Suzuki Forum ...
    www.suzuki-forums.com/.../14338-head-unit-aux-input-information.htm...
    Jun 28, 2006 - 10 posts - ‎5 authors
    This cable gives you an AUX input into the stereo, so you can listen to ... There is a plastic damper attached to the right side of the glove box (a ...Missing: uplander
    [PDF]Get To Know Guide - Chevrolet Owner Center
    https://my.chevrolet.com/.../2007/chevrolet/uplander/2007_che...
    ChevroletR. Glove Box. Getting to Know Your. Uplander. 2. See Section 3 of your Owner Manual. Instrument Panel. DRIVER INFORMATION. Uplander 2007 A 7/24/06 ...
    Only Driver's side speakers working when using the aux input on
Feb 03, 2016 | 2007 Chevrolet Chevrolet Uplander
Aux input
cheap is an FM adapter but they are horrible bat sound quality
the best way is using a Dodge aux input adapter , they cost that much because there is a lot of electronics involve inside this box, the interface tricks the radio to open the external CD changer port you can buy the interface from here use Summer coupon for %10 off
Dodge aux input
May 13, 2013 | 2006 Dodge Grand Caravan
My aux cord broke off too, while playing my ipod, how do i remove it? The little metal piece is pretty deep in the aux connection. I have a 2007 nissan altima, does anyone know how to remove it? Thanks....
try to super glue a small nail head to the metal in the radio. Don't use to much glue! just a small drop. Hold till it dries and pull up to rest of the plug
Oct 02, 2009 | Car Audio & Video
Where is the aux plug for this radio; Eclipse's optional Rockford Fosgate premium audio system
The Mitsubishi Eclipse with the Rockford Fosgate premium audio system does not actually have an aux plug. When you are scrolling through the sources, one of them listed is an AUX. This implies that there is a headphone jack somewhere in the vehicle where you can plug an iPod into and play it through the system. The port, however, was never actually installed on all pre-2009 eclipses.
The only way to access this feature of the stereo is to obtain an AUX cable from the mitsubishi dealer, which will be a wire harness that connects to the back of the head unit and provides an additional AUX port cable allowing you to plug in your iPod. You can talk to your local mitsubishi dealer about the cable, from what I hear, its rather expensive, and then go to best buy, somewhere similar, to have them install it.
Aug 06, 2009 | Rockford Fosgate Car Audio & Video
Aux input location
Though I'm sure there is an AUX button on the radio, there isn't actually an auxillary port on a 2007 Grand Prix stock radio.I'm sorry to say, but you would have to get an aftermarket radio.
Mar 11, 2009 | 2007 Pontiac Grand Prix GXP Sedan
Aux cable stuck in Aux input
needdle nose plyers or you can use a screw just turn and pull
Jan 25, 2009 | 2007 Nissan Sentra 2.0 SL Sedan
Aux cable snapped of inside external Audio port (AUX). an ideas on how to get the piece out? or does anyone now how to take the AUX port out of the console? 2008 crv, center console unit.
I have a 2007 CRV which had the same issue. I fixed this by:
- first removing the AUX port cover by carefully prying it up from both the rear-facing and front-facing edges. Once done, this exposes the AUX port mechanism itself.
- Using some needlenose plyers, I pulled out the AUX port component. It simply slides out.
- The trick now is to PUSH the broken piece out of the inside of the port. To do this, I first removed the "cover" that is covering the end of the port (opposite from the opening to the port). Be very careful with this step as you don't want to break the cover. It's very thin plastic.
- Once this cover is removed, I used a pin to push the piece that was lodged inside back out of the opening.
Reassembly was the opposite of this and was quick.
Hope that helps.
- Dave
Nov 19, 2008 | 2007 Honda CR-V
Sirius radio connection
Yes, just plug it into the AUX port and keep pressing the mode button until it says "AUX" on the display!
Dec 27, 2007 | Car Audio & Video
Port Incorporated 2007-2010 Honda CR-V Receiver 4XN0 Logo
48 people viewed this question
Top Port Incorporated Car Audio & Video Experts
xxxxxx xxx
Are you a Port Incorporated Car Audio and Video Expert? Answer questions, earn points and help others
