Restore command line prompt on mac - Computers & Internet
    Problem Solver:
  • 11 Answers
You would need to be more specific. Mac operating system being run? Mac model? Where are you trying find the command line? It's in utilities - Terminal on OSX.
Posted on Aug 01, 2013
I need to restore my computer without disc, what should I write in command prompt?
To access the System Restore Gui from command prompt you will need to type in rstrui.exe
OR
%Windir%\System32\rstrui.exe
Other Thoughts
If you are experiencing Boot issues you will need to install a boot manager. If your system is missing a file or a file is broken, you may need to replace that file with a working version that's compatible with your OS Version.
Aug 07, 2015 | Dell OptiPlex GX270 PC Desktop
Tip
How to find your MAC address using MS-DOS
The MAC address is the physical address your computer's Ethernet card or network interface card (NIC) uses to identify itself to other computers and devices on your network. There are different ways to find your Ethernet card's MAC address, depending on what operating system and programs you have installed. Since most Windows-based computers have access to the MS-DOS command prompt, using DOS to find your MAC address is one standard way to do it.
There are a couple of different tools you can use in MS-DOS to find your MAC address. All of them requiring opening a command prompt window, which you can do by typing "cmd" into the Run bar on the Start menu (or in Windows Vista or 7, you can type it into the Search bar instead).
- Getmac
Getmac is a utility that is included on Windows Vista computers and on newer Windows XP systems. Typing "getmac" by itself on a command line will return the MAC addresses of any NICs that you have installed in your computer. (If you have an Ethernet NIC and a wireless NIC, for example, Getmac will list the MAC addresses for both of them.)
- Ipconfig
Ipconfig is a command that will display your IP address if you are currently connected to a network. However, by adding the "/all" switch to it, you can also see your MAC address, as well as many other configuration settings. Type "ipconfig /all" and look for the line labeled "Physical Address." If you have more than one NIC, the MAC address for each NIC will be displayed separately.
on Oct 04, 2010 | Microsoft MSDOS 6 Upgrade Operating System
Cant find my mac address
Assuming this is a Microsoft Windows system...
Click on Start
Then either Run (Windows XP)
Or just type into the dialogue box above the Start button (Windows 7)
Type in: CMD and press Enter
In the black window next to the >
Type in ipconfig /all and press Enter
In the output look for the Physical Address in the 12 character alpha-numeric format of:
xx-xx-xx-xx-xx-xx
This is the MAC address
Jun 02, 2011 | Computers & Internet
The MAC address sticker on the bottom of my Toshiba Satellite A215 is so worn I can't read the MAC ID. Where can I get the MAC ID for this machine? (just purchased used) everything else works...
If you are running Windows...
Go to Start Run (or hit the Windows key and the letter "R" simultaneously on your keyboard) and type cmd. crasher35_14.jpg
Once in the command prompt, type "ipconfig /all" crasher35_15.jpg
It will give you a lot of information, but what you are looking for is the line labeled "Physical Address." crasher35_16.jpg
You may have more than one device listed depending on how many network devices you have installed (such as a wireless adapter, a virtual adapter, or a second network interface card). Look at the description to help determine which one it is you need.
May 29, 2011 | Computers & Internet
Lost the stick on back of modeme try find MAC ID for SBG900
Open up a command line prompt (Start>Run>cmd
At the command (C:\) type the following: arp -a
That should give you the IP Address and Physical (MAC) address of your router.
Good Luck
James
Apr 17, 2011 | Arris SURFboard SBG900 (49402201900) Modem
How do you do a system restore on an acer extensa 4420-5963? Can you use a "F" key on start up?
you have 2 ways to carry out an system restore
1. start / programes / Accessories / System tools / system restore
OR
To start System Restore using the Command prompt, follow these steps:
?? Restart your computer, and then press and hold F8 during the initial startup to start your computer in safe mode with a Command prompt.
?? Use the arrow keys to select the Safe mode with a Command prompt option.
?? If you are prompted to select an operating system, use the arrow keys to select the appropriate operating system for your computer, and then press ENTER.
?? Log on as an administrator or with an account that has administrator credentials.
?? At the command prompt, type %systemroot%\system32\restore\rstrui.exe, and then press ENTER.
?? Follow the instructions that appear on the screen to restore your computer to a functional state.
Dec 19, 2010 | Computers & Internet
Can't log-in in mac os x
I'm assuming that you have forgotten your password, if so, here is what you need to do.
1. With the unit turned off, press the power button to power-on the mac, but also hold down the "CMD" and "C" keys on the keyboard at the same time. This will tell the Mac that you want to boot into SINGLE USER MODE.
2. Mac OS will now boot into a unix command line shell. From here you only need to remember your username and then type in the following command-line statements.
sh /etc/rc passwd USERNAME reboot
In this instance, USERNAME is the username that you normally login as. The "passwd" command will prompt you to enter a new password for the user called USERNAME.
WARNING: Changing your password this way will wipe out any and all keychain passwords associated with your user account. This is a pain, but better than not logging into the box.
May 19, 2010 | Apple Mac OS X 10.4 Tiger for Mac
How do I restore factory settings to a zebra barcode printer LP-2844-Z
The ^default command has been added to the EPL2 commands, starting in firmware version 4.39. This command will set the printer back to factory settings as long as the printer is in page mode. The command is not supported in line mode at this time. The command is case sensitive.
Syntax: ^default.
You can send the command to the printer via the parallel or serial port.
Parallel:
Open command prompt (DOS prompt) See windows instructions for details.
At the prompt type:
ECHO ^default>LPT1 <enter>
Serial:
Assuming standard communications on the printer of Baud 9600, No parity, 8 bits, 1 stop bit and use of COM 1:
At the prompt type:
Mode Com1:9600,n,8,1 <enter>
ECHO ^default>COM1 <enter>
Feb 02, 2010 | Zebra LP 2844 Thermal Printer
Reinstalling Contribute 3
Hi,this is how you can re-install Contribute 3 .
Make sure that you un-install previous installation first and then follow these steps to re-install.
You can either click on
http://kb.adobe.com/selfservice/viewContent.do?externalId=tn_19596 or
Copy the Contribute_Installer.msi from the FSCOMMAND folder on the CD to C:\.
  1. Bring up the Command Prompt program from Start > Programs> Accessories > Command Prompt.
  2. If Contribute is already installed then uninstall Contribute which will also automatically uninstall FlashPaper. To uninstall Contribute 3 you can go to Control Panel > Add/Remove programs and select Macromedia Contribute, or use the command line with the following line of code:
    C:\>msiexec /X ?C:\Contribute_Installer.msi"
  3. Run the Installer from command line as follows.Note: The syntax must be exact for this command to execute. If spaces or extra characters are added, the install will not work. Here is the command:
C:\>msiexec /I "C:\Contribute_Installer.msi" ADDLOCAL=ConfigurationFiles,MLM,DesktopShortcut,QuicklaunchShortcut,ProgramFiles,HelpFiles,Contribute
  1. After the command has executed, enter exit to close the Command Prompt window.
After the install has completed you will be prompted to enter the serial number again. If there are any problems, remove Contribute, using step three above. Then, repeat step four to run the installer again.
May 29, 2008 | Macromedia Contribute 3 And FlashPaper 2...
How to Find the Ethernet Adapter's MAC Address
Follow these instructions to find your adapter's Media Access Control address (MAC address). This is not the same as a Macintosh computer, it is a fixed string built in to the hardware, that uniquely identifies a computer device. Windows 2003 1. Click Start > Run. A command prompt window appears. 2. Type cmd. 3. Type ipconfig/all. (no spaces around the /) 4. Copy down the "Physical Address" (aka the MAC address) on a paper where you keep your network configuration settings. 5. You may close the command prompt window. Windows XP 1. Click Start > Run. A command prompt window appears. 2. Type cmd. 3. Type ipconfig/all. 4. Copy down the "Physical Address" (aka the MAC address) on a paper where you keep your network configuration settings. 5. You may close the command prompt window. Windows 2000 1. Click Start > Programs > Accessories > Command Prompt. A command prompt window appears. 2. Type ipconfig /all. 3. Copy down the "Physical Address" (aka the MAC address) on a paper where you keep your network configuration settings. 4. You may close the command prompt window. Windows 95 and Windows 98 1. Click Start > Run. A command prompt window appears. 2. Type winipcfg. 3. Click OK. 4. Copy down the "Adapter Address" (the MAC address) on a paper where you keep your network configuration settings. 5. You may close the command prompt window. Windows NT 1. Click Start > Programs > MS-DOS Prompt. A command prompt window appears. 2. Type ipconfig /all. 3. Copy down the "Physical Address" (aka the MAC address) on a paper where you keep your network configuration settings. 4. You may close the command prompt window. Macintosh OS (10.3.5) These instructions also work for some earlier OS. 1. Click Apple Menu at top left > System Preferences > Network icon. 2. Select Show: Built-in Ethernet in the pull down menu. 3. Click Ethernet. 4. Your adapter's MAC address is the characters in Ethernet ID.
Feb 19, 2006 | NetGear CG814M Wireless Cable Modem...
Computers & Internet Logo
David Payne
David Payne
