Digidoor 2 drive nut
The carriage assembly opens by itself as soon as it starts to open the door.
SOURCE: Carriage Jam
I FIXED MINE YES... open your thing.. and look,... do you notice..
theirs like a small black.. corner shaped thing, that stopped the carriage..
pop that thing like add force to push it back...
boo ya. :) and their you go...
this problem annoyed me for a month. and i went through numerous hp printers too.
but, just...... really open your eyes and try to find out whatsup..
:) woot woot woot imma print stuff now.
Posted on May 11, 2008
adonscott
  • 106 Answers
SOURCE: carriage jam error
Here is the document that i want you to follow exactly in order to resolve your issue.
CLICK HERE TO VIEW THE DOCUMENT.==>> DOCUMENT
Please let me know the result after following the document.
Thank you so much. I remain.
adonscott
Posted on Jul 24, 2008
myob247
  • 1342 Answers
SOURCE: Error: Carriage jam
Click Here for HP's solution to this problem.
Posted on Jul 26, 2008
rockfixya
  • 679 Answers
SOURCE: psc 2110 carriage jam
SolutionStep one: Perform a power reset and connect the printer directly into the electrical outlet Remove all the paper loaded in the main input tray.
Make sure that the product is turned off.
Disconnect the USB cable from the back of the product.
Disconnect the power cord from the product.
Disconnect the power cord from the electrical outlet and wait 10 seconds.
Reconnect the power cord directly into the electrical outlet and check for the following.
Make sure that the power cord used is the one provided with the product.
If a computer is connected to the product, make sure that the computer is connected to a grounded (three-prong) wall outlet.
Make sure that the power cord is firmly connected to both the product and the power supply.
Reconnect the power cord to the back of the product.
Press the power button ( ) to turn on the product.
Reconnect the USB cable to the back of the product.
If the issue is resolved, proceed to Step six: Print a self-test page.
If the issue continues, proceed to the next step.
for more information please go to below link>>
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01458822&cc=us&lc=en&dlc=en
Thanks for using FixYa.
Posted on Feb 03, 2009
rockfixya
  • 679 Answers
SOURCE: HP Officejet 7410 "carriage jam"
How do I get a free service manual for digidoor 24 garage door opener
Your first problem is you bought a digidoor garage door opener. But check their website, or call the manufacture. You will either be able to download the manual or have to buy a one directly.
Mar 28, 2015 | Building Materials
How do I program a Digidoor 3 garage motor.
Limits must be programed. Power down and remove battery power ,press & hold button on motor pc board then apply power still holding button. The door should start running open and close. When it starts you can release button
Oct 31, 2014 | Building Materials
I bought a second hand Digidoor 1 with garage door. The door opens and closes perfectly when the digidoor is off. When I power up the digidoor the motor will not open the garage door when the door is...
You are receiving interference from the digi door. You will have to return this unit and go with a different one on a different frequency. Chamberlain makes a clicker that would work well with that unit. Thanks BB
Sep 21, 2010 | liftmaster Chamberlain Garage Door Opener...
Digidoor 3 garage door only opens about 60cm and stops. Was not given a manual by installer.
The problem might actually be the door itself. make sure it raises and lowers easily and is well balanced. If it is then find the power adjustments and turn up the up force to work the door. Do a 2x4 safety reversal test afterward. Thanks BB
Aug 24, 2010 | liftmaster Chamberlain Garage Door Opener...
Fairley new opener but it unhooks from the Carriage Assembly once every 5th time
sounds like the carriage is coming of the connector and that usually happens when the cariage travels to far and bumps the power head of the machine that split second **** is enough to unhook it fro the carriage because the next motion would be coming down and probably without the door attached to the connector , and by connector i mean the other half of the carriage Remedie ;; adjust the open door travel to not come up as high let it stop about 2 inches before the machine and that should fix-it , Thank you and hopefully i was able to help you please leave a good rating if i was able to help Sincerely Glenn Mayer ....mayer overhead door co,
Mar 04, 2009 | Sears Craftsman LiftMaster Chamberlain...
Need to replace carriage on stanley sd450 opener how is it done?
Please make sure you don't have broken springs first and that the door is balanced properly. If so you can replace the "Trolly" by disconnecting the arm from the opener, undoing the opener from the bracket that mounts it to the wall. This usually takes a 1/2 in wrench. Then swing the opener out far enough to slide the trolly off and replace it with a new one. Re-connect everything then re-engage the trolly.
Oct 25, 2008 | Chamberlain Powerdrive PD422D 1/2 HP...
k24674
jasbo
jasbo
