Lg Region Code for dp932H - Televison & Video
Region free code for LG Blu ray BP125
can the lg bd 125 be made region free?
Oct 13, 2012 | LG Televison & Video
Tip
LG DV582H region free code
Here are the steps to make your LG DV582H DVD region free.
1) Power on (with no disc)
2) Wait for msg "No disc"
3) Open tray
4) Push three times number 0 (i.e.: 0 0 0)
5) A blue screen appears with the code region factory set, and the option to set the new region code
6) Press 0 (zero)
7) Press Pause (A msg say that you have to press de new code and them press pause to confirm....so, is to easy)
8) Close tray
9) Turn off
Works 100% for my LG DV582H region 4, now its region free!!
Good Luck
on Jan 03, 2011 | Audio Players & Recorders
Tip
LG LH-D6235 Region Free Fix
LG LH-D6235 DVD Home Theater Region Free Fix
Would you like to make your LG LH-D6235 DVD Home Theater Region Free?
Follow these steps:
  1. Press the Pause button on your remote control
  2. Using your remote control enter the code 3, 1, 4, 1, 5 and 9 (If your unit does not enter the following mode which enables you to enter a region code, repeat steps 1 and 2. You may need to enter these codes in a shorter time span for them to work.)
  3. Press the 0 button on your remote control for Region free, 1 for Region 1 or 2 for Region 2.
  4. Press the Pause button on your remote control
  5. Power off your player and wait a few seconds
  6. Power on your player
I hope that helps.
____________________________________________________________________
Download LG LH-D6235 Home Cinema System Manual
on Jul 14, 2010 | LG LH-D6230 System
What is the code to make LG DP522H DVD player region free (0)/ multi-region? (this replaces my question yesterday where I got the LG model wrong!)
Ok so here is how it was done.
Press the Pause button on your remote control. Using your remote control enter the code 3, 1, 4, 1, 5 and 9, Press the 0 button on your remote control for Region free, 1 for Region 1 or 2 for Region 2. Press the Pause button on your remote control. Power off your player and wait a few seconds. Power on your player
Or
Press the Setup button on your remote control then, Step, Next, Up and Down, select the region of your choice or Bypass for region free, save and then Exit the menu.
LG 3200E, LG 3520, LG 4351, LG 4721P, LG 4730, LG 4821P, LG 4950S, LG 5083, LG 5822N, LG 593W
Aug 12, 2012 | LG Televison & Video
I have a LG HR559d blue ray Is there a region Crack for this model
These are not for your model, but you can try them anyways.
LG 2300
With "no disk" on tray, press sequentially in the remote control PAUSE,3,1,4,5,9:
code -- will appear in the display. Enter the region or 0 for region free.
LG 3000
Or
Mar 09, 2011 | Audio Players & Recorders
Region code error for my LG RC388 DVD/VCR player & recorder
1) Power on player with no disc in tray
2) Press PAUSE
3) Key in 314159
5) For multi-region, select 0
6) Press PAUSE again
7) Power off player
8) Wait a minute turn it on.
Please rate our Free help to keep the service online ++++
Aug 30, 2009 | Televison & Video
Is there a way to make my LG DVD multi regional?
please check this thread from answersbag.com
"1. Insert the DVD with Region Code which will not play. 2. Press 0000 on the remote and a new screen should appear showing Region Code for the LG V271 (as Region 4). 3. Select new region code as 0. 4. Press Pause to exit the screen and your LG V271 should now be region free."
Aug 02, 2009 | LG V271 DVD Player/VCR
Need unlock code for LG V774W
Howdy,
I just tried this on LGV774W and it worked :))
To make this player region free (or change the region), do the following:
* Ensure that there is no disc in the player (ie: "no disc" is displayed).
* Press PAUSE
* Enter 314159
* Enter the region code (0 for region free, or 1-6).
* Press PAUSE
* Turn the player off for a few seconds.
* Turn the player back on
* Voila! You beauty!!
Jan 13, 2009 | LG XBR446 DVD Recorder/VCR
Code region
power on the dvd
let it load and show no disc
open tray and enter '0' four times
region edit and region code appears with the default code
press 0 for region free and enter
region code should be 0
press pause on remote
power off and on again
Jan 03, 2009 | Televison & Video
Televison & Video Logo
405 people viewed this question
Top Televison & Video Experts
Electro Med Services...
