Question about Crosley Arlington Stack-O-Matic CR66 Shelf System
Replacement of turntable belt on crosley cr66
How do I replace the turnrable belt??
2 Suggested Answers
SOURCE: can't play records on my crosley cr66 turntable
You have to lift the tonearm up, and move it to the right slightly. This starts the turntable moving.
Posted on Apr 13, 2011
I have had my crosley cr66 rochester for 8 years. all of a sudden, the turntable wobbles when i put a record on it.
Pull the platter off and look to see if it has a bearing, if it does try and find a replacement for it.
Jul 08, 2016 | Crosley Radio & Crosley Furniture Crosley...
We just got a crosley radio CR66 model,we cannot get the turntable to activate,it wont turn!It is brand new! so I dont understand whats wrong? we hear a click sound but nothing happens please help ty Bill
remove the rubber plate at the top of the record player,, under that is a metal plate, in that plate is a large "sight hole" look in that as you turn the plate around,, look for the belt that has fallen off the motor shaft and the plate itself,, if you can't locate it, there is a spring clip at the base of the post that holds the metal plate on, remove that , you will see the motor shaft, and the ridge on the underside of the metal plate that the belt has to be on, they sometimes fall off in shipping,
Sep 07, 2011 | Crosley CR248 Turntable
I have a Crosley CR66-PA. It's 120 volts and I
It might have blown the fuse if you are lucky. Otherwise it's likely the transformer failed.
Jun 11, 2011 | Crosley Audio Players & Recorders
I just bought a replacement needle for a Crosley CR66 4 in 1 record player and now my records sound distorted and far away
It might be that you have caused an earth wire to the cartridge to come off or loose. Check the connections to the cartridge.
Jun 08, 2011 | Crosley CR248 Turntable
Crosley CR66 turntable not turning, belt is fine - motor?
frozen motor maybe or blown interal fusesmaybe,try manualy spinig platter to try an maybe free it up
Aug 07, 2009 | Crosley CR248 Turntable
Can't play records on my crosley cr66 turntable
May 27, 2009 | Crosley Arlington Stack-O-Matic CR66 Shelf...
Turntable does NOT turn.Crosley CR66 vintage Radio and Turntable
Try this - GENTLY move the phono arm to the RIGHT until you hear a click Tof course, do this after you turn on the power via the volume dial and set the other dial to"phono"). Doing this turns on the turntable when you haven't used it in awhile. This worked for us, hope it works for you.
If it doesn't work, you can check the belt by removing the tiny clip at the center post and gently lift the turntable platform/tray to peek at the motor and belt underneath. The pulley is on the right at the 2 o'clock position, the belt should be in contact with it.
May 27, 2009 | Crosley Audio Players & Recorders
Crosley Arlington Stack-O-Matic CR66 Shelf System Logo
Top Crosley Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Crosley Audio Player and Recorder Expert? Answer questions, earn points and help others
