Fujitsu Lifebook not booting up - main screen only.
My son recons he was on his laptop & the screen went blank. Still a light but nothing on the screen.I restarted it but only get the Fujitsu main screen & it goes no further. I tried restart & F10 it only comes up with boot menu but will not progress to anything else. Even esc from there doesn't work.I've done the basic static drain but a bit stumped as to what it could be.Thanks for any suggestions in advance.
dreamkam
  • 83 Answers
SOURCE: compaq 6735s notebook pc goes to HP screen, but wont boot
First you need to determine how many blinks you are getting when you try to power on the laptop.
Check the blinking codes below and reason behind that for HP Compaq laptops
Blinking battery power LED Battery Insufficient charge on the battery
Blink: 1 - Caps Lock/Num Lock - CPU CPU not functional
Blink: 2 - Caps Lock/Num Lock - BIOS BIOS corruption failure
Blink: 3 - Caps Lock/Num Lock - Memory Module error not functional
Blink: 4 - Caps Lock/Num Lock - Graphics Graphics controller not functional
Blink: 5 - Caps Lock/Num Lock - System board General system board failure
Blink: 6 - Caps Lock/Num Lock - BIOS BIOS authentication failure
Plz get back so I can suggest you the steps to resolve the issue.
Dreamkam
Posted on May 24, 2010
  • 44 Answers
SOURCE: Laptop Not booting up, Scroll Lock indicator blinking
Your user guide might provide a mean to interpret the meaning of the blinking Scroll Lock Indicator...
Posted on May 09, 2010
Minzuko
  • 100 Answers
SOURCE: Fujitsu Lifebook does not boot up
Have you tried draining the static on your computer?
Turn off the computer
remove the battery and adapter
press and hold the power button for 1 minute
plugged back in the adapter and battery
turned on the computer
if not resolved:
tried using an external monitor and connect to your computer to check if you can have a video on the external, if yes it is possible an LCD issue
Also, you may try using a flashlight in your LCD and check if you can see any, if none?
I suspect possible LCD issue.
Posted on May 21, 2010
electron-man
  • 136 Answers
SOURCE: I have a sony vaio
you will need the restore cdrom's to fix this issue. sounds like you the wrong upates! you should only updates that come from the sony web site for your particular sony item.
refer to sony tech support.
Posted on Aug 23, 2011
SOURCE: Futitsu Lifebook not booting - first screen only.
What you would need to do is go to the power button, turn on and immediately hit the F8 key and go into safe mode with networking, and then run malware bytes to see if there is any virus's on the computer, use this link to download malware bytes free edition to clean the computer of virus http://download.cnet.com/Malwarebytes-Anti-Malware/3000-8022_4-10804572.html?part=dl-10804572&subj=dl&tag=button
Once completed, then if it still doesn't work, you would need to reload the operating system, make sure the computer is backed up, then use the install disks that came with the computer when you bought it, the install will take about 2 hours, if you don't have the install discs call the manufactuer and then will send you them in the mail for free to reload the computer software.
Posted on Jul 29, 2013
Jul 28, 2013 | Fujitsu Siemens LifeBook® S7110 PC...
My Lifebook C2310 has a blank screen. How can I fix the problem?
If your laptop appears to boot up and the hard disk LED flashes, then the problem is probably a back light fault. This can be a faulty inverter or a faulty CCFL lamp. Please click on this link and follow my instructions to identify the fault and possible fix :- http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
Feb 21, 2013 | Fujitsu cp189608-01 - Lifebook C2310...
The screen on my Fujitsu Notebook N6000 just went blank
If your laptop appears to boot up and the hard disk LEDflashes, then the problem is probably a back light fault. This can be a faultyinverter or a faulty CCFL lamp. Please click on this link and follow myinstructions to identify the fault and possible fix :- http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
May 06, 2012 | Fujitsu Siemens Fujitsu LifeBook N6000...
I have a fujitsu siemens lifebook E7010 laptop and the problem is this : When I switch on power the system goes ON but with a black screen and the small LCD is showing the start logos CD player is working...
This may cause by an electrical charge in the motherboard itself,Im not really sure how it affects the display of the computer.There's also a possibility that the problem is with the LCD cable or the LCD itself. Please follow this method since it usually fix such problem like that,
1.Removed the battery then unplugged the AC adapter
2.Press and hold the power button or the ON/OFF button for at least 30 seconds
3.Connect the power supply back to your computer then turn it back on.
4. Check if you will see any difference.
5. If nothing happens, try to press and hold Fn and F2 on the keyboard.
If nothing happens, there is a possibility that the problem is with the LCD or monitor itself, maybe it will need a replacement...
I hope this information will be helpful. Thank you for using FixYa...
Jul 22, 2011 | Fujitsu LifeBook E7010 Notebook
if not resolved:
May 21, 2010 | Fujitsu LifeBook A6010 Notebook
May 09, 2010 | Fujitsu Siemens LifeBook® S7110 PC...
My Fujitsu LIFEBOOK N3430 Notebook does not boot up the screen is blank
Remove the battery for 5 minutes, press and hold the power button for 3 seconds, wait 5 more minutes, put battery back in and see if everything works now. It should. This usually works.
If it doesn't, you may have a faulty memory chip causing you the black screen.
You can try removing one at a time to see if it corrects the problem.
Lastly, the ribbon cable from screen to motherboard can become piched and non responsive.
Nov 25, 2009 | Fujitsu LifeBook N3410 Notebook
External monitor on Laptop not receiving a signal
When you start your computer, keep hitting the F8 key. you will get a menu that comes up.. Choose the VGA mode.. this will stop the computer from loading video drivers and will allow you to install the new monitor.
Give that a try.. Hope it helps... let me know
May 31, 2009 | Fujitsu Siemens AMILO D-7830 Notebook
I have a Fujitsu Lifebook P-2040 that I just reformatted. I'm going to install Windows 2K Professional (don't have the restore disks for XP Home). After I reformatted and restarted, nothing happens. There...
Is there any reason for your preference for Win 2K over Win XP Pro? XP Pro would be a better choice over Win 2K.
You may be able to selecting the CD as the alternate boot device by pressing F12 as the laptop is booting up.
I am not familar with BIOS key on your laptop but you can try these keys on a cold boot up (don't use a warm boot up - Ctrl+Alt+Del keys). Try:-
Del
F1
F2
F10
Ctrl+F1 or F2
Alt+F1 or F2
Esc+F1 or F2
Once you get into the BIOS you can change the boot order, set the CD as the first device. You should be able install Windows from the CD.
If these keys don't work go to the Fujitsu WEB site to download the manual, whilst you are there you will also need to download the drivers for your model laptop the Windows version of the devices that are installed on your laptop eg. audio, video, modem, LAN etc. These need to be installed after the Windows installation.
Dec 20, 2008 | Fujitsu LifeBook P2040 Notebook
Computers & Internet Logo
123 people viewed this question
David Payne
David Payne
