Question about Dryers
Maytag neptune Dryer won't start. Get an error
    Top Expert:
  • 12,223 Answers
Reset the dryer .disconnect the power cord by 30 -40seconds, and try again, if the problem persist with the error, read you owner manual in troubleshootign section. or dwonload the owner manual for identify the error problem, can be problem a temperature.
go to www.retrevo.com
God bless you
Posted on Jul 28, 2013
fixinit4me
  • 10 Answers
SOURCE: Maytag Neptune dryer error
To find out what the code means,
contact Maytag ServicesSM, Maytag Customer Assistance: U.S.A. 1-800-688-9900 or
Canada 1-800-688-2002.
Posted on Oct 28, 2007
SOURCE: Changing the drum rollers on a Maytag MDE4000AYW Neptune Dryer..
The instructions above are perfect for most Maytag Dryers, but the Neptune MDE4000AYW is built differently from most. To open it, undo the two screws that run through the door hinges, and remove the door, then undo the two other screws that are on the opposite side of the doorway. With these four screws out, you can lift the front panel UP and out. Make sure you unplug the dryer first :-)
Posted on Nov 21, 2008
milten1
  • 1304 Answers
SOURCE: Maytag Neptune Dryer Won't Heat up
these particular dryers have issues with the heat coils,
it probably has a bad element
Posted on Oct 03, 2009
heatman101
  • 43501 Answers
SOURCE: when we push the button
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on May 20, 2011
canwoodjc
  • 3301 Answers
SOURCE: My Maytag Neptune Dryer stopped running & is
as per heatman The most common cause of your appliance giving you the PF error code is a problem with the power coming in from your utility company. Of course if there is an interruption of power, and then the power comes back on you will get the PF code Loose wires going to the circuit board or the control can also be a cause of the error code. If a wire terminal end happens to get corroded or loose, the vibration from the machine can cause slight power problems and this can cause the PF code to be displayed. Finding the cause of this type of problem is like finding a needle in a haystack. Sometimes you can cause it to be displayed by banging on the side of the appliance or slightly moving the wiring harness, to see if you can get the error code to display.
The bottom line about this power failure error code, is that it is power related. Finding the exact cause can be difficult. If you are continually having to reset the appliance then check to see if all of your appliances are giving the same code. This will indicate utility power problems. If only one appliance is giving the PF code then it is probably internal to the appliance.
Posted on Jul 12, 2011
Error code FL-maytag neptune front load washer won't lock
replace door latch (fl = faulty latch ) good luck APPLIANCES R EN
Mar 09, 2013 | Maytag Neptune MAH5500B Front Load Washer
May tag washer Neptune door won't open
what is your model number is then we can get started then
Oct 25, 2012 | Maytag Clothes Washer Dispenser Bezel...
Maytag Neptune wont heat up what is problem
We just converted my neptune gas dryer to propane. It ignited yesterday but we could smell propane. So, my husband fixed that ,now it won't ignite and heat up
Nov 10, 2011 | Maytag Neptune MDG5500AW Gas Dryer
Hello I have a MAYTAG NEPTUNE DRYER Model# MD5500 (MDE5500AYQ) . The console panel lights up.You can load up a cycle on the display but the unit won't start. It Just beeps or locks up.So I checked the...
heatman101
Jul 30, 2011 | Maytag Neptune MDE5500AY Electric Dryer
Error message appearing "power failure occurred
Push the Start/Stop button on the Neptune to reset the machine.
Dec 26, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Error E5 or L5???
L5 means it cannot sense the lid open or closed.
Lid switch is likely bad.
This error code may also be used if there is a disagreement between the motor and machine controllers on the state of the lid switch. The control should not allow the unit to run in this condition. This code will also appear if the user presses the START key while the lid is open. Open the lid or press STOP/CANCEL to clear the display.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Aug 23, 2010 | Maytag Neptune MDG5500AW Gas Dryer
MAYTAG NEPTUNE GAS DRYER
Unplug the unit and take off the cover where the cord goes in. You may have one burnt wire under that cover.
Mar 06, 2008 | Maytag Neptune MDG5500AW Gas Dryer
Oct 06, 2007 | Maytag MDE2400AYW Neptune Electric Dryer
Dryers Logo
115 people viewed this question
Top Dryers Experts
