Question about Electrical Supplies
JD 5410 tractor, how to replace starter
Looking for informative pictures or video on how to change the starter in my tractor, it is a JD 5410 and I cannot get it out...
5 Suggested Answers
wireguy212
  • 1627 Answers
SOURCE: 1989 JD 2155 2WD tractor, cannot start engine,
Have you tried crossing the large post of the starter with the small terminal that has the engagement wire going to it[with the machine in neutral and the range lever in neutral if course].If this will make the tractor turn over then the problem is likely the neutral safety switch located under the panel that is covering the transmission just rear of the sticks.
Posted on Jan 08, 2010
Mackmech11
  • 122 Answers
SOURCE: jd tractor 11hp briggs engine has no stark
I would check the stator which is located on the top or side of the motor, this is what produced spark and if there is rust on it it will lose spark. so basically remove the fan housing the top of the motor and you should see it either on top or directly on the side i believe it has one wire going to it green in color and is held down by two bolts. good like look out for the rust
Posted on Apr 18, 2010
SOURCE: I have trouble starting my 316 JD tractor. When I
I have a JD 316, and have had a similar problem for about ten years, now my starter literally burned up, I guess it was gradually getting worse.
Posted on Jun 17, 2010
wireguy212
  • 1627 Answers
SOURCE: JD 301 industrial loader tractor Overheating
You may need to do a compression test on the engine to confirm whether or not the head-gasket needs to be replaced,that's where i would start if the thermostat is not the problem and the hydraulics are not loading up.Check for oil in the radiator or anti-freeze in the oil as well as for white smoke out of the exhaust,all are indicators of a bad head-gasket.
Posted on Jul 18, 2010
How to change starter on 5410 john deere tractor
Visit the on-line store, know as reliable-store, they have the repair manuals. I'm sure you will get the solution of your problem.
Best Manuals
Oct 03, 2016 | John Deere Garden
How to remove starter jd 4310 ?
It probably the starter relay, or ignition switch. What does it do when you try to start?
Jul 23, 2014 | John Deere Seat 4210 4310 4410 4510 4610...
How do I change out the crankshaft seal on a 737 JD mower
gas or diesel ? ck out youtube look for kawasaki(gas) 23 hp motor shaft seal change and i got one up on a perkins diesel too it's for a older unit but the methods the same
May 13, 2014 | John Deere Garden
Changed starter soleniod on z 425 jd mower wont turn over
some of the new 2 wire solenoids have power to on one small post and the switch triggers a ground to the other found that out the hard way as well
Jun 28, 2012 | Garden
I have a 3010 John Deere +24 volt pos ground how do I change from 24 volt gererator to a 24 volt altenator
The 3010 24v JD system is not a true 24v system. It is a balanced split 12v system, with one positive ground battery and one negative ground battery. The only 24 volt accessory is the starter, where the batteries meet in a series to provide 24 volts for starting. All other accessories are 12v, half powered by the positive ground battery and half powered by the negative battery. The generator charges one battery in one direction and the other battery in the reverse direction. Therefore a 24v alternator is not easily adapted to this system.
The usual solution is to change to a 12v system with an alternator, changing the starter to 12v and changing the polarity of the positive ground battery to negative ground.
The cost of a 12v starter and alternator is far less than the cost of a 24v alternator, plus the added benefit of using 12v lights and other accessories.
JD switched to this 12v type of system with alternator during the 20 series production, but used two 6v batteries in a series due to the larger cranking amp rating of the 6v batteries occupying the same physical space.
Jan 10, 2011 | John Deere 4020 Gas & Diesel Tractor...
My JD L120 starter solenoid is not being activated. Besides the seat button interlock what esle my be inhibiting the starter?
The pto switch,park brake switch and the seat switch will cause the tractor to not turn over,also the ignition switch could be the problem,start with the brake switch,under the right floor pan.
Jun 24, 2010 | John Deere 420,1020,2010,2020,2510,2520...
I need a good part number for my jd 2020 starter 4 cyl gas
Is it direct drive or gear? We carry both...your talking 157.97 plus S&H for Direct and 235.90 plus 60.00 core fee and then S&H for gear drive...both delco starters. ediesinc@gmail.com for more info.
May 27, 2010 | John Deere 420,1020,2010,2020,2510,2520...
JD 4440 Tractor - how to get air out of fuel line after changing filters.
the air should purge itself out while you are trying to start it. it should onlt take a few pulls (or cranks) one the starter to acomplish this...good luck
Apr 08, 2010 | John Deere 420,1020,2010,2020,2510,2520...
1989 JD 2155 2WD tractor, cannot start engine, have replaced starter switch, nothing happens, battery good. What should I check next?
Jan 03, 2010 | John Deere 420,1020,2010,2020,2510,2520...
Electrical Supplies Logo
Top Electrical Supplies Experts
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
