Question about Refrigerators
Diagram for LG Gr-382R Refrigerator
Were can I find a free download diagram of assembly and parts for this refrigerator?
Benimur
  • 6966 Answers
SOURCE: refrigerator not cooling.
Hi and welcome to FixYa,
Almost always, your described problem could be either:
  • evaporator fan/blower is faulty; or
  • air passgaeway blocked or vent is blocked or closed.
The refrigerator section gets its cold air from the freezer. If the freezer is working then the frozen air would have to be drawn to the refrigerator side by the fan. If the fan is not working or the air passage way is blocked, then no frozen air would be moving towards the refrigerator side. result would be as you described.
In some instances, it could be the thermostat of the refrigerator but this would be least likely.
Good luck and thank you for using FixYa.
Posted on Feb 22, 2009
SOURCE: Where to get bypass plug/cap for LG Refrigerator
I have been searched for awhile, no LG by pass for 5231JA2006A. I tried to modify the pipe at back of the refrigerator. My ice make did not get water and water dispenser works. Looks the diagram.... like this... ( by guess) ....
From supply ( bottom of the refrigerator), goes to top into filter. From filter, one goes to ice-mater. One goes back out to back and connect to water dispenser ... This sound not logic.... But looks like this.
I think I need to cut a used water filter and sealed inside to make a by-pass.
Posted on Jan 17, 2010
  • 161 Answers
SOURCE: lg refrigerator LFC22740ST loud humming noise no
You have a bad fan motor ... replace motor.
Posted on Jan 24, 2010
kel1guy2002
  • 3740 Answers
SOURCE: LG refrigerator GR-B258jvc - replacing light bulb
There are usually 3 or 4 locking tabs on the cover that just need to be pressed INDIVIDUALLY toward the bulb to release them and then carefully remove the cover. The ones with 3 tabs usually have and upper and lower tab then the thrid tab is on the side. Removed the upper and lower tabs by pressing inward to the bulb and then the cover will pivot out on the 3rd SIDE tab.
Thanks for using FixYa.
Kelly
Posted on Apr 09, 2010
heatman101
  • 43501 Answers
SOURCE: Top refrigerator part not cooling, bottom freezer and fan working
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Posted on May 25, 2010
Need ice maker parts breakdown AEQ36756907
Hi.
The icemaker AEQ36756907 is sold as a single part. For this reason the manufacturer (LG) does not provide a diagram with the exploded view of the ice-maker assembly (here part). A diagram with the icemaker position in the whole fridge assembly is available in the service manual. Here an example with the same icemaker shown at page 49 in position 600A.
Regards.
Ginko
Other models are similar.
Dec 15, 2011 | LG LFC25770ST (250 cu ft) Bottom Freezer...
WHERE DO I GET A MANUAL FOR THIS REFRIGERATOR LG GR 642AP
You could download the manual from :-
http://safemanuals.com/user-guide-instructions-owner-manual/LG/GR-642AP-_E
You need to have acrobat reader to view this.
Good Luck!!
Thanks!!
Aug 17, 2010 | LG Kitchen Ranges
MY LG fridge model GR- M562 YLY
If you pull frig out from the wall, so that you can get behind it you will see a diagram with information on it. It states what happens with what test.
TEST1-All display lights come on
TEST2-Number 22 22 appears
TEST3-Number 33 33 appears
I have a question is your frig making a loud humming sound or a screach. If so it means that the fans need replacing.
Jul 21, 2009 | LG LRTBC1825T Top Freezer Refrigerator
I have electrocool LG MOdel# GR-382R ser# 206MR17803. my bottom fridge cooler area is freezing up.
I have the same problem.It seems that the gasket around the freezer door and fridge door are no longer tightly adhering to the fridge therefore allowing the cool air from the freezer to continiuously entering the fridge storage and making evreything freeze up. I am trying to find out if I can purchase new gaskets and install them myself.
Any recommendation on where to find these and how to install them?
Thanks.
Jun 22, 2009 | LG Refrigerators
One of the pockets broke on the door of the fridge Pocket(see through plastic,on the door were you put your milk etc...where would i buy this part? this is for the lg frost free gr 232 sbf
Go to this site,...select model number and type it in. Look in the sub-component list for Refrigerator Door Section. You will find a diagram and a parts lits. It will give you an acutual part number associated with that part and if you like you will be able to use that part number to price compare. Most other website parts sellers give you thier part number this is the only one that I know of that will give you an actual part number for that unit. Good Luck!
Click below and it will take you directly to the Sears Parts Store
http://www.searspartsdirect.com/partsdirect/index.action?psid=26127688&sid=PSx20071217x00001a
May 12, 2009 | LG Refrigerators
LG GR-292R freezer works/fridge does not.
well i have the exact same refrigerator but opposite problem.... the freezer works but the entire refridgerator is a freezer....why is the fridge part freezing everything. This appeared to happen after the power went out and the entire fridge is a freezer now.
Mar 02, 2009 | LG LFD25860
LG Refridgerator GR-131R. Out of the
Good day.
Seems like your thermostat went shorted that is why you cant control the temperature anymore.
chris
Mar 11, 2008 | Refrigerators
Refrigerators Logo
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
