Question about Exhaust for Chevrolet Camaro Convertible
What causes back firing - Exhaust for Chevrolet Camaro Convertible
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 43 Answers
Backfiring in internal combustion engines occur outside of the combustion chamber, and are typically the result of an improper air to fuel ratio. An overly lean air-fuel mixture (i.e. an overabundance of air) can lead to a failure to ignite in the combustion chamber, also called a "misfire". The unburnt fuel then enters the exhaust system, where hot components can cause the fuel to ignite unpredictably. Alternatively, rich air-fuel mixtures (i.e. an overabundance of fuel) can result in incomplete combustion, again causing unburnt fuel to enter the exhaust system.
Backfires may also occur before the combustion chamber. One possible cause of this is timing. If the timing is too advanced, the spark plug fires before the intake valves close, causing the combustion to propagate into the intake manifold, further igniting the air-fuel mixture there; the resulting explosion then travels out of the carburetor and air filter. On many small marine engines, a screen is placed over the intake of the carburetor as a flame arrestor, to prevent these flames from escaping the intake and potentially igniting fuel or fuel vapors in the enclosed sump or bilge of the boat, causing a fire or explosion. Alternatively, the engine timing may be retarded, in which case the combustion is not completed by the time the exhaust valves open, allowing the combustion to propagate into the exhaust system.
Additionally, improperly adjusted carburetors that create a lean condition during acceleration can cause the air fuel mixture to burn so slowly, that combustion is still taking place during the exhaust stroke, and even when the intake valve opens. The flame front can then travel up the intake and cause a backfire. In this situation it is conceivable that there is a backfire occurring in the intake manifold and exhaust manifold simultaneously.
In both cases (combustion occurring before and after the combustion chamber), the result is a sharp pop, which is colloquially referred to as a "backfire". However, for troubleshooting, engine mechanics more strictly define an ignition of fuel within the engine exhaust system as an "afterfire", while a "backfire" is this same process taking place in the induction system.
Posted on Jul 28, 2013
L2000 craftsman riding mower won't crank just backfires. Has new spark plug & carburetor fills up with fuel
Back fire is a result of timing being off. If the mower does not have electronic ignition, the points can be worn causing a timing issue. Back fire is usually and ignition of unburned fuel igniting outside the cylinder such as in the exhaust system. A valve not seating usually causes low compression but rarely does it cause a back fire. Start there.
Aug 20, 2017 | Craftsman Garden
Can a large enough backfire threw the tailpipe throw off your timing
no
but the back fire could be caused by a failed timing belt or chain
a back fire is just exploding fuel in the exhaust or inlet manifold caused when a valve has not properly closed and fuel fire is allowed to escape
Dec 17, 2016 | GMC Vandura Cars & Trucks
Can the charging system on a 2004 polaris ranger cause back firing cutting out and dying
these ATVs do a lot of hard work for size of motor
worth checking other things as per normal servicing
new spark plug
clean air filter
drain and add new fuel to tank
wont hurt to clean the carby or bowl contents
if fitted with a fuel filter inline .. fit a new one
and valves adjustment if still back firing
Oct 13, 2016 | ATVs
Car back fires. what causes that?
Usually its a hole in muffler
Mar 06, 2015 | Cars & Trucks
What causes backfire issues on a craftsman riding mower
The most common reasons any motor backfires are timing being out of adjustment or dirty spark plugs, in this case a dirty plug. Carbon deposits cling to the electrode, effectively changing the gap of the plug, or glowing long enough after the actual firing to cause another firing in between the normal firing, (back fire). I'd lean towards a good spark plug cleaning or just a new plug.
Aug 10, 2014 | Craftsman Garden
Its back firing and keeps cutting off cleaned the filter
Hi: Did you hit a rock or other solid object ,Some times if you hit a hard object it will Shear or partly move the Flywheel Key and throws the timing off which will cause kick back and back firing. If it is back firing through the carburetor it is probably flooding cause by a dirty or faulty fuel jet and seat, if so clean and check the jet in the carburetor. Hope I have helped you AL
May 08, 2013 | Briggs & Stratton Garden
81 full size blazer back firing. i changed spark plug wiring. still back firing any solutions.
check thie rotor and inside the cap for any signs of arc's or burn areas, any debris built up on the contacts inside the cap will cause the motor to fire wrong and late , which would cause backfiring
Jul 23, 2011 | Chevrolet Blazer Cars & Trucks
I have a 2001 that backfires
YEP A CRACKED DISTRIBUTOR CAP.CAUSE BACK FIRING AND CROSS FIRING PLUG WIRES.BAD PLUG WIRES WILL CAUSE BACKFIRING.WRONG HEAT RANGE PLUGS WILL ALSO CAUSE BACK FIRING.
Nov 10, 2009 | Dodge Ram 1500 Cars & Trucks
Exhaust for Chevrolet Camaro Convertible Logo
286 people viewed this question
Top Chevrolet Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Mike
Are you a Chevrolet Vehicle Part and Accessory Expert? Answer questions, earn points and help others
